6 Replies Latest reply on Feb 24, 2014 11:51 AM by Darcey76
    Debugging is BROKEN. Can't launch debug more than a couple of time. (says it can't delete swf file)
    matteosistisette Level 1
      I do this:
      - open a project
      - start debugging it
      - my code throws some error, so execution stops and I can see the error backtrace
      - stop debugging (I click the stop button, then I even click "remove all terminated launches")
      - edit some of the .as files and save
      - try debugging again.
      I get an error message saying thet the project has errors, whether I want to debug anyway. My code has no compile error. The only error that appears in "problems" is:
      xxx.swf: cannot access file. The file is in use by another project.
      If I choose to procede anyway, the debug is launched but the project has not been recompiled (obviously) and the older version prior to changes is run.
      If I manually clean the project I get the error:
        cannot delete xxx.swf
      where xxxx.swf is the main swf of the application.
      OBVIOUSLY no other process is using the swf file except FlashBuilder itself.
      No way I can get debugging to work. I have to close Flash Builder, restart it, then I can debug the project. Once. Because the next time I edit something and try to debug again, i get this nonsense error again.
      Is there a fix for this bug that renders Flash Builder useless?
      thanks
      m.
