1 Reply Latest reply on May 7, 2012 9:21 PM by Frustrated in AZ
    checking books back in?
    nburrf
      I have checked out and read a book from the Houston area digital library; how do I check it back in?
        • 1. Re: checking books back in?
          Level 4
          The library may - or may not - set up the loan so you can check it in
          early.  If they did, then you can see an option to return the ebook early
          listed in the Item Info for the ebook.  In Library view, click on the small
          arrow next to the ebook name, and a drop-down box will appear.  Pick "Item
          Info" fron the list and you'll see the option.  If the library did not set
          up an early return, don't worry about it: the ebook will expire at the end
          of the loan period and you will see the title, but won't be able to open it
          after that date.
          Hope this helps!
