4 Replies Latest reply on May 7, 2012 1:36 PM by JoshWeiss reTooled
    7D 1920 and 1280 footage mix
    nickflix Level 1
      Hello. If I shoot a film at 1920x1080 24 on the 7D but then need to make a slow motion sequence, can I shoot it at 1280x720 60 and then be able to edit them seamlessly? What are the steps I need to do to mix these? I've heard 1920 30 is just not as nice as 60, but I worry about the different aspect ratios.  What does one do to combine the two and also will there be a quality loss on either one since there's a size difference? Thanks!
        • 1. Re: 7D 1920 and 1280 footage mix
          Harm Millaard Level 7
          Edit everything in 720 format by downrezzing the 1080 format. Far better than uprezzing 720 to 1080. Both 1920x1080 and 1280x720 use the same square PAR.
          • 2. Re: 7D 1920 and 1280 footage mix
            Colin Brougham Level 6
            Sure, it'll work. Just shooting at 60fps isn't enough to recreate a slow-motion sequence, however; you have to interpret the clip as 24fps, which will give you a playback rate of 40% of the original shooting rate. Select the clip in the bin, and go to Modify > Interpret Footage, and set frame rate to 23.976 (not 24...).
            In the sequence, use Scale to Frame Size (right-click on the clip and select this option), or select the clip and go to the ECP and use Motion > Scale to enlarge the clip. Like any enlargement, you'll lose a little quality in the process, but I do this all the time and it looks fine. Sometimes a little bit of the Sharpen filter can bring back some perceived resolution.
            • 3. Re: 7D 1920 and 1280 footage mix
              Jim_Simon Level 8
              You could shoot the whole thing at 720, and use both 24 fps and 60 fps.  Then no scaling anywhere.
              • 4. Re: 7D 1920 and 1280 footage mix
                JoshWeiss reTooled
                As for what to shoot, what is your final deliverable. In other words, is there a client?  Is it for web or tv?  Me personally, I would shoot and finish at 1920x1080 and deal with a little quality loss on the upscale.  But of course that depends of the percentage of footage shot at each frame rate.  The final deliverable.  etc. etc.  So I guess we need more info.
