I've downloaded adobe flash player. it works for a little while then later on or the next time i boot up tells me i need to install adobe flash player to view a web page (like youtube, ect.) i've uninstalled it x15 or more and downloaded it all over again just to have this problem again and again and again. does anyone know why this is happening. nothing else does this, just the flash player. i've also tried installing 32bit instead of 64bit flash player and still the same. any help would be great. thank you.
P.S. I'm running Windows 7 64-bit system. Internet Explorer 9.0.8112.16421
the very latest flash player
Try a clean install, then download the 64-bit offline installer(s) from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#Install_in_a_firewall_proxy_server_environment
Try a clean install, then download the 64-bit offline installer(s) from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#Install_in_a_...
If Pat's steps don't solve this problem, please see the following FAQ:
Pat's solutions seems to have worked. but thank you too for your second solution. i will keep in mind incase i need to try something different. Thank you also for your solution and your time. Have a great day you and everyone at adobe...
Thank you very much. so far so good, seems to be working. i did everything but delete all folders/files the first few times i uninstalled/re-installed. this time i did and seems to have worked. thank you for your help and your time. please have a great day you and the rest of adobe.
