4 Replies Latest reply on Apr 24, 2008 2:12 AM by Aussie_Bloke
    “Full Motion Recording” gives multiple slides
    MatsSjoq
      I’m recording web lectures using Captivate v3.
      Recording as “Full Motion Recording” results in multiple slides. How do I avoid this. I just want one continuous slide containing the whole video and whole audio.
      The lecture is then published to Flash.
        • 1. Re: “Full Motion Recording” gives multiple slides
          This question was also asked in a different forum category. This practice is known as cross-posting and should be avoided. Please direct any responses to the other post. You may do so by clicking here.
          • 2. Re: “Full Motion Recording” gives multiple slides
            MatsSjoq Level 1
            I’m sorry if I have expressed myself so poorly so you interprete it as a cross-posting. As I view it I have two different problems.
            1) When I record “Full Motion Recording” I get multiple slides, while I want it to get recorded as a single slide.
            2) If I have a recording consisting of multiple slides and export it, I get the audio in several files. Is it possible to export the audio in a single file?
            I posted the recording question and the export portion of this problem in the respective forum. Is that cross-posting?
            • 3. Re: “Full Motion Recording” gives multiple slides
              RoboWizard Level 4
              Hi MatsSjoq
              Sorry about that. My bad. I read the part of recording lectures in both places and misinterpreted your posts.
              The link I provided in the other post should help with the multiple sound files. If you are wanting a single continuous video file, Captivate probably isn't your tool of choice at the moment. Who knows what the future may hold, but presently I don't believe it's quite up to the task of a single way long recording.
              If you wish to try and coax it into a single recording, there is a Full Motion Editor you may download and use. Personally, I believe it's a bit of a misnomer to call it an "editor", as it doesn't truly allow for editing individual elements. It really only allows slicing, dicing and joining multiple full motion clips. You may view the article as well as download it by following this link.
              Cheers... Rick
              • 4. Re: “Full Motion Recording” gives multiple slides
                Aussie_Bloke
                I am a new user of Captivate but with many years pf software experience but are finding a lot of problems with Captivate. I have already reasearched this problem and I think this is part of your answer. It appears a Flash file will not allow more than 16,000 frames. If you record and compress at 30fps, then you will have an upper record limit of 8.9 minutes. You can change the output production rate to create the flash file to a lower value say 25fpm BUT you will get a poorer quality output.
                Hopefully Adobe will look at some of these file limitations as any swf file over 10 minutes becomes a night mare.
