where is the animation panel in Photoshop CS6 extended?
Its the timeline panel in CS6 there is a button to create a video or animation frames once the panel opens. Use men Window>Timeline to open
Thank you very much for responding JJMack, but i happened to stumble across it maybe 30 minutes after i posted the question. I somehow stumbled across it by selecting the measurements panel. But none of the less, thank you for the support, sincerely, David Caron.
Glad that you located the Video/Animation selection.
If all is good, then please look over this article: http://forums.adobe.com/thread/1058744?tstart=0
Though you found the location, just after posting, as JJMack's Reply is correct, maybe mark it as such, to help others, who find your thread in a Search, just so that they will know that you got the answer, and that the correct place to look is known. That will likely help others in the future.
Good luck, and thank you for reporting your success.
Hunt
