2 Replies Latest reply on May 7, 2012 9:26 PM by Frustrated in AZ
    help to transfer to SD card
    carolinawoody
      I am using Aluratek ereader. When Itry to transfer a book from Digital editions to the sd card It tells me I am not autorized. it transfers fine to the internal memory. What can I do?
        • 1. Re: help to transfer to SD card
          Jeff A Wright Adobe Employee
          Moving this discussion to the Adobe Digital Editions forum.
          • 2. Re: help to transfer to SD card
            Level 4
            There are a couple of possibilities.  I'm going to make an assumption that,
            when you say you've tried to transfer an ebook to an SD card, you're asking
            Digital Editions to do that.  If this is the case, ADE does not support SD
            cards as a 'transfer device': it's not a supported ereader.  You'd have to
            use your computer's utility programs to copy the ebook to the SD card from
            the ADE library.
            The other possibility is that the ebook has digital rights that do not
            permit the ebook to be copied.  You can check them by looking at the
            ebook's Item Info.  You get there from ADE's Library view by clicking on
            the small arrow next to the ebook title.  A drop-down box will appear, and
            you can select 'Item Info' from the list in the box.  The digital rights
            assigned by the publisher or distributor will indicate whether you can copy
            the ebook or not.
            Hope this helps!
