Hello!
I have been using FlashPlayer ActiveX for a very long time without any problems. Now I tried to upgrade to 11.2.202.253 ActiveX and received the fllowing error message:
"A neccesary file (C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX. exe:5) could not be written due to missing access rights
." (I translated this from the orinial german error message, so the original english one might look different).
This happens on Windows 7 32bit Home Premium.
I am logged in with admin-rights (in fact I have tried with three diferent admin account).
The Flashplugin for Firefox installe without any problem.
Here is my flashinstalllog:
=O====== M/11.2.202.235 2012-05-21+13-23-59.004 ========
0000 [I] 00000010 "D:\Users\Public\install_flash_player_ax_32bit.exe"
0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0004 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0005 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0007 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_235.ocx
0008 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.e xe
0009 [E] 00001031 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.e xe:5
0010 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.d ll
0011 [W] 00001026 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.d ll 5
0012 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0013 [W] 00001106
0014 [W] 00001106
=X====== M/11.2.202.235 2012-05-21+13-30-03.038 ========
Any ideas / any help?
It seems that the permission problem is not so much the Admin account, but either the C:\Windows\system32\Macromed\Flash folder, or some of the files that should be overwritten in it.
I suggest that you try the following:
If you still have permission problems after this, try
Hello!
I have followed both instructions and tried to install FlashPlayer again. Unfortuately nothing changed:
while the PlugIn for Firefox/Opera/... installs without any problems, the ActiveX-Installation has the same error message. The OCX-file is placed in the installation directory though, but it is not registered as the installation fails.
I will copy the flashinstall.log of the new installation ans a report recorded by Processmonitor (as CSV). I hope somebody can help!
flashinstall.log:
=O====== M/11.2.202.235 2012-05-22+19-11-05.554 ========
0000 [W] 00001113 C:\Windows\system32\Macromed\Flash\\* 3
0001 [I] 00000010 "D:\Users\root\Desktop\BI\install_flash_player_ax_32bit.exe"
0002 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0004 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0005 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0006 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0007 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0008 [I] 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_235.ocx
0009 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.e xe
0010 [E] 00001031 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.e xe:5
0011 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.d ll
0012 [W] 00001026 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_235_ActiveX.d ll 5
0013 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
=X====== M/11.2.202.235 2012-05-22+19-11-25.990 ========
procmon-report:
"Time of Day","Process Name","PID","Operation","Path","Result","Detail"
"21:14:06,7367309","install_flash_player_ax_32bit.exe","2432","CreateF ile","C:\Windows\Prefetch\INSTALL_FLASH_PLAYER_AX_32BIT-F2B2A34F.pf"," NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Attributes: n/a, ShareMode: None, AllocationSize: n/a"
"21:14:15,5201705","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\Prefetch\INSTALL_FLASH_PLAYER_AX_32BIT-F2B2A34F.pf","N AME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Attributes: n/a, ShareMode: None, AllocationSize: n/a"
"21:14:15,5203269","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Session Manager","REPARSE","Desired Access: Read"
"21:14:15,5253714","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\SafeBoot\Option","REPARSE", "Desired Access: Query Value, Set Value"
"21:14:15,5254022","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\SafeBoot\Option","NAME NOT FOUND","Desired Access: Query Value, Set Value"
"21:14:15,5254355","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Srp\GP\DLL","REPARSE","Desi red Access: Read"
"21:14:15,5254552","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Srp\GP\DLL","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5255371","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Policies\Microsoft\Windows\safer\codeidentifiers \TransparentEnabled","NAME NOT FOUND","Length: 80"
"21:14:15,5255888","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Policies\Microsoft\Windows\Safer\CodeIdentifiers"," NAME NOT FOUND","Desired Access: Query Value"
"21:14:15,5296590","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\sechost.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:15,5330118","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Nls\Sorting\Versions","REPA RSE","Desired Access: Read"
"21:14:15,5331516","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Session Manager","REPARSE","Desired Access: Query Value"
"21:14:15,5331922","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\System\CurrentControlSet\Control\Session Manager\SafeDllSearchMode","NAME NOT FOUND","Length: 16"
"21:14:15,5344344","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\imm32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5356680","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\imm32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5368787","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\imm32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:15,5381259","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Error Message Instrument","REPARSE","Desired Access: Read"
"21:14:15,5381542","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Error Message Instrument","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5382429","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\GRE_Initialize\DisableMetaFiles","NAME NOT FOUND","Length: 20"
"21:14:15,5383506","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Compatibility32\install_flash_player_ax_32bit","NAM E NOT FOUND","Length: 172"
"21:14:15,5383790","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Microsoft\Windows NT\CurrentVersion\IME Compatibility","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5386130","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Control Panel\Desktop\MuiCached\MachineLanguageConfiguration","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5386629","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Policies\Microsoft\MUI\Settings","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5387257","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Policies\Microsoft\Control Panel\Desktop","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5387762","install_flash_player_ax_32bit.exe","624","RegEnumV alue","HKCU\Control Panel\Desktop\LanguageConfiguration","NO MORE ENTRIES","Index: 0, Length: 512"
"21:14:15,5388156","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Policies\Microsoft\MUI\Settings","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5388772","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Policies\Microsoft\Control Panel\Desktop","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5389246","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKCU\Control Panel\Desktop\PreferredUILanguages","NAME NOT FOUND","Length: 12"
"21:14:15,5389918","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Policies\Microsoft\MUI\Settings","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5390743","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKCU\Control Panel\Desktop\MuiCached\MachinePreferredUILanguages","BUFFER OVERFLOW","Length: 12"
"21:14:15,5395873","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Microsoft\Windows NT\CurrentVersion\Diagnostics","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5400904","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Ole\PageAllocatorUseSystemHeap","NAME NOT FOUND","Length: 144"
"21:14:15,5401416","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Ole\PageAllocatorSystemHeapIsPrivate", "NAME NOT FOUND","Length: 144"
"21:14:15,5402167","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Microsoft\OLE\Tracing","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5412889","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Program Files\ThreatFire\TFWAH.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:15,5417403","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Pref erExternalManifest","NAME NOT FOUND","Length: 20"
"21:14:15,5440024","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\OLEAUT","NAME NOT FOUND","Desired Access: Query Value"
"21:14:15,5440633","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\OLEAUT","NAME NOT FOUND","Desired Access: Query Value"
"21:14:15,5446503","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Nls\CustomLocale","REPARSE" ,"Desired Access: Read"
"21:14:15,5447001","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\System\CurrentControlSet\Control\Nls\CustomLocale\de-DE", "NAME NOT FOUND","Length: 532"
"21:14:15,5447266","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Nls\ExtendedLocale","REPARS E","Desired Access: Read"
"21:14:15,5447654","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\System\CurrentControlSet\Control\Nls\ExtendedLocale\de-DE ","NAME NOT FOUND","Length: 532"
"21:14:15,5452797","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\Globalization\Sorting\SortDefault.nls","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5462755","install_flash_player_ax_32bit.exe","624","QueryOpe n","D:\Users\root\Desktop\BI\SspiCli.dll","NAME NOT FOUND",""
"21:14:15,5474666","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\sspicli.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:15,5483257","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Rpc\MaxRpcSize","NAME NOT FOUND","Length: 144"
"21:14:15,5483959","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\ComputerName\ActiveComputer Name","REPARSE","Desired Access: Read"
"21:14:15,5485714","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Policies\Microsoft\Windows NT\Rpc","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5486158","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Policies\Microsoft\SQMClient\Windows","NAME NOT FOUND","Desired Access: Read"
"21:14:15,5499454","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5511476","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\KernelBase.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5520461","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\ntdll.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5532021","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\advapi32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5545416","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5579189","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\user32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5598503","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5619904","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\shell32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5693967","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5710977","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\user32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5724643","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\ntdll.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5740440","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5761163","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\user32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5793206","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5805690","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\ntdll.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5818524","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\advapi32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5837948","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\user32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5858684","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,5890019","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\advapi32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6001102","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6114192","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\advapi32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6136246","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\user32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6167562","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6218573","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\shell32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6275442","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6334201","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\advapi32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6390546","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6447673","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\user32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6492070","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6517511","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\advapi32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6545520","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\user32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6571165","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\kernel32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6666469","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\ParentFolder","NAM E NOT FOUND","Length: 144"
"21:14:15,6666586","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\Description","NAME NOT FOUND","Length: 144"
"21:14:15,6666697","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\RelativePath","NAM E NOT FOUND","Length: 144"
"21:14:15,6666801","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\ParsingName","NAME NOT FOUND","Length: 144"
"21:14:15,6666912","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\InfoTip","NAME NOT FOUND","Length: 144"
"21:14:15,6667017","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\LocalizedName","NA ME NOT FOUND","Length: 144"
"21:14:15,6667122","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\Icon","NAME NOT FOUND","Length: 144"
"21:14:15,6667232","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\Security","NAME NOT FOUND","Length: 144"
"21:14:15,6667337","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\StreamResource","N AME NOT FOUND","Length: 144"
"21:14:15,6667442","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\StreamResourceType ","NAME NOT FOUND","Length: 144"
"21:14:15,6667547","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\LocalRedirectOnly" ,"NAME NOT FOUND","Length: 144"
"21:14:15,6667651","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\Roamable","NAME NOT FOUND","Length: 144"
"21:14:15,6667756","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\PreCreate","NAME NOT FOUND","Length: 144"
"21:14:15,6667861","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\Stream","NAME NOT FOUND","Length: 144"
"21:14:15,6667971","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\PublishExpandedPat h","NAME NOT FOUND","Length: 144"
"21:14:15,6668082","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\Attributes","NAME NOT FOUND","Length: 144"
"21:14:15,6668187","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\FolderTypeID","NAM E NOT FOUND","Length: 144"
"21:14:15,6668292","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{1AC14E77-02E7-4E5D-B744-2EB1AE5198B7}\InitFolderHandler" ,"NAME NOT FOUND","Length: 144"
"21:14:15,6674906","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\KnownFold erSettings","NAME NOT FOUND","Desired Access: Query Value"
"21:14:15,6675263","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\KnownFold erSettings","NAME NOT FOUND","Desired Access: Query Value"
"21:14:15,6685486","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\version.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6696307","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\version.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6707035","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\version.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:15,6753520","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\dwmapi.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6765240","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\dwmapi.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6776221","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\dwmapi.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:15,6823008","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\atl.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6963904","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\atl.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,6974743","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\atl.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:15,7176609","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\ntmarta.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,7491891","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\ntmarta.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,7503377","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\ntmarta.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:15,7530068","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Services\LDAP","REPARSE","Desired Access: Read"
"21:14:15,7531140","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Services\LDAP","REPARSE","Desired Access: Read"
"21:14:15,7531534","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\System\CurrentControlSet\services\ldap\UseOldHostResoluti onOrder","NAME NOT FOUND","Length: 144"
"21:14:15,7531836","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Services\LDAP","REPARSE","Desired Access: Read"
"21:14:15,7532218","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\System\CurrentControlSet\services\ldap\UseHostnameAsAlias ","NAME NOT FOUND","Length: 144"
"21:14:15,7574219","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\winmm.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,7585323","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\winmm.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,7596088","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\winmm.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:15,7644458","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\dsound.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,7856800","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\dsound.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:15,7867737","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\dsound.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:15,9627054","install_flash_player_ax_32bit.exe","624","QueryOpe n","D:\Users\root\Desktop\BI\POWRPROF.dll","NAME NOT FOUND",""
"21:14:15,9644643","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\powrprof.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:15,9809859","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\SourcePat h","NAME NOT FOUND","Length: 144"
"21:14:15,9814379","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\System\CurrentControlSet\Control\WMI\Security\12e1ddac-7e bb-434f-bc58-54c27d745f8f","NAME NOT FOUND","Length: 524"
"21:14:15,9861425","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\d3d9.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,0054878","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\d3d9.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,0066635","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\d3d9.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:16,0074105","install_flash_player_ax_32bit.exe","624","QueryOpe n","D:\Users\root\Desktop\BI\d3d8thk.dll","NAME NOT FOUND",""
"21:14:16,0083756","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\d3d8thk.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:16,2468883","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\GraphicsDrivers\Scheduler", "REPARSE","Desired Access: Query Value"
"21:14:16,2477739","install_flash_player_ax_32bit.exe","624","RegEnumK ey","HKCU\Software\Microsoft\Direct3D","NO MORE ENTRIES","Index: 1, Length: 288"
"21:14:16,2479531","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\Drivers\Size","NAME NOT FOUND","Length: 144"
"21:14:16,2479710","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\Drivers\Name","NAME NOT FOUND","Length: 144"
"21:14:16,2480948","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\DX6TextureEnumInclusionList\S ize","NAME NOT FOUND","Length: 144"
"21:14:16,2481120","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\DX6TextureEnumInclusionList\N ame","NAME NOT FOUND","Length: 144"
"21:14:16,2481668","install_flash_player_ax_32bit.exe","624","RegEnumK ey","HKLM\SOFTWARE\Microsoft\Direct3D","NO MORE ENTRIES","Index: 3, Length: 288"
"21:14:16,2482142","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Microsoft\Direct3D\Drivers","NAME NOT FOUND","Desired Access: Read"
"21:14:16,2483664","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\Drivers\Direct3D HAL\Size","NAME NOT FOUND","Length: 144"
"21:14:16,2483916","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\Drivers\Direct3D HAL\Name","NAME NOT FOUND","Length: 144"
"21:14:16,2485092","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\Drivers\Ramp Emulation\Size","NAME NOT FOUND","Length: 144"
"21:14:16,2485308","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\Drivers\Ramp Emulation\Name","NAME NOT FOUND","Length: 144"
"21:14:16,2486453","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\Drivers\RGB Emulation\Size","NAME NOT FOUND","Length: 144"
"21:14:16,2486675","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\Drivers\RGB Emulation\Name","NAME NOT FOUND","Length: 144"
"21:14:16,2487014","install_flash_player_ax_32bit.exe","624","RegEnumK ey","HKLM\SOFTWARE\Microsoft\Direct3D\Drivers","NO MORE ENTRIES","Index: 3, Length: 288"
"21:14:16,2488024","install_flash_player_ax_32bit.exe","624","RegEnumK ey","HKCU\Software\Microsoft\Direct3D","NO MORE ENTRIES","Index: 1, Length: 288"
"21:14:16,2489471","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\Drivers\Size","NAME NOT FOUND","Length: 144"
"21:14:16,2489644","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\Drivers\Name","NAME NOT FOUND","Length: 144"
"21:14:16,2490684","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\DX6TextureEnumInclusionList\S ize","NAME NOT FOUND","Length: 144"
"21:14:16,2490851","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Direct3D\DX6TextureEnumInclusionList\N ame","NAME NOT FOUND","Length: 144"
"21:14:16,2491393","install_flash_player_ax_32bit.exe","624","RegEnumK ey","HKLM\SOFTWARE\Microsoft\Direct3D","NO MORE ENTRIES","Index: 3, Length: 288"
"21:14:16,2491879","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\System\CurrentControlSet\Control\GraphicsDrivers\Scheduler", "NAME NOT FOUND","Desired Access: Read"
"21:14:16,2492483","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\GraphicsDrivers\Scheduler", "REPARSE","Desired Access: Read"
"21:14:16,2493197","install_flash_player_ax_32bit.exe","624","RegEnumK ey","HKLM\System\CurrentControlSet\Control\GraphicsDrivers\Scheduler", "NO MORE ENTRIES","Index: 0, Length: 288"
"21:14:16,2497366","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Policies\Microsoft\SQMClient\Windows","NAME NOT FOUND","Desired Access: Read"
"21:14:16,2566848","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\mscms.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,3080092","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\mscms.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,3099146","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\mscms.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:16,4712806","install_flash_player_ax_32bit.exe","624","QueryOpe n","D:\Users\root\Desktop\BI\USERENV.dll","NAME NOT FOUND",""
"21:14:16,4735543","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\userenv.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:16,4748778","install_flash_player_ax_32bit.exe","624","QueryOpe n","D:\Users\root\Desktop\BI\profapi.dll","NAME NOT FOUND",""
"21:14:16,4768966","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\profapi.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:16,4836495","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\System\CurrentControlSet\Control\WMI\Security\d53270e3-c8 cf-4707-958a-dad20c90073c","NAME NOT FOUND","Length: 524"
"21:14:16,4908409","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\ieframe.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,4940039","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\ieframe.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,4957911","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\ieframe.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:16,5474013","install_flash_player_ax_32bit.exe","624","QueryOpe n","D:\Users\root\Desktop\BI\OLEACC.dll","NAME NOT FOUND",""
"21:14:16,5490099","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\oleacc.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:16,6833724","install_flash_player_ax_32bit.exe","624","QueryOpe n","D:\Users\root\Desktop\BI\OLEACCRC.DLL","NAME NOT FOUND",""
"21:14:16,6846441","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\oleaccrc.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,7239334","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Pref erExternalManifest","NAME NOT FOUND","Length: 20"
"21:14:16,7247753","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Microsoft\Windows\CurrentVersion\SideBySide\Assembl yStorageRoots","NAME NOT FOUND","Desired Access: Enumerate Sub Keys"
"21:14:16,7249496","install_flash_player_ax_32bit.exe","624","QueryOpe n","D:\Users\root\Desktop\BI\install_flash_player_ax_32bit.exe.Local", "NAME NOT FOUND",""
"21:14:16,7271420","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\winsxs\x86_microsoft.windows.common-controls_65 95b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\comctl32.dll","FIL E LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,7282302","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\winsxs\x86_microsoft.windows.common-controls_65 95b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\comctl32.dll","FIL E LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,7293179","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\winsxs\x86_microsoft.windows.common-controls_65 95b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\comctl32.dll","FIL E LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:16,7315996","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\WindowsShell.Manifest","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,7317517","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Pref erExternalManifest","NAME NOT FOUND","Length: 20"
"21:14:16,7407260","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\oleaccrc.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,7420772","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\oleaccrc.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,7434081","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\oleaccrc.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:16,7488153","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\dbghelp.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,7501530","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\dbghelp.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,7514998","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\dbghelp.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:16,7575205","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\uxtheme.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,7590404","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\uxtheme.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:16,7605049","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\uxtheme.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:16,7745391","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\ParentFolder","NAM E NOT FOUND","Length: 144"
"21:14:16,7745551","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\Description","NAME NOT FOUND","Length: 144"
"21:14:16,7745859","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\ParsingName","NAME NOT FOUND","Length: 144"
"21:14:16,7746001","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\InfoTip","NAME NOT FOUND","Length: 144"
"21:14:16,7746192","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\LocalizedName","NA ME NOT FOUND","Length: 144"
"21:14:16,7746321","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\Icon","NAME NOT FOUND","Length: 144"
"21:14:16,7746450","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\Security","NAME NOT FOUND","Length: 144"
"21:14:16,7746672","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\StreamResource","N AME NOT FOUND","Length: 144"
"21:14:16,7746807","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\StreamResourceType ","NAME NOT FOUND","Length: 144"
"21:14:16,7746937","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\LocalRedirectOnly" ,"NAME NOT FOUND","Length: 144"
"21:14:16,7747078","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\Roamable","NAME NOT FOUND","Length: 144"
"21:14:16,7747208","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\PreCreate","NAME NOT FOUND","Length: 144"
"21:14:16,7747337","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\Stream","NAME NOT FOUND","Length: 144"
"21:14:16,7747466","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\PublishExpandedPat h","NAME NOT FOUND","Length: 144"
"21:14:16,7747602","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\Attributes","NAME NOT FOUND","Length: 144"
"21:14:16,7747737","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\FolderTypeID","NAM E NOT FOUND","Length: 144"
"21:14:16,7747873","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Folder Descriptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\InitFolderHandler" ,"NAME NOT FOUND","Length: 144"
"21:14:16,7748156","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FolderDes criptions\{3EB685DB-65F9-4CF6-A03A-E3EF65729F3D}\PropertyBag","NAME NOT FOUND","Desired Access: Read"
"21:14:16,7750170","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\SessionIn fo\1\KnownFolders","NAME NOT FOUND","Desired Access: Query Value"
"21:14:16,7797665","install_flash_player_ax_32bit.exe","624","QueryOpe n","D:\Users\root\Desktop\BI\CRYPTBASE.dll","NAME NOT FOUND",""
"21:14:16,7807463","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\cryptbase.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:16,8258185","install_flash_player_ax_32bit.exe","624","CreateFi le","D:\Users\root\AppData\Local\Temp\{32BB2EA0-F4EF-439D-8D66-33CF243 C0647}\fpb.tmp","NAME NOT FOUND","Desired Access: Read Attributes, Disposition: Open, Options: , Attributes: N, ShareMode: Read, Write, Delete, AllocationSize: n/a"
"21:14:17,9398281","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","D:\Users\root\AppData\Local\Temp\{32BB2EA0-F4EF-439D-8D66- 33CF243C0647}\fpb.tmp","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:17,9403109","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","D:\Users\root\AppData\Local\Temp\{32BB2EA0-F4EF-439D-8D66- 33CF243C0647}\fpb.tmp","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:17,9452643","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","D:\Users\root\AppData\Local\Temp\{32BB2EA0-F4EF-439D-8D66- 33CF243C0647}\fpb.tmp","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:17,9736184","install_flash_player_ax_32bit.exe","624","CreateFi le","D:\Users\root\AppData\Local\Temp\{89CA96C1-C821-4327-A95A-2A9236E 39AE9}\fpb.tmp","NAME NOT FOUND","Desired Access: Read Attributes, Disposition: Open, Options: , Attributes: N, ShareMode: Read, Write, Delete, AllocationSize: n/a"
"21:14:18,0319784","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","D:\Users\root\AppData\Local\Temp\{89CA96C1-C821-4327-A95A- 2A9236E39AE9}\fpb.tmp","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:18,0324359","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","D:\Users\root\AppData\Local\Temp\{89CA96C1-C821-4327-A95A- 2A9236E39AE9}\fpb.tmp","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:18,0549764","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","D:\Users\root\AppData\Local\Temp\{89CA96C1-C821-4327-A95A- 2A9236E39AE9}\fpb.tmp","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:18,0560763","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Pref erExternalManifest","NAME NOT FOUND","Length: 20"
"21:14:18,0601015","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SYSTEM\CurrentControlSet\Services\crypt32","REPARSE","Desire d Access: Read"
"21:14:18,0601607","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\System\CurrentControlSet\services\crypt32\DebugHeapFlags" ,"NAME NOT FOUND","Length: 144"
"21:14:18,0644415","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\wininet.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:18,0685788","install_flash_player_ax_32bit.exe","624","QueryDir ectory","C:\Windows\System32\Macromed\Flash","NO MORE FILES",""
"21:14:18,0688467","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKCU\Software\Macromedia\FlashPlayer\RerunInUIMode","NAME NOT FOUND","Length: 144"
"21:14:18,0690888","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\mms.cfg","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:18,0693622","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\mms.cfg","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:18,0696535","install_flash_player_ax_32bit.exe","624","RegDelet eValue","HKCU\Software\Macromedia\FlashPlayer\ConflictingProcs","NAME NOT FOUND",""
"21:14:18,0709314","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\msimg32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:18,0720923","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\msimg32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:18,0732612","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\msimg32.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:18,0805640","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\CTF\Compatibility\install_flash_player_ax _32bit.exe","NAME NOT FOUND","Desired Access: Read"
"21:14:18,0817859","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\rpcss.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:18,0829443","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\rpcss.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:18,0839500","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\CTF\EnableAnchorContext","NAME NOT FOUND","Length: 144"
"21:14:18,0841015","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\CTF\KnownClasses","NAME NOT FOUND","Desired Access: Read"
"21:14:18,0870299","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Microsoft\Windows\CurrentVersion\SideBySide\Assembl yStorageRoots","NAME NOT FOUND","Desired Access: Enumerate Sub Keys"
"21:14:18,0872738","install_flash_player_ax_32bit.exe","624","QueryOpe n","D:\Users\root\Desktop\BI\install_flash_player_ax_32bit.exe.Local", "NAME NOT FOUND",""
"21:14:18,0904486","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Nls\Locale","REPARSE","Desi red Access: Read"
"21:14:18,0905175","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Nls\Locale\Alternate Sorts","REPARSE","Desired Access: Read"
"21:14:18,0905600","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Nls\Language Groups","REPARSE","Desired Access: Read"
"21:14:18,0914438","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Macromedia\FlashPlayer\SafeVersions","NAME NOT FOUND","Desired Access: Read"
"21:14:18,1106321","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontSubstitutes\Tahoma","NAME NOT FOUND","Length: 144"
"21:14:18,1118884","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\DataStore_V1.0\Disable","NAME NOT FOUND","Length: 144"
"21:14:18,1125105","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\Fonts\StaticCache.dat","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:18,1223371","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane1","NAME NOT FOUND","Length: 144"
"21:14:18,1224018","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane3","NAME NOT FOUND","Length: 144"
"21:14:18,1224209","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane4","NAME NOT FOUND","Length: 144"
"21:14:18,1224387","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane5","NAME NOT FOUND","Length: 144"
"21:14:18,1224578","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane6","NAME NOT FOUND","Length: 144"
"21:14:18,1224757","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane7","NAME NOT FOUND","Length: 144"
"21:14:18,1224941","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane8","NAME NOT FOUND","Length: 144"
"21:14:18,1225126","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane9","NAME NOT FOUND","Length: 144"
"21:14:18,1225317","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane10","NAME NOT FOUND","Length: 144"
"21:14:18,1225508","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane11","NAME NOT FOUND","Length: 144"
"21:14:18,1225693","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane12","NAME NOT FOUND","Length: 144"
"21:14:18,1225878","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane13","NAME NOT FOUND","Length: 144"
"21:14:18,1226068","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane14","NAME NOT FOUND","Length: 144"
"21:14:18,1226253","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane15","NAME NOT FOUND","Length: 144"
"21:14:18,1226438","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Plane16","NAME NOT FOUND","Length: 144"
"21:14:18,1229025","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Arial","NAME NOT FOUND","Desired Access: Query Value"
"21:14:18,1264670","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\LanguagePack\SurrogateFallback\Arial","NAME NOT FOUND","Desired Access: Query Value"
"21:14:24,6560929","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Macromedia\FlashPlayerActiveX","NAME NOT FOUND","Desired Access: Read"
"21:14:24,6600652","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\CTF\KnownClasses","NAME NOT FOUND","Desired Access: Read"
"21:14:26,1173517","install_flash_player_ax_32bit.exe","624","RegDelet eValue","HKCU\Software\Macromedia\FlashPlayer\ConflictingProcs","NAME NOT FOUND",""
"21:14:26,1175753","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Macromedia\FlashPlayer\SafeVersions","NAME NOT FOUND","Desired Access: Read"
"21:14:26,1191975","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Macromedia\FlashPlayerActiveX","NAME NOT FOUND","Desired Access: Read"
"21:14:26,1231229","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\FlashPlayerCPLApp.cpl","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1233268","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{D27CDB6E-AE6D-11CF-96B8-444553540000}\InprocServer32" ,"NAME NOT FOUND","Desired Access: Read"
"21:14:26,1234155","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{A483C63A-CDBC-426E-BF93-872502E8144E}\LocalServer32", "NAME NOT FOUND","Desired Access: Read"
"21:14:26,1234764","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{19114156-8E9A-4D4E-9EE9-17A0E48D3BBB}\LocalServer32", "NAME NOT FOUND","Desired Access: Read"
"21:14:26,1235466","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{0BE09CC1-42E0-11DD-AE16-0800200C9A66}\LocalServer32", "NAME NOT FOUND","Desired Access: Read"
"21:14:26,1236969","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{D4304BCF-B8E9-4B35-BEA0-DC5B522670C2}\LocalServer32", "NAME NOT FOUND","Desired Access: Read"
"21:14:26,1238681","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX","NAME NOT FOUND","Desired Access: Read/Write, Delete"
"21:14:26,1239660","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{cdf0cc6 4-4741-4e43-bf97-fef8fa1d6f1c}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1240683","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1ae3b44 2-f6e5-49a0-bf8b-0e8d56d7d450}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1241545","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{436EE5F 2-71F0-4738-B8E7-93741EF4828F}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1242383","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0B575FB 2-30B1-48F2-80A3-977638C2D6BA}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1243208","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{F180E59 9-CC04-4971-8140-3F71F95D7944}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1244021","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9600BCE 2-9DEF-4930-ABF7-FB68ED538BF7}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1244852","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0A28C61 0-EE06-4A33-BB56-A2155B524916}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1245665","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0CB2ABF 4-BB8D-4F87-9223-50F106B50D95}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1246490","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{6815FCD D-401D-481E-BA88-31B4754C2B46}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1247297","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{885A63E A-382B-4DD4-A755-14809B8557D6}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1248122","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5E8A1B0 8-0FBD-4543-9646-F2C2D0D05750}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1248941","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CD5C7EB 6-937A-4E39-B847-A8A50568EE9B}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1249761","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E859056 4-FD80-4864-B219-619BD4B3EB83}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1250573","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E67FAA8 D-58E0-433C-833C-6647CDB14AB0}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1251393","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{F7BE8C6 6-4DFF-4480-A9B6-410E6FE4D399}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1252212","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0B99136 5-EB79-40B3-92AE-5E09B4008553}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1253025","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B0D584D C-3B46-4F6C-B9C3-BDC61304D3CD}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1253924","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{2927FFE 6-25C2-4C86-B93C-EDEEA97B7CB7}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1254743","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{6D7EE95 D-ADFB-4454-B28B-FAC56F84F186}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1255562","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{8A90EC4 9-E132-4AA5-BF74-A18CC3C6DF6D}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1256375","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{00C10AC 2-32C3-4281-B8EB-011E00B5AE20}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1257188","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{2BBA59A E-9246-4348-8BB8-54EA1182817B}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1258007","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A370392 2-84E3-4318-B0A1-04EFAD449A04}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1258820","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{8A7DC98 2-6A96-4C3C-BBE1-D5025CD85AF5}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1259639","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{BB65C39 3-C76E-4F06-9B0C-2124AA8AF97B}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1260464","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{116E6EE C-0CBA-460E-8DEB-55CFF8E28C7D}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1261289","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{685A56F 8-75B6-44AD-B3DA-FB0A3266B47C}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1262102","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{D26FEB2 1-3495-401F-9046-0A39050A9324}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1262915","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{8186E1B 9-DDC6-45B6-B9EB-C28947CBC4CF}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1263741","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{6EB45C7 0-7B6E-456C-8C23-58A8409C0E3D}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1264553","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{BC4F8E8 4-5E29-49EC-B4E7-E6F9CB50986C}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1265366","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{786547F 9-59BB-4FA3-B2D8-327FF1F14870}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1266179","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3420E72 4-6DDB-49C2-BA39-165F543C147C}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1266992","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{8E9DB7E F-5DD3-499E-BA2A-A1F3153A4DF8}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1267817","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0A621EC 5-B98B-45C9-95FE-A7D0DA3150EA}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1268637","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{58BAA8D 0-404E-4585-9FD3-ED1BB72AC2EE}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1269450","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{483CFBD B-5870-41ED-82DC-992D1A2CBA87}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1270262","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{74B3FB8 A-2A0F-4CEA-84FD-12C9B03EE377}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1271082","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{693E05C 4-15CF-4EC4-8298-AFCC049F4B94}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1271901","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{6FEFB72 4-6655-492B-9D10-00F530FC39D3}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1272707","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{41FA409 9-8AAA-495C-B1F0-E0447F9F4A93}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1273526","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9BA8B44 1-9E83-4307-A582-03EC9A456C72}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1274333","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{03E99F0 B-3A02-4821-BD44-70D4463F897B}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1275146","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{BB79ADD E-9369-44C4-84DB-221C853ABEDC}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1275959","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B4D7921 6-306A-400B-858B-00C05F0B0E80}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1276778","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C64CF7F 5-92A0-4615-AA2D-A1237AD3F332}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1277597","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{211986F D-3BB6-4B0D-8AAF-C22A6DBC7E36}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1278416","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{4FB5B08 2-6906-4764-9486-332393B33C9F}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1279235","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{7EC95A1 0-14F2-496A-99FA-772454E44566}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1280135","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{2CB8838 8-9DFB-46f7-B7F1-862EB29A6FAB}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1280954","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{17EDE3E 8-7AF0-4c54-B6E7-0CA4129E9C21}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1281767","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3A6829E F-0791-4FDD-9382-C690DD0821B9}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1282580","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{685A56F 8-75B6-44AD-B3DA-FB0A3266B47C}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1283393","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{2BD2FA2 1-B51D-4F01-94A7-AC16737B2163}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1284205","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A19AA51 E-C145-4323-947E-D0D71EC84E47}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1285006","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{922E852 5-AC7E-4294-ACAA-43712D4423C0}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1285819","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CECF750 0-69B8-4EEE-9A5F-8D2FC2625760}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1286632","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B7B3E9B 3-FB14-4927-894B-E9124509AF5A}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1287439","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{AFCD87D 7-46F9-4923-84F0-987F12D0C28C}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1288252","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{2476201 2-C6C8-4AAD-A02D-71A009FA1683}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1289065","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{D4B2F65 8-FCCC-4C50-952B-A8A5E5BC110F}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1289878","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{66E3BA0 0-6B3D-466B-96FA-6309A7F42BB0}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1290690","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{20B3FD5 B-A987-406B-A5B5-CDE3CA1EF4E1}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1291503","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{6E9EF98 E-259E-416D-B5F8-0ABDB99942CE}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1292322","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{EFB786F D-D916-416B-A23A-1EBEAF4A9DDC}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1293160","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FFB768E 4-E427-4553-BC36-A11F5E62A94D}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1293979","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{95A0B13 E-F09A-425F-9D5F-E7C5EC470D06}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1294811","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{406A89D 6-09E6-4550-B370-8D376DDB56BE}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1295623","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{03A3CDE E-94D7-49c1-B373-D342653A22E8}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1296443","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{95468B0 0-C081-4B27-AC96-0A2A31359E60}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1297268","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C6C0E5B 3-19B9-45D4-B76A-177F500A276C}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1298087","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{148D9D0 3-5D23-4D4F-B5D0-BA6030C45DCF}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1298906","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{65EAFCC B-4057-4184-9145-137DED9E0144}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1299725","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E5D03B2 E-B2D4-477F-A60D-8E1969D821FA}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1300563","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{87AE8A8 F-6040-42B5-A7E5-644B1EA70163}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1301388","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{18BBF24 A-6D04-4CA4-B6B4-1CF372162EEC}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1302213","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{37C8015 8-721A-440E-8102-8C5B71BFE2DE}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1303038","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B001064 C-D061-4BAE-9031-416A838D5536}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1303858","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FFE0758 1-220F-47B7-8EDE-26059EF9FB26}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1304689","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FA1D674 2-0515-4A94-AD5D-F0484026E4A2}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1305600","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9A80D7E 7-4C48-484E-9C16-F4E300366F1D}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1306524","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{DCC90D9 D-4F8D-4A06-9050-ADDB284FF9FA}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1307368","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{23885D9 8-F1AF-4579-81FB-C57CA71B7E89}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1308199","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A6FD09C 6-E363-4986-8ABD-2165B4485EEC}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1309025","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{397B615 E-7442-4BEA-8098-61BBCF703C74}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1309850","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{88D881E F-0567-443A-9A84-E5AAEF29BB34}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1310675","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{04F9616 D-BEB9-40DD-88EA-0D404F67C775}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1311500","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0483BE0 7-260D-4E4D-815E-F737C0A72E40}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1312326","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{332FDA1 D-0B1E-460C-9961-65515CADB9B7}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1313151","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{48DB591 4-8772-472D-B8DF-E2092BE598F6}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1313976","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{EA5AFEE 8-17F9-4DC6-AB10-A41C34A35893}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1314801","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{72D4DD4 C-0749-4352-B63E-7A7C9286430E}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1315620","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A3F073D B-01A6-4e24-A0F5-950EAB651355}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1316446","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{DB093E0 B-0934-4183-BA60-5C1ADC9F6424}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1317277","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C0D8060 A-8E3B-458c-9434-FBBE04F823D3}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1318108","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E24A001 5-C73F-4B57-B8DF-5EB84D2E9685}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1318940","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{39BCE53 F-F8C8-4545-A5D8-F210E7608360}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1319759","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{54DAAD1 6-A57A-4524-9C4F-391500945D14}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1320584","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A437E1A 3-F0AA-4EA2-8E43-845DDC2221D1}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1321409","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{36B194F 6-D57F-4E58-B99D-9A4565356A66}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1322229","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E84F69A 8-5357-4C1F-B8AA-63919FA0BDA6}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1323060","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FEE2740 C-D52A-4C76-8857-335E35AB7037}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1323879","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{1D424BA A-E25C-456C-B502-0B9C9F164BDE}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1324710","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{212719F 5-89EE-4B3A-A8EB-121D931E5547}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1325536","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{AB36B93 A-7B6A-4693-99DE-95143819EE78}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1326367","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{2B2D7C9 F-F652-4C9C-86AD-7298D2989D88}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1327186","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{DA69776 C-A93F-4077-8874-25DF521EAA8A}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1328018","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{23D7973 0-EC1A-435E-83F8-AAEBFE5237B0}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1328837","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{726D93B 8-C973-4C5B-881B-96FBDE459D39}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1329662","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{A10EE46 B-C2E8-4FAB-A8F8-3E80D0662BA9}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1330487","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{6C119C5 2-528E-4115-A05D-E78893FB01F6}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1331312","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{4278B78 0-6CB5-437A-BA6A-31C7F9FAB980}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1332230","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{DBC42D8 0-FE3F-4F45-91EA-972F0EDC8603}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1333055","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{421976B 6-DEC6-4CA5-941F-F0663B3A2B74}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1333874","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C2840D4 B-5DD8-4813-A9D8-C2B72E821226}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1334687","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{D0F112B B-7902-43AC-AF50-4D1117C9152E}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1335500","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B88C181 E-D594-4A3C-9767-07E4794234D6}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1336307","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{62DD0E8 5-7A25-47A4-8F0F-95D749F9F102}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1337132","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{7DBA4E0 E-C43E-4BD8-859E-DA4E8284473E}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1337951","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{8D7DDFA 2-3A50-49A4-99C5-6D8BE66FE0B9}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1338771","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{3D093B2 E-1E39-4097-A0EF-C70351A16CA6}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1339590","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E7C06D2 9-B16A-4D88-A917-55422FAB4E9D}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1340409","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{82833D1 3-CE67-4DD9-A270-30265F12DCB7}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1341228","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{90790D5 D-80D8-4C7E-8BDC-23DBB8C6AEC7}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1342047","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{CF72288 2-1ED7-4FB9-B98A-589544A15F40}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1342866","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{D3F3D07 F-4B4F-440B-9DC9-355848A8103C}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1343673","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{14190A5 1-2712-42C1-B7DB-011ABEAF33E2}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1344492","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{5C804EB B-475F-4555-A225-1D6573F158BD}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1345311","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{E3C99F7 A-60C3-40C4-BC9D-FB6B0C2F2671}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1346130","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{8DB09D2 5-8E79-4F23-854D-02B95062A5B2}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1346949","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{94B87B2 6-B746-4AEA-B301-4AB281AF3B7A}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1347768","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9E25236 A-E313-4853-9C8C-DB7015E9F9C4}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1348587","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0EF1265 8-CB6B-4A73-923D-2CABE04976A6}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1349413","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{6B393C3 2-A8CE-4663-9D5B-EA75C8D1233C}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1350232","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{853E933 0-9717-4504-BDA2-BB8743D458DD}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,1355011","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashPlayerCPLApp.cpl","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1358835","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\uninstall_activeX.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1362358","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1365825","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash6.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1369391","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash6a.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1372840","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash7.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1376276","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg7.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1379731","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash7a.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1383272","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg7a.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1386734","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash7b.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1390170","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg7b.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1393680","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash7c.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1397098","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg7c.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1400535","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash7d.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1403990","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg7d.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1407513","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash8.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1410912","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg8.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1414343","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash8a.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1417859","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg8a.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1421308","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash8b.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1424757","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg8b.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1428212","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash8c.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1431734","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg8c.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1435140","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash8d.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1438761","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg8d.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1442216","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash8e.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1445985","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg8e.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1449440","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash8f.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1452883","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg8f.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1456387","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash8g.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1459885","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg8g.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1463741","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1467035","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1469228","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9a.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1471328","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9a.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1473422","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9b.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1475565","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9b.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1477634","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9c.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1479710","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9c.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1481828","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9d.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1483953","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9d.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1486022","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9e.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1488098","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9e.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1490253","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9f.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1492304","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9f.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1494392","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9g.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1496467","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9g.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1498758","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9h.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1500821","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9h.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1502891","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9i.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1505021","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9i.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1507103","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9j.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1509172","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9j.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1511260","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9k.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1513397","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9k.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1515466","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9l.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1517536","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9l.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1519765","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9m.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1521908","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9m.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1524113","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9n.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1526244","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9n.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1528424","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash9o.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1530530","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg9o.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1532661","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1534786","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg10.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1537015","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10a.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1539171","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg10a.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1541425","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10b.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1543587","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg10b.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1545656","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10c.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1547756","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg10c.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1549825","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10d.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1551938","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg10d.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1554062","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10e.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1556144","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlDbg10e.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1558293","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10f.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1560344","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10g.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1562407","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10h.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1564489","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10i.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1566737","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10j.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1568800","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10k.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1570844","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10l.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1572994","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10m.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1575069","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10n.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1577145","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10o.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1579319","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10p.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1581696","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10q.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1583876","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10r.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1586309","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10s.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1588563","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10t.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1590903","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10u.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1593311","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10v.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1595528","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10w.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1597881","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10x.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1600178","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10y.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1602395","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10z.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1604674","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10za.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1607051","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10zb.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1609465","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10zc.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1611744","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash10zd.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1614041","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash11a.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1616332","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash11b.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1618684","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash11c.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1620827","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash11d.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1623211","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash11e.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1625465","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash11f.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1627664","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash11g.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1629745","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash11h.ocx","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1632024","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\GetFlash.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1634376","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\GetFlash.exe.manifest","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1636692","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\UninstFl.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1638940","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9a.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1641292","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9b.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1643602","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9c.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1645911","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9d.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1648184","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9e.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1651528","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9f.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1653714","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9g.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1655765","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9h.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1657822","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9i.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1659916","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9j.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1661973","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9k.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1664024","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9l.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1666068","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9m.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1668156","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9n.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1670195","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil9o.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1672239","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1674444","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10a.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1676489","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10b.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1678644","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10c.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1680831","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10d.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1682992","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10e.dll","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1685031","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10e.exe","NAME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1687088","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10e_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1689182","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10e_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1691214","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10f_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1693259","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10f_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1695309","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10g_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1697403","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10g_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1699454","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10h_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1701567","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10h_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1703654","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10i_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1705693","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10i_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1707731","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10j_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1709776","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10j_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1711870","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10k_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1713902","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10k_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1715947","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10l_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1717985","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10l_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1720061","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10m_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1722099","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10m_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1724138","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10n_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1726232","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10n_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1728264","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10o_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1730302","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10o_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1732347","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10p_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1734503","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10p_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1736541","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10q_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1738586","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10q_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1740674","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10r_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1742712","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10r_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1744757","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10s_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1746807","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10s_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1748895","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10t_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1750928","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10t_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1752978","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10u_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1755066","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10u_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1757105","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10v_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1759143","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10v_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1761188","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10w_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1763312","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10w_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1765511","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10x_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1767550","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10x_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1769631","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10y_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1771676","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10y_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1773708","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10z_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1775913","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10z_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1778007","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10za_ActiveX.dll","NA ME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1780045","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10za_ActiveX.exe","NA ME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1782084","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10zb_ActiveX.dll","NA ME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1784172","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10zb_ActiveX.exe","NA ME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1786210","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10zc_ActiveX.dll","NA ME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1788292","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10zc_ActiveX.exe","NA ME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1790330","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10zd_ActiveX.dll","NA ME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1792418","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil10zd_ActiveX.exe","NA ME NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1794450","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11a_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1796483","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11a_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1798527","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11b_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1800597","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11b_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1802629","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11c_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1804667","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11c_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1806749","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11d_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1808781","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11d_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1810820","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11e_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1812858","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11e_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1814946","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11f_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1816978","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11f_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1819017","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11g_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1821172","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11g_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1823199","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11h_ActiveX.dll","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1825243","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\FlashUtil11h_ActiveX.exe","NAM E NOT FOUND","Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, AllocationSize: n/a"
"21:14:26,1826635","install_flash_player_ax_32bit.exe","624","RegDelet eValue","HKCU\Software\Macromedia\FlashPlayer\RerunInUIMode","NAME NOT FOUND",""
"21:14:26,1835306","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\LSA\AccessProviders","REPAR SE","Desired Access: Read"
"21:14:26,1838749","install_flash_player_ax_32bit.exe","624","QuerySec urityFile","C:\Windows\System32\Macromed\Flash\Flash32_11_2_202_235.oc x","BUFFER OVERFLOW","Information: DACL"
"21:14:26,1845751","install_flash_player_ax_32bit.exe","624","QuerySec urityFile","C:\Windows\System32\Macromed\Flash","BUFFER OVERFLOW","Information: DACL"
"21:14:26,1846749","install_flash_player_ax_32bit.exe","624","QuerySec urityFile","C:\Windows\System32\Macromed\Flash\Flash32_11_2_202_235.oc x","BUFFER OVERFLOW","Information: Owner, Group, DACL"
"21:14:26,1850598","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{D27CDB6E-AE6D-11CF-96B8-444553540000}","NAME NOT FOUND","Desired Access: Query Value, Enumerate Sub Keys, Read Control"
"21:14:26,1851195","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{D27CDB6E-AE6D-11CF-96B8-444553540000}","NAME NOT FOUND","Desired Access: Read Control"
"21:14:26,1851645","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{D27CDB70-AE6D-11CF-96B8-444553540000}","NAME NOT FOUND","Desired Access: Query Value, Enumerate Sub Keys, Read Control"
"21:14:26,1852027","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{D27CDB70-AE6D-11CF-96B8-444553540000}","NAME NOT FOUND","Desired Access: Read Control"
"21:14:26,1852489","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\TypeLib\{D27CDB6B-AE6D-11CF-96B8-444553540000}","NAME NOT FOUND","Desired Access: Query Value, Enumerate Sub Keys, Read Control"
"21:14:26,1852969","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\TypeLib\{D27CDB6B-AE6D-11CF-96B8-444553540000}","NAME NOT FOUND","Desired Access: Read Control"
"21:14:26,1860809","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\Macromed\Flash\Flash32_11_2_202_235.oc x","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:26,2171787","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\Macromed\Flash\Flash32_11_2_202_235.oc x","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:26,2183636","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\Macromed\Flash\Flash32_11_2_202_235.oc x","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:26,2800954","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Pref erExternalManifest","NAME NOT FOUND","Length: 20"
"21:14:26,5514007","install_flash_player_ax_32bit.exe","624","RegDelet eValue","HKLM\SOFTWARE\Macromedia\FlashPlayer\CurrentVersion","NAME NOT FOUND",""
"21:14:26,5516236","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MacromediaFlashPaper.MacromediaFlashPaper\s hell\open\command","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,5516686","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\MacromediaFlashPaper.MacromediaFlashPaper\shell\open\command ","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,5517622","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MacromediaFlashPaper.MacromediaFlashPaper\s hell\open","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,5517985","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\MacromediaFlashPaper.MacromediaFlashPaper\shell\open","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,5518977","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MacromediaFlashPaper.MacromediaFlashPaper\s hell","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,5519328","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\MacromediaFlashPaper.MacromediaFlashPaper\shell","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,5520202","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MacromediaFlashPaper.MacromediaFlashPaper\D efaultIcon","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,5520677","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\MacromediaFlashPaper.MacromediaFlashPaper\DefaultIcon","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,5522044","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\Interface\{57a0e747-3863-4d20-a811-950c84f1 db9b}\TypeLib","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5522555","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\Interface\{57a0e747-3863-4d20-a811-950c84f1db9b}\TypeLib","N AME NOT FOUND","Desired Access: Read"
"21:14:26,5523781","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\TypeLib\{57a0e746-3863-4d20-a811-950c84f1db 9b}\0.0\0\win32","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5524156","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\TypeLib\{57a0e746-3863-4d20-a811-950c84f1db9b}\0.0\0\win32", "NAME NOT FOUND","Desired Access: Read"
"21:14:26,5712067","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MacromediaFlashPaper.MacromediaFlashPaper", "NAME NOT FOUND","Desired Access: Read"
"21:14:26,5712418","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\MacromediaFlashPaper.MacromediaFlashPaper","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5713336","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\FlashFactory.FlashFactory.1","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5713570","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\FlashFactory.FlashFactory.1","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5714247","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\ShockwaveFlash.ShockwaveFlash.1","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5714475","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\ShockwaveFlash.ShockwaveFlash.1","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5715103","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\FlashFactory.FlashFactory","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5715319","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\FlashFactory.FlashFactory","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5715971","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\ShockwaveFlash.ShockwaveFlash.3","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5716187","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\ShockwaveFlash.ShockwaveFlash.3","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5716784","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\ShockwaveFlash.ShockwaveFlash.4","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5716994","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\ShockwaveFlash.ShockwaveFlash.4","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5717591","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\ShockwaveFlash.ShockwaveFlash.5","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5717807","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\ShockwaveFlash.ShockwaveFlash.5","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5718410","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\ShockwaveFlash.ShockwaveFlash.6","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5718620","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\ShockwaveFlash.ShockwaveFlash.6","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5719211","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\ShockwaveFlash.ShockwaveFlash.7","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5719426","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\ShockwaveFlash.ShockwaveFlash.7","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5720018","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\ShockwaveFlash.ShockwaveFlash.8","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5720233","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\ShockwaveFlash.ShockwaveFlash.8","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5720868","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\ShockwaveFlash.ShockwaveFlash.9","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5721083","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\ShockwaveFlash.ShockwaveFlash.9","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5721687","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\ShockwaveFlash.ShockwaveFlash.10","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5721902","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\ShockwaveFlash.ShockwaveFlash.10","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5722500","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\ShockwaveFlash.ShockwaveFlash.11","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5722709","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\ShockwaveFlash.ShockwaveFlash.11","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5723306","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\ShockwaveFlash.ShockwaveFlash","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5723522","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\ShockwaveFlash.ShockwaveFlash","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5724803","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000 }","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5725037","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5727463","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000 }","NAME NOT FOUND","Desired Access: Read"
"21:14:26,5727685","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}","NAME NOT FOUND","Desired Access: Read"
"21:14:26,6337280","install_flash_player_ax_32bit.exe","624","RegEnumK ey","HKCU\Software\Classes\CLSID","NO MORE ENTRIES","Index: 372, Length: 288"
"21:14:26,6436138","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\.spl","NAME NOT FOUND","Desired Access: Read"
"21:14:26,6436452","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\.spl","NAME NOT FOUND","Desired Access: Read"
"21:14:26,6437283","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\.swf","NAME NOT FOUND","Desired Access: Read"
"21:14:26,6438392","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\.swf","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,6438946","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\.mfp","NAME NOT FOUND","Desired Access: Read"
"21:14:26,6439149","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\.mfp","NAME NOT FOUND","Desired Access: Read"
"21:14:26,6439759","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\.sol","NAME NOT FOUND","Desired Access: Read"
"21:14:26,6440609","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\.sol","NAME NOT FOUND","Desired Access: Write"
"21:14:26,6441533","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\.sol","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,6442038","install_flash_player_ax_32bit.exe","624","RegDelet eValue","HKCR\.sol\Content Type","NAME NOT FOUND",""
"21:14:26,6442771","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\.sol","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,6443312","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\.sor","NAME NOT FOUND","Desired Access: Read"
"21:14:26,6444162","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\.sor","NAME NOT FOUND","Desired Access: Write"
"21:14:26,6444791","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\.sor","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,6445055","install_flash_player_ax_32bit.exe","624","RegDelet eValue","HKCR\.sor\Content Type","NAME NOT FOUND",""
"21:14:26,6445665","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\.sor","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,6447802","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MIME\Database\Content Type\application/futuresplash","NAME NOT FOUND","Desired Access: Read"
"21:14:26,6449145","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MIME\Database\Content Type\application/futuresplash","NAME NOT FOUND","Desired Access: Write"
"21:14:26,6449865","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MIME\Database\Content Type\application/futuresplash","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,6450142","install_flash_player_ax_32bit.exe","624","RegDelet eValue","HKCR\MIME\Database\Content Type\application/futuresplash\CLSID","NAME NOT FOUND",""
"21:14:26,6450814","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MIME\Database\Content Type\application/futuresplash","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,6451374","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MIME\Database\Content Type\application/x-shockwave-flash","NAME NOT FOUND","Desired Access: Read"
"21:14:26,6452249","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MIME\Database\Content Type\application/x-shockwave-flash","NAME NOT FOUND","Desired Access: Write"
"21:14:26,6452895","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MIME\Database\Content Type\application/x-shockwave-flash","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,6453154","install_flash_player_ax_32bit.exe","624","RegDelet eValue","HKCR\MIME\Database\Content Type\application/x-shockwave-flash\CLSID","NAME NOT FOUND",""
"21:14:26,6453924","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Classes\MIME\Database\Content Type\application/x-shockwave-flash","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,6458142","install_flash_player_ax_32bit.exe","624","RegEnumK ey","HKCU\Software\Classes\MIME\Database","NO MORE ENTRIES","Index: 1, Length: 288"
"21:14:26,6460335","install_flash_player_ax_32bit.exe","624","RegEnumK ey","HKCU\Software\Classes\MIME","NO MORE ENTRIES","Index: 1, Length: 288"
"21:14:26,6463032","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Internet Explorer\ActiveX Compatibility\{D27CDB70-AE6D-11cf-96B8-444553540000}","NAME NOT FOUND","Desired Access: Read"
"21:14:26,6820175","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\Macromed\Flash\Flash32_11_2_202_235.oc x","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:26,6888683","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\TypeLib\{D27CDB6B-AE6D-11CF-96B8-444553540000}","NAME NOT FOUND","Desired Access: Maximum Allowed"
"21:14:26,7313748","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{D27CDB6E-AE6D-11CF-96B8-444553540000}","NAME NOT FOUND","Desired Access: Read/Write, Delete"
"21:14:26,7314567","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\CLSID\{D27CDB70-AE6D-11CF-96B8-444553540000}","NAME NOT FOUND","Desired Access: Read/Write, Delete"
"21:14:26,7315165","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCR\TypeLib\{D27CDB6B-AE6D-11CF-96B8-444553540000}","NAME NOT FOUND","Desired Access: Read/Write, Delete"
"21:14:26,7315694","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Shockwav eFlash","NAME NOT FOUND","Desired Access: Read/Write, Delete"
"21:14:26,7348273","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash","NAME COLLISION","Desired Access: Read Data/List Directory, Synchronize, Disposition: Create, Options: Directory, Synchronous IO Non-Alert, Open Reparse Point, Attributes: N, ShareMode: Read, Write, AllocationSize: 0"
"21:14:27,3194376","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash\Flash32_11_2_202_235.ocx","NAM E NOT FOUND","Desired Access: Read Attributes, Disposition: Open, Options: , Attributes: N, ShareMode: Read, Write, Delete, AllocationSize: n/a"
"21:14:27,5110343","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash","NAME COLLISION","Desired Access: Read Data/List Directory, Synchronize, Disposition: Create, Options: Directory, Synchronous IO Non-Alert, Open Reparse Point, Attributes: N, ShareMode: Read, Write, AllocationSize: 0"
"21:14:27,5452322","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash","NAME COLLISION","Desired Access: Read Data/List Directory, Synchronize, Disposition: Create, Options: Directory, Synchronous IO Non-Alert, Open Reparse Point, Attributes: N, ShareMode: Read, Write, AllocationSize: 0"
"21:14:27,5463648","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\SQMServiceList","REPARSE"," Desired Access: Query Value"
"21:14:27,5472159","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash","NAME COLLISION","Desired Access: Read Data/List Directory, Synchronize, Disposition: Create, Options: Directory, Synchronous IO Non-Alert, Open Reparse Point, Attributes: N, ShareMode: Read, Write, AllocationSize: 0"
"21:14:27,6877129","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\Macromed\Flash\FlashPlayerUpdateServic e.exe","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:27,6881908","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\FlashPlayerUpdateService.exe","NAME NOT FOUND","Desired Access: Query Value, Enumerate Sub Keys"
"21:14:27,6903402","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Session Manager\AppCertDlls","REPARSE","Desired Access: Query Value"
"21:14:27,6903685","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Session Manager\AppCertDlls","NAME NOT FOUND","Desired Access: Query Value"
"21:14:27,6904061","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\SafeBoot\Option","REPARSE", "Desired Access: Query Value, Set Value"
"21:14:27,6904252","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\SafeBoot\Option","NAME NOT FOUND","Desired Access: Query Value, Set Value"
"21:14:27,6904886","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Policies\Microsoft\Windows\safer\codeidentifiers \TransparentEnabled","NAME NOT FOUND","Length: 80"
"21:14:27,6905440","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Policies\Microsoft\Windows\Safer\CodeIdentifiers"," NAME NOT FOUND","Desired Access: Query Value"
"21:14:27,6905711","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\SafeBoot\Option","REPARSE", "Desired Access: Query Value"
"21:14:27,6905902","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\SafeBoot\Option","NAME NOT FOUND","Desired Access: Query Value"
"21:14:27,6906149","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Session Manager\AppCompatibility","REPARSE","Desired Access: Query Value"
"21:14:27,6906358","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\System\CurrentControlSet\Control\Session Manager\AppCompatibility","NAME NOT FOUND","Desired Access: Query Value"
"21:14:27,6906586","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Policies\Microsoft\Windows\AppCompat","NAME NOT FOUND","Desired Access: Query Value"
"21:14:27,6918195","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\System32\apphelp.dll","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE"
"21:14:27,6937674","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\AppPatch\sysmain.sdb","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:27,6965856","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers\C:\Windows\System32\Macromed\ Flash\FlashPlayerUpdateService.exe","NAME NOT FOUND","Length: 1.024"
"21:14:27,6966293","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers","NAME NOT FOUND","Desired Access: Read"
"21:14:27,6966632","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Custom\FlashPlayerUpdateService.exe" ,"NAME NOT FOUND","Desired Access: Read"
"21:14:27,6971319","install_flash_player_ax_32bit.exe","624","QueryDir ectory","C:\Windows\System32\Macromed\Flash","NO MORE FILES",""
"21:14:27,7012587","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\{767a56fe-ce21-4e6f-a7f5-ddf314c776b 0}","NAME NOT FOUND","Length: 1.024"
"21:14:27,7013480","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\{767a56fe-ce21-4e6f-a7f5-ddf314c776b 0}","NAME NOT FOUND","Length: 1.024"
"21:14:27,7017274","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\{abffd2a7-69ed-49f5-9a32-2855803366c 3}","NAME NOT FOUND","Length: 1.024"
"21:14:27,7017908","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\{abffd2a7-69ed-49f5-9a32-2855803366c 3}","NAME NOT FOUND","Length: 1.024"
"21:14:27,7026998","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\system32\Macromed\Flash\ui\SwDRM.dll","PATH NOT FOUND","Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a"
"21:14:27,7030299","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\{049efb11-5dd9-4112-998a-335fd1e47d2 7}","NAME NOT FOUND","Length: 1.024"
"21:14:27,7030909","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\{049efb11-5dd9-4112-998a-335fd1e47d2 7}","NAME NOT FOUND","Length: 1.024"
"21:14:27,7066068","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\{767a56fe-ce21-4e6f-a7f5-ddf314c776b 0}","NAME NOT FOUND","Length: 1.024"
"21:14:27,7066672","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\{767a56fe-ce21-4e6f-a7f5-ddf314c776b 0}","NAME NOT FOUND","Length: 1.024"
"21:14:27,7069511","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\{abffd2a7-69ed-49f5-9a32-2855803366c 3}","NAME NOT FOUND","Length: 1.024"
"21:14:27,7070096","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\{abffd2a7-69ed-49f5-9a32-2855803366c 3}","NAME NOT FOUND","Length: 1.024"
"21:14:27,7080689","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\{049efb11-5dd9-4112-998a-335fd1e47d2 7}","NAME NOT FOUND","Length: 1.024"
"21:14:27,7081256","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\{049efb11-5dd9-4112-998a-335fd1e47d2 7}","NAME NOT FOUND","Length: 1.024"
"21:14:27,7089286","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\DisableLocalOverride","NAME NOT FOUND","Length: 1.024"
"21:14:27,7089680","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Pref erExternalManifest","NAME NOT FOUND","Length: 20"
"21:14:27,7120972","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\AppPatch\sysmain.sdb","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:27,7130179","install_flash_player_ax_32bit.exe","624","CreateFi leMapping","C:\Windows\AppPatch\sysmain.sdb","FILE LOCKED WITH ONLY READERS","SyncType: SyncTypeCreateSection, PageProtection: PAGE_READONLY"
"21:14:31,2770986","install_flash_player_ax_32bit.exe","624","RegOpenK ey","HKLM\SOFTWARE\RealNetworks\RealPlayer","NAME NOT FOUND","Desired Access: Read"
"21:14:33,7244791","install_flash_player_ax_32bit.exe","624","CreateFi le","C:\Windows\System32\Macromed\Flash","NAME COLLISION","Desired Access: Read Data/List Directory, Synchronize, Disposition: Create, Options: Directory, Synchronous IO Non-Alert, Open Reparse Point, Attributes: N, ShareMode: Read, Write, AllocationSize: 0"
"21:14:33,9130961","install_flash_player_ax_32bit.exe","624","RegQuery Value","HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\GRE_Initialize\DisableMetaFiles","NAME NOT FOUND","Length: 20"
From the FlashInstall.log file it appears as if the installer can't write FlashUtil32_11_2_202_235_ActiveX.exe; but I cannot see anything regarding this in the procmon log file.
I'm a bit lost here... But, what I would try if that happened to me is the following
I am currently away from my desk till end of june, so I was not yet able to test it.
A few thoughts I want to try if it does not work as suggested above:
a)
what about trying an installation in protected mode?
b)
I am running Secunias PSI 2.0, MS Security Essentials 4 and ThreatFire on both affected computers. Though I disabled all of them before trying to install again and again there might be something related to that software!?
So, if you have any further hints (e.g. using the same security software or success in installing it in protected mode) please let me know!
