2 Replies Latest reply on Apr 10, 2008 2:44 PM by prwirk
    Flash Remoting Error
    prwirk
      I am trying to get Flash Remoting working on my local machine and keep getting the following error when I run the compiled .swf file with the RemoteObject reference in it:
      faultCode:Channel.Call.Failed
      faultString:'error' faultDetail:'NetConnection.Call.Failed: HTTP: Failed
      Can anyone help? I do get a blank page when I navigate to http://127.0.0.1:8500/flex2gateway/, not an 404 error. I'm completely stuck at this point and don't know what else to do!
        • 1. Re: Flash Remoting Error
          SujitG Level 2
          can you please make sure the end-point URLs in the services-config.xml/remoting-config.xml are proper.
          Hope this helps.
          • 2. Re: Flash Remoting Error
            prwirk Level 1
            Here is my services-config.xml file currently:
            <?xml version="1.0" encoding="UTF-8"?>
            <services-config>
            <services>
            <service id="coldfusion-flashremoting-service"
            class="flex.messaging.services.RemotingService"
            messageTypes="flex.messaging.messages.RemotingMessage">
            <adapters>
            <adapter-definition id="cf-object" class="coldfusion.flash.messaging.ColdFusionAdapter" default="true"/>
            </adapters>
            <destination id="ColdFusion">
            <channels>
            <channel ref="my-cfamf"/>
            </channels>
            <properties>
            <source>*</source>
            <!-- define the resolution rules and access level of the cfc being invoked -->
            <access>
            <!-- Use the ColdFusion mappings to find CFCs, by default only CFC files under your webroot can be found. -->
            <use-mappings>false</use-mappings>
            <!-- allow "public and remote" or just "remote" methods to be invoked -->
            <method-access-level>remote</method-access-level>
            </access>
            <property-case>
            <!-- cfc property names -->
            <force-cfc-lowercase>false</force-cfc-lowercase>
            <!-- Query column names -->
            <force-query-lowercase>false</force-query-lowercase>
            <!-- struct keys -->
            <force-struct-lowercase>false</force-struct-lowercase>
            </property-case>
            </properties>
            </destination>
            </service>
            </services>
            <channels>
            <channel-definition id="my-cfamf" class="mx.messaging.channels.AMFChannel">
            <endpoint uri=" http://{server.name}:{server.port}{context.root}/flex2gateway/" class="flex.messaging.endpoints.AMFEndpoint"/>
            <properties>
            <polling-enabled>false</polling-enabled>
            <serialization>
            <instantiate-types>false</instantiate-types>
            </serialization>
            </properties>
            </channel-definition>
            </channels>
            <logging>
            <target class="flex.messaging.log.ConsoleTarget" level="Error">
            <properties>
            <prefix>[Flex] </prefix>
            <includeDate>false</includeDate>
            <includeTime>false</includeTime>
            <includeLevel>false</includeLevel>
            <includeCategory>false</includeCategory>
            </properties>
            <filters>
            <pattern>Endpoint.*</pattern>
            <pattern>Service.*</pattern>
            <pattern>Configuration</pattern>
            <pattern>Message.*</pattern>
            </filters>
            </target>
            </logging>
            <system>
            </system>
            </services-config>
            I've also tried with the end-point defined this way:
            <endpoint uri=" http://localhost:8500/flex2gateway/" class="flex.messaging.endpoints.AMFEndpoint"/>
            and I get the same error. When I use IE, I get an 404 error rather than just the HTTP failed. A colleague of mine installed with the same configuration and hers works fine. Also, I'm using CFMX 7.0.2 with Flex 2. I also have Flex3 and used to have ColdFusion 8 on my computer as well. I have uninstalled CF 8 to and reinstalled CFMX 7.0.2 to see if that made a difference but it did not.
            Any help anyone can provide would be greatly appreciated!
