6 Replies Latest reply: May 12, 2012 4:17 PM by margieannejulie RSS
    stuck with date from IPTC core
    margieannejulie Community Member
      I usually change date from template when not corresponding to real one, and succesfully. Now doesn't work, daTE  is stuck at date at IPTC core, and I can actually change from there but I prefer to change from template
      (small icon top right)
      I did tools/purge cache for folder, and restarted B holding down option key.
      Also in accounts language and tex>region, I am in correct country
      Problem is I dont like date format from the IPTC core, I prefer 6/6/11 to 11-06-06
      thanks
        • 1. Re: stuck with date from IPTC core
          Omke Oudeman Community Member
          To my opinion you won't benefit from a template because that has fixed info and you want to have different values.
          And whether you like it or not, IPTC s a world standard and it might not be a good idea to change this because other applications or users depend also on this format.
          If you want the date format you wish you can choose to do so in a batch rename setting, for instance for a series of images use the format yy-mm-dd_Filename_sequencenumber.
          If you use yyyymmdd_filename_sequencenumber your files have a natural sort order in the finder
          • 2. Re: stuck with date from IPTC core
            where is batch rename
            • 3. Re: stuck with date from IPTC core
              Menu Tools/ Batch rename or shortcut ShiftCmdR
              It is only active when having a file selected but of course meant to have more selected and then in one go rename the selected bunch
              Be sure to check the options for extra fields and the options in the pop up menus from the fields. You can also save custom settings.
              • 4. Re: stuck with date from IPTC core
                The choice of date format is interesting, I can't apply just yet. I selected a picture in metadata, selected  DDMMYYYY in drop down,
                clicked rename, but in metadata it stayed 2011-06-30.
                I suspect i have to select something in "date time" and "date created" menus, just to the left?
                • 5. Re: stuck with date from IPTC core
                  You can't change the creation date in an easy way, it seems that it is able using a script but You should drop tat question in the dedicated Adobe Scripting forum.
                  Batch renaming is altering the filename. Using a yyyymmdd format automatically gives you the correct sort order in a folder and also adding the correct date in the description area would make it easy findable when searching.
                  Do you have a specific need for changing the date created in the IPTC field?
                  • 6. Re: stuck with date from IPTC core
                    1.   The question about batch rename was not about changing the date, but changing the format. In other words, if I select a picture,
                    select DDMMYYYY, click on "rename" and nothing changes in the date order, how do you use it if you want to actually change the date order?
                    If you read my previous post, it says: the option of date format is interesting, but I can't apply it. In other words, it doesn't work.
                    Just try it: select a picture in B, give it a date format different from 2011-06-19 which is the (for me at least) default format, click on rename, and NOTHING changes, that's why I was wondering what else I had to click on.
                    2.   As far as changing the date created, yes, I need that: If I have pictures taken in Libya in june 2011, during a fight in Misrata, and
                    all the world knows that Misrata had the Arab spring in 2011 and they show may 2012, which is the day that I fixed them or
                    who knows why, that is ridiculous, right?
                    So I have to change the date back. Can somebody tell me how that happened, or I will make a post for that.
                    Pease keep the 2 issues separate.
