3 Replies Latest reply on Apr 17, 2008 6:49 AM by jojolina
    Quiz Result Messages
    Jillbr
      Hi
      I'm working with Captivate 3 on the quiz options, and the Quiz Result Messages are not displaying? Does any one have any suggestions on why this is happening?
        • 1. Re: Quiz Result Messages
          jojolina Level 1
          Hi Jillbr
          In your project, check your settings at :
          Quizz / Quizz Preferences
          and select the Settings nodes.
          Confirm that the "Show score at end of quizz" box is selected and next to this is a "Quizz Result Messages" button which will allow you to edit what gets displayed to the user.
          Cheers and post back if this does not work please.
          Andrew
          • 2. Re: Quiz Result Messages
            Jillbr Level 1
            Andrew
            Thanks for the feeback.
            The settings are correct. I tested it more after posting my message and what I found is that the default message will display. When I personalized the text, which is much longer, it no longer displays. Could there be a cap on the number of characters entered into Quiz Result Message box?
            • 3. Re: Quiz Result Messages
              jojolina Level 1
              Hi again Jillbr
              Just check on your Quizz Results slide if you can see the text box containing the message you want. Resize this box bigger (vertical & horizontal) and you should be able to view it no problemo, but post back if problem persists.
              Keep having Fun
              Andrew
