7 Replies Latest reply on May 6, 2012 7:48 AM by harmonyJJ
    Single Pages for print coming up with overlapping images from previous page ?
    harmonyJJ Level 1
      I am new in Indesign. I have finished a 192 Pages magazine in Indesign CS5, when I export in PDF in single pages I get a piece of the previous page always showing on the following pages. This for the entire document. As if they were overlapping. What am I doing wrong ?
        • 1. Re: Single Pages for print coming up with overlapping images from previous page ?
          Sounds to me like you've exported including an inside bleed.
          • 2. Re: Single Pages for print coming up with overlapping images from previous page ?
            harmonyJJ Level 1
            Hi Peter, Can you explain me better ? Shall I uncheck something when I Export ?
            • 3. Re: Single Pages for print coming up with overlapping images from previous page ?
              harmonyJJ Level 1
              Peter you are a GENIUS!!!! It worked!!! I have an other question. When I import Pictures from outside, in High Res, hall I give them the 4 colour separation or this is automatic ?
              • 4. Re: Single Pages for print coming up with overlapping images from previous page ?
                First, let's talk about inside bleed. Most of the time you don't need itm but there are cases where it may be required. How are you biniding this?
                Normally, the inside bleed really is just the edge of the opposite page, and there's no harm if that area is blank or if the objects that need the bleed actually cross the spine. And most RIPS, I think, are capable of ignoring the inside bleed during imposition, so it's not generally a fatal error in any case. Where it get's tricky is if you have a real need for the inside bleed, but the object stops at the spine. In those cases you generally want to split the spread and extend bleeding objects. See InDesignSecrets » Blog Archive » Breaking Pages Apart to Bleed Off a Spine
                Separations are the responsibility of the printer. If they've asked you to provide them, it's time to evaluate whether this is someone you really want to work with. Normal procedeure is to provide a composite PDF in single pages (in otherwords, you just export your layout) and the printer takes care of imposing (arranging the pages on the larger sheet) and separations. If they provide you with an output profile you will want to convert the colors to that profile at export.
                • 5. Re: Single Pages for print coming up with overlapping images from previous page ?
                  harmonyJJ Level 1
                  No they didn't ask for anything: I just wanted to know how to do it. Since it is my first big project.
                  They asked only for the PDF with bleed signs, but nothing else, as their Machine, places all the crops and other signs.
                  I have preflight set and check all the errors.
                  I have turned all the Black ink into Full Black C=0, M=0, Y=0, K=100
                  All colors are in quadricromy.
                  Ready to Package it, but they actually don't need links or fonts. I hav easked.
                  I only had 2 errors left: the inside bleed, but now it is resolved.
                  The second error is: Color space not allowed (100+) what is this ?
                  • 6. Re: Single Pages for print coming up with overlapping images from previous page ?
                    When you say quadrichromy, do you mean CMYK, or some other space like LRGB?
                    I ALWAYS provide crop marks for any file that has bleed, even if I know the RIP will delete them and put in new ones. There can be no question about where to trim if you show it.
                    And what do you mean by full black? Did you have tints before that you might really have wanted? have you substitued a K-only black for a 4-color "rich black"? What sort of objects have you done this to?
                    A color space not allowed error means the preflight is set to look for a color space that you don't want, either CMYK, RGB, Lab, Grayscale or Spot. The default profile doesn't look for this, so you must be using a custom profile, and it may not be what you want, so you should click the Preflight panel flyout menu and go to Define Profiules and check it. That aside, 100+ color errors usually indicates that your images are RGB and you've flagged it as not allowed. This is NOT a fatal error as long as you either convert to CMYK during export, or use the PDF/X-4 preset which leaves colors unchanged, embeds their profiles, and the output intent, so the conversion can be done in the RIP by the printer. You should check withthe printer first, though, to make sure thay can handle this.
                    • 7. Re: Single Pages for print coming up with overlapping images from previous page ?
                      harmonyJJ Level 1
                      quadrichromy: I mean CMYK for all colors
                      Crop Marks: So I can send themc rop marks and than they can delete them. OK.
                      I have a lot of black background with White text in 10 Pts. In order to avoid unpleasant surprises of overlapping CMY. The printer asked me to convert all black in a full black C=0, M=0, Y=0, K=100 or eventually in a RICH black such as C=50, M=0, Y=0, K=100
                      Color space: Yes I will covert all colors in CYMK during export as requested by the printer.
                      Thank yu very much. You helped a lot!
