In Indesign CS6 using Mountain Lion, the hand tool appears and I can't select or work with any other tool. All I can do is move the document around. After trying the space bar and other key commands I restarted and it worked for a while. Then it happened again. I work on a Macbook pro, so when I removed the mouse and worked only with the trackpad there was no change. When I quit and reopened, no change. I then deleted prefs and restarted and it worked, but it's been happening from time to time. Anyone know any other fix without restarting or deleting prefs.
Check your space bar one more time, it might be sticking. My MacBook Pro has a spacebar that sticks just a tiny bit every once in a while and it causes exactly the problem you are describing. The space bar is a short cut for the hand tool and while you can select other tools, it will always immediately revert to the hand tool as soon as you move your mouse back over the document.
Count me as a third - same problem... Intermittent and very frustrating. The only reliable way to reset has been to quit the app and restart. I use ID 6-8 hours/day and this occurs 3-5 times per day.
I'm working in Lion, however, not ML. MacPro (1,1) dual Xeon 3GHz, 12GB RAM, Radeon HD 5770. I've not experienced the problem in any of the other CS6 apps, only ID.
Could the three of you please report this as a bug: Adobe - Feature Request/Bug Report Form
I'm not sure it is one, but it maight at least prompt someone at QA to take a look.
The same thing is happening to me. I'm on a MacBook Pro Retina, running bootcamp with Windows 7. While I'm on the Windows side I'm not able to select any of the tools. Keyboard shortcuts work, but I'm not able to select most tools with my mouse. I can't seem to trash my preferences, but even when I restart I'm still unable to select the tools.
This is much more likely a case of using Large Fonts in the Windows interface: InDesign tools and panels don't respond to mouse clicks (Windows 7/Vista)
I hd the same thing happen and I'm on an imac in Mountain Lion. Thank goodness you guys posted this and I was able to trash my preferences. I will be reporting this as well. The more people who do that, the quicker they will be to fix the bug. By the way, in case anyone reading this doesn't know or remember, to delete preferences on a mac you hold down shift+control+option+command while starting InDesign and you will get a prompt asking if you want to delete the preferences.
