Locked
Registry problems when installing Flash Player
Apr 09, 2012 Apr 09, 2012
Hi, first of all, sorry for any misspelling, I'm Argentinian . I'm writing here because I've tried a LOT of ways and solutions to install Flash Player for IE, here some facts:
I mostly use Google Chrome, that has the FP already installed, but i have a problem with the ActiveX control, I can install Flash player 11 for windows but Not ActiveX... i read that that's a tool for IE, so i thought i wouldn't be needing it, but when i tried to execute a program (Game Ranger) it said that i needed ActiveX control and that i didn't have it in my computer.. So i started to check for solutions, etc etc. and finally give it up because i just couldn't do it, but well now I started again because I want to know if it's something important to have..
The problem when installing is this: It starts to download Flash Player.. then install it and when it's in 51% it stops and a message appears saying: registry error. this is what happens when I try to install ActiveX, not Flash Player itself because as I said earlier I can install it...
All I want to know is if there's some way to allow Flash Player installation to change registry values.. because i think that's the main problem.. i think. Thank you for reading.
Edit: Forgot to tell information about my system.
OS: Windows 7 32-bits
9.8K
Community Beginner , Apr 11, 2012 Apr 11, 2012
FINALLY FOUND THE SOLUTION!!
This is where I found it > http://forums.adobe.com/message/4086663#4086663
Finally, after 6 months I have installed ActiveX, thanks to that person that fixed it
Anyways, I'm grateful with you guys, I was impressed by the speed that you answered my question, thank you very much.
Advisor ,
Windows
  1. Download the current 32 bit uninstaller
  2. Close all browser windows and run the uninstaller
  3. Restart Windows
  4. Delete all remaining files and folders located in the following directories. (tip: copy and paste these paths into the path bar in a Windows Explorer window)
    • C:\Windows\system32\Macromed\Flash
    • %appdata%\Adobe\Flash Player
    • %appdata%\Macromedia\Flash Player
  5. Verify that the file “FlashPlayerCPLApp.cpl” in C:\Window\system32\ has been deleted
  6. Download the current 32 bit installer
       32 bit Flash Player for ActiveX (Internet Explorer)
  Physically disconnect from the Internet and run the downloaded installer
Apr 10, 2012 Apr 10, 2012
Thanks for the help, I dont have too much time now so I'll try that in a few hours, then I will tell you what happened
To Pat: Thank you!! That's what I wanted to know, that i could not find in any place...
When I finish doing what Carl suggested i will also post that information.
Thanks a lot
Adobe Employee ,
If Carl's steps don't clear this up, you might want to give this FAQ a try in case we're dealing with a registry permission conflict:
How do I fix Windows permission problems with Flash Player?
Tried it. Same error, which is the last one in this page: http://kb2.adobe.com/es/cps/191/tn_19166.html#main_CommonErrors
As Pat said, here's the list all files there are in C:\Windows\system32\Macromed\Flash (after following Carl's instructions)
Flash32_11_2_202_228.ocx
FlashInstall.log
FlashPlayerUpdateService.exe
FlashUtil32_11_2_202_228_ActiveX.dll
FlashUtil32_11_2_202_228_ActiveX.exe
And here are the contents in the FlashInstall.log
=O====== M/11.1.102.62 2012-04-10+00-36-47.662 ========
0000 00000010 "C:\Users\User\Downloads\install_flash_player_ax_32bit (2).exe"
0001 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0002 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0004 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash11f.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11f_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil11f_ActiveX.dll
0008 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0009 00001032 C:\Windows\system32\Macromed\Flash\Flash11f.ocx 80070005
0010 00000018
0011 00001032 C:\Windows\system32\Macromed\Flash\Flash11f.ocx 80070005
=X====== M/11.1.102.62 2012-04-10+00-36-59.750 ========
=O====== M/11.1.102.62 2012-04-10+00-37-02.198 ========
0009 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
0010 00001032 C:\Windows\system32\Macromed\Flash\Flash11f.ocx 80070005
0011 00000018
0012 00001032 C:\Windows\system32\Macromed\Flash\Flash11f.ocx 80070005
=X====== M/11.1.102.62 2012-04-10+00-37-07.486 ========
=O====== M/11.0.1.152 2012-04-10+00-37-09.663 ========
0000 00000010 "C:\Users\User\Downloads\InstallFlashPlayer[11.0.1.152].exe"
0001 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0002 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0003 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0004 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0005 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0006 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0007 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0008 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0009 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0010 00001036 Software\Opera Software/Last CommandLine 2
0011 00001036 Software\Opera Software/Last CommandLine 2
0012 00001036 Software\Opera Software/Plugin Path 2
0013 00001036 Software\Opera Software/Plugin Path 2
0014 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32.dll
0015 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11c_Plugin.exe
0016 00000017 C:\Windows\system32\Macromed\Flash
0017 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0018 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
=X====== M/11.0.1.152 2012-04-10+00-37-16.433 ========
=O====== M/11.1.102.62 2012-04-10+00-37-20.222 ========
0000 00000010 "C:\Users\User\Downloads\uninstall_flash_player_32bit (2).exe" -force
0003 00001018
0005 00001019
0006 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0007 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0008 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0009 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
0010 00001021
0011 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0012 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0013 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0014 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0015 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0016 00001021
0017 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0018 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0019 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0020 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0021 00001036 Software\Opera Software/Last CommandLine 2
0022 00001036 Software\Opera Software/Last CommandLine 2
0023 00001036 Software\Opera Software/Plugin Path 2
0024 00001036 Software\Opera Software/Plugin Path 2
=X====== M/11.1.102.62 2012-04-10+00-37-23.884 ========
=O====== M/11.1.102.62 2012-04-10+00-37-24.761 ========
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0003 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0004 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0006 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash11f.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11f_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil11f_ActiveX.dll
0010 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0012 00000018
0013 00001032 C:\Windows\system32\Macromed\Flash\Flash11f.ocx 80070005
=X====== M/11.1.102.62 2012-04-10+00-37-30.354 ========
=O====== M/11.1.102.62 2012-04-10+00-45-07.183 ========
0011 00000018
=X====== M/11.1.102.62 2012-04-10+00-45-13.035 ========
=O====== M/11.0.1.152 2012-04-10+00-45-15.075 ========
=X====== M/11.0.1.152 2012-04-10+00-45-19.263 ========
=O====== M/11.2.202.228 2012-04-10+00-59-30.619 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/11.2.202.228 2012-04-10+00-59-30.937 ========
=O====== M/11.2.202.228 2012-04-10+00-59-19.313 ========
0000 00000010 "C:\Users\User\AppData\Local\Temp\install_flash_player_ax_32bit.exe" -iv 8 -install -au 0
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_228.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.dll
0010 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0011 00001102
0012 00001106
0013 00001032 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_228.ocx 80070005
0014 00000018
0015 00001032 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_228.ocx 80070005
=X====== M/11.2.202.228 2012-04-10+00-59-31.574 ========
=O====== M/11.0.1.152 2012-04-10+01-04-33.190 ========
0000 00000010 "C:\Windows\System32\Macromed\Flash\FlashUtil11c_Plugin.exe"
=X====== M/11.0.1.152 2012-04-10+01-04-36.613 ========
=O====== M/11.2.202.228 2012-04-10+01-15-19.500 ========
=X====== M/11.2.202.228 2012-04-10+01-15-19.651 ========
=O====== M/11.2.202.228 2012-04-10+01-15-20.228 ========
=X====== M/11.2.202.228 2012-04-10+01-15-20.322 ========
=O====== M/11.2.202.228 2012-04-10+01-15-10.656 ========
0010 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
0011 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0012 00001106
0013 00001106
0014 00001024 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
0016 00000018
0017 00001032 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_228.ocx 80070005
=X====== M/11.2.202.228 2012-04-10+01-15-20.875 ========
=O====== M/11.2.202.228 2012-04-12+00-14-07.450 ========
0000 00000010 "C:\Users\User\Downloads\uninstall_flash_player_32bit (4).exe" -force
0003 00001018
0005 00001019
0010 00001021
0012 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0013 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0014 00001036 Software\Macromedia\FlashPlayerPlugin/isScriptDebugger 2
0015 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0016 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0017 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0018 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0019 00001021
0020 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0021 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0022 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0023 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0024 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
0025 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0026 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0027 00001106
0028 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0029 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0030 00001036 Software\Opera Software/Last CommandLine 2
0031 00001036 Software\Opera Software/Last CommandLine 2
0032 00001036 Software\Opera Software/Plugin Path 2
0033 00001036 Software\Opera Software/Plugin Path 2
=X====== M/11.2.202.228 2012-04-12+00-14-13.543 ========
=O====== M/11.2.202.228 2012-04-12+00-20-50.182 ========
0000 00000010 "C:\Users\User\Downloads\install_flash_player_ax_32bit (1).exe"
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_228.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.dll
0012 00001102
0013 00001106
0014 00001032 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_228.ocx 80070005
0015 00000018
0016 00001032 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_228.ocx 80070005
=X====== M/11.2.202.228 2012-04-12+00-21-31.245 ========
Chris: Thank you too. I will give that a try right now.
Some clarification: ActiveX is part of Internet Explorer, you cannot "install" it.
Flash Player is installed either
  • as an ActiveX Control (for Internet Explorer)
  • or a plugin (for other browsers, like Firefox)
  • or preinstalled in Chrome
If you still have problems after following Carl's instructions above, please
  • list all files you have in C:\Windows\system32\Macromed\Flash
  • post the contents of the FlashInstall.log file in that same folder
Adobe Employee ,
Interesting, the script in the FAQ should have taken care of that for you too.  Did you have to specifically add your username as a user with full access to the folder?  Do you believe that the msi was key in your installation?
If you have a few minutes, I'd like to see what your permissions are so I can try and resolve this for other users.  I've got a script in the following post that outputs the user permissions for these folders and files.  You'd just need to run it once and send me the log.
http://forums.adobe.com/message/4311497#4311497#4311497
I believe that what fixed the problem was the .MSI file, because I then realized that i didn't change any permission (but i thought i did).
So, what i think was more important is the installation via the .msi
I'll run that program and then send the log to your e-mail. Thanks!
Edit: Sorry! I forgot to say that i tried your solution Chris, but it didn't work either
Again thanks for you help
