We have a problem to do HDS streaming in my FMS ...attached the screenshot showing error when i tried in my sample video player.
Normally what could be the reason for it. RTMP is working without any probelms.
Please advice where I can check the errorlogs for this issue.
That error is too generic. Provide details like FMS version, liveplgr xmls, httpd config files, etc.
FMS version 4.5
# cat Event.xml
<Event>
<EventID>liveevent</EventID>
<Recording>
<FragmentDuration>4000</FragmentDuration>
<SegmentDuration>400000</SegmentDuration>
<DiskManagementDuration>3</DiskManagementDuration>
</Recording>
</Event>
# cat Manifest.xml
<manifest xmlns="http://ns.adobe.com/f4m/1.0">
<media streamId="livestream" bitrate="350" />
</manifest>
httpd.conf
# This is the main Apache server configuration file. It contains the
# configuration directives that give the server its instructions.
# See <URL:http://httpd.apache.org/docs/2.2/> for detailed information.
# In particular, see
# <URL:http://httpd.apache.org/docs/2.2/mod/directives.html>
# for a discussion of each configuration directive.
# Please see httpd.conf.orig for the configuration of a default
# (non-FMS) installation of apache.
Listen 80
#Listen 8134
# If you plan to run FMS as root on linux, you _must_ specify a
# valid user, with access to the FMS installation direction, or
# apache will not run.
# If you've used the default installer, nobody (or whatever other
# username you gave to the installer) will work here.
# If you're running a developer build under your own home directory,
# you should use your own username.
User fms
Group fms
AccessFileName .htaccess
ServerSignature On
UseCanonicalName Off
HostnameLookups Off
Timeout 120
KeepAlive On
MaxKeepAliveRequests 100
KeepAliveTimeout 15
ErrorLog logs/error_log
LogLevel info
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
CustomLog logs/access_log combined
# Proxy rtmpt to FMS
ProxyRequests Off
ProxyPass /open/ http://localhost:1935/open/
ProxyPass /close/ http://localhost:1935/close/
ProxyPass /idle/ http://localhost:1935/idle/
ProxyPass /send/ http://localhost:1935/send/
ProxyPass /fcs/ http://localhost:1935/fcs/
ProxyPass /fms/ http://localhost:1935/fms/
DocumentRoot "../webroot"
DirectoryIndex index.html index.html.var index.php index.php3 index.php4 index.php5 index.py index.pl index.rb
<Directory />
Options FollowSymLinks
AllowOverride None
Order allow,deny
Allow from all
Satisfy all
</Directory>
<Directory "../webroot">
Options -Indexes FollowSymLinks
AllowOverride None
Order allow,deny
Allow from all
</Directory>
Alias /documentation ../documentation/
<Directory ../documentation/>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
Alias /icons/ "icons/"
<Directory "icons">
Options MultiViews FollowSymLinks
AllowOverride None
Order allow,deny
Allow from all
</Directory>
Alias /error/ "error/"
ScriptAlias /cgi-bin/ "cgi-bin/"
<Directory "cgi-bin">
AllowOverride None
Options None
Order allow,deny
Allow from all
</Directory>
<Location /server-status>
SetHandler server-status
Order deny,allow
Deny from all
Allow from 10.0.0.0/8
Allow from 172.16.0.0/12
Allow from 192.168.0.0/16
Allow from 127.
</Location>
ExtendedStatus On
<Location /server-info>
SetHandler server-info
Order deny,allow
Deny from all
Allow from 127.
</Location>
<FilesMatch "^\.ht">
Order allow,deny
Deny from all
</FilesMatch>
<IfModule mpm_winnt_module>
ThreadsPerChild 250
MaxRequestsPerChild 0
</IfModule>
<IfModule worker_module>
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadsPerChild 25
</IfModule>
LoadModule actions_module modules/mod_actions.so
#LoadModule alias_module modules/mod_alias.so
LoadModule asis_module modules/mod_asis.so
LoadModule auth_basic_module modules/mod_auth_basic.so
LoadModule auth_digest_module modules/mod_auth_digest.so
LoadModule authn_anon_module modules/mod_authn_anon.so
#LoadModule authn_dbm_module modules/mod_authn_dbm.so
LoadModule authn_default_module modules/mod_authn_default.so
LoadModule authn_file_module modules/mod_authn_file.so
#LoadModule authz_dbm_module modules/mod_authz_dbm.so
LoadModule authz_default_module modules/mod_authz_default.so
LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
LoadModule authz_host_module modules/mod_authz_host.so
LoadModule authz_user_module modules/mod_authz_user.so
LoadModule autoindex_module modules/mod_autoindex.so
#LoadModule cern_meta_module modules/mod_cern_meta.so
LoadModule cgi_module modules/mod_cgi.so
</IfModule>
LoadModule cgid_module modules/mod_cgid.so
</IfModule>
LoadModule dav_module modules/mod_dav.so
LoadModule dav_fs_module modules/mod_dav_fs.so
LoadModule deflate_module modules/mod_deflate.so
LoadModule dir_module modules/mod_dir.so
LoadModule env_module modules/mod_env.so
#LoadModule expires_module modules/mod_expires.so
#LoadModule file_cache_module modules/mod_file_cache.so
LoadModule headers_module modules/mod_headers.so
LoadModule imagemap_module modules/mod_imagemap.so
LoadModule include_module modules/mod_include.so
LoadModule info_module modules/mod_info.so
LoadModule isapi_module modules/mod_isapi.so
</IfModule>
LoadModule log_config_module modules/mod_log_config.so
LoadModule mime_module modules/mod_mime.so
LoadModule mime_magic_module modules/mod_mime_magic.so
LoadModule proxy_module modules/mod_proxy.so
LoadModule proxy_ajp_module modules/mod_proxy_ajp.so
LoadModule proxy_balancer_module modules/mod_proxy_balancer.so
LoadModule proxy_connect_module modules/mod_proxy_connect.so
LoadModule proxy_http_module modules/mod_proxy_http.so
LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
LoadModule negotiation_module modules/mod_negotiation.so
LoadModule rewrite_module modules/mod_rewrite.so
LoadModule setenvif_module modules/mod_setenvif.so
#LoadModule speling_module modules/mod_speling.so
LoadModule status_module modules/mod_status.so
LoadModule unique_id_module modules/mod_unique_id.so
LoadModule userdir_module modules/mod_userdir.so
#LoadModule usertrack_module modules/mod_usertrack.so
#LoadModule vhost_alias_module modules/mod_vhost_alias.so
#LoadModule ssl_module modules/mod_ssl.so
# The following section enables caching of Just-In-Time packaged content #
# Use htcacheclean tool to manage the amount of data that is cached on disk. #
# See Apache documentation for its usage. #
# http://httpd.apache.org/docs/2.2/programs/htcacheclean.html #
# Make sure the directory specified by the CacheRoot directive exists. The #
# default is a directory named cacheroot that is directly under the Apache #
# installation directory. #
# For more information on content caching, see Apache documentation #
# http://httpd.apache.org/docs/2.2/caching.html #
# Uncomment this to enable caching
#LoadModule cache_module modules/mod_cache.so
<IfModule mod_cache.c>
LoadModule disk_cache_module modules/mod_disk_cache.so
<IfModule mod_disk_cache.c>
CacheEnable disk /hds-vod
CacheEnable disk /hls-vod
CacheRoot cacheroot
CacheMaxFileSize 10000000
CacheLock On
</IfModule>
</IfModule>
<IfModule mod_deflate.c>
AddOutputFilterByType DEFLATE application/vnd.apple.mpegurl
SetEnvIfNoCase Request_URI "^" dont-vary
SetEnvIfNoCase Request_URI \.(?:vnd\.apple\.mpegurl)$ !no-gzip !dont-vary
Header append Vary Accept-Encoding env=!dont-vary
</IfModule>
LoadModule f4fhttp_module modules/mod_f4fhttp.so
<IfModule f4fhttp_module>
<Location /vod>
HttpStreamingEnabled true
HttpStreamingContentPath "../webroot/vod"
</Location>
# Drop the Range header when more than 5 ranges.
# CVE-2011-3192
SetEnvIf Range (,.*?){5,} bad-range=1
RequestHeader unset Range env=bad-range
# map old style url to new (as of FMS 4.5), more compact url
Redirect 301 /live/events/livepkgr/events /hds-live/livepkgr
<Location /hds-live>
HttpStreamingLiveEventPath "../applications"
HttpStreamingContentPath "../applications"
HttpStreamingF4MMaxAge 2
HttpStreamingBootstrapMaxAge 2
HttpStreamingDrmmetaMaxAge 2
HttpStreamingFragMaxAge -1
</Location>
</IfModule>
LoadModule hlshttp_module modules/mod_hlshttp.so
<IfModule hlshttp_module>
<Location /hls-live>
HLSHttpStreamingEnabled true
HLSMediaFileDuration 8000
HLSSlidingWindowLength 6
HLSFmsDirPath ".."
HLSM3U8MaxAge 2
HLSTSSegmentMaxAge -1
HLSMaxEventAge 300
HttpStreamingUnavailableResponseCode 503
# Uncomment the following directives to enable encryption
# for this location.
# HLSEncryptionScope server
# HLSEncryptCipherKeyFile "../phls/liveeventkey.bin"
# HLSEncryptKeyURI "https://<ServerName>/hls-key/liveeventkey.bin"
</Location>
<Location /hls-vod>
HLSFmsDirPath ".."
HLSJITConfAllowed true
# HLSEncryptCipherKeyFile "../phls/vodkey.bin"
# HLSEncryptKeyURI "https://<ServerName>/hls-key/vodkey.bin"
</Location>
</IfModule>
LoadModule jithttp_module modules/mod_jithttp.so
<IfModule jithttp_module>
<Location /hds-vod>
HttpStreamingJITPEnabled true
HttpStreamingJITConfAllowed true
JitFmsDirPath ".."
</Location>
</IfModule>
LoadModule ctrlplane_module modules/mod_ctrlplane.so
<IfModule ctrlplane_module>
<Location /ctrlplane>
SetHandler ctrlplane
HdsHttpStreamingLiveEventPath "../applications"
HlsHttpStreamingLiveEventPath "../applications"
MaxBootstrapAge 300
</Location>
</IfModule>
TypesConfig conf/mime.types
MIMEMagicFile conf/magic
DefaultType text/plain
AddType video/x-flv .flv
AddType video/MP2T .ts
AddType application/x-compress .Z
AddType application/x-gzip .gz .tgz
AddType application/x-mpegurl .m3u8
AddHandler send-as-is asis
AddHandler type-map var
AddType text/html .shtml
AddOutputFilter INCLUDES .shtml
<IfModule ssl_module>
SSLRandomSeed startup builtin
SSLRandomSeed connect builtin
</IfModule>
<IfModule userdir_module>
UserDir disable
</IfModule>
<IfModule dav_fs_module>
DAVLockDB tmp/dav/lockdb
</IfModule>
IndexOptions FancyIndexing VersionSort NameWidth=* HTMLTable
AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
AddIconByType (TXT,/icons/text.gif) text/*
AddIconByType (IMG,/icons/image2.gif) image/*
AddIconByType (SND,/icons/sound2.gif) audio/*
AddIconByType (VID,/icons/movie.gif) video/*
AddIconByType (VID,/icons/movie.gif) application/x-shockwave-flash
AddIcon /icons/binary.gif .bin .exe
AddIcon /icons/binhex.gif .hqx
AddIcon /icons/tar.gif .tar
AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
AddIcon /icons/a.gif .ps .ai .eps
AddIcon /icons/layout.gif .html .shtml .htm .pdf
AddIcon /icons/text.gif .txt
AddIcon /icons/c.gif .c
AddIcon /icons/p.gif .pl .py
AddIcon /icons/f.gif .for
AddIcon /icons/dvi.gif .dvi
AddIcon /icons/uuencoded.gif .uu
AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
AddIcon /icons/tex.gif .tex
AddIcon /icons/bomb.gif core
AddIcon /icons/back.gif ..
AddIcon /icons/hand.right.gif README
AddIcon /icons/folder.gif ^^DIRECTORY^^
AddIcon /icons/blank.gif ^^BLANKICON^^
DefaultIcon /icons/unknown.gif
ReadmeName README.html
HeaderName HEADER.html
IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t
AddLanguage ca .ca
AddLanguage cs .cz .cs
AddLanguage da .dk
AddLanguage de .de
AddLanguage el .el
AddLanguage en .en
AddLanguage eo .eo
AddLanguage es .es
AddLanguage et .et
AddLanguage fr .fr
AddLanguage he .he
AddLanguage hr .hr
AddLanguage it .it
AddLanguage ja .ja
AddLanguage ko .ko
AddLanguage ltz .ltz
AddLanguage nl .nl
AddLanguage nn .nn
AddLanguage no .no
AddLanguage pl .po
AddLanguage pt .pt
AddLanguage pt-BR .pt-br
AddLanguage ru .ru
AddLanguage sv .sv
AddLanguage zh-CN .zh-cn
AddLanguage zh-TW .zh-tw
LanguagePriority en ca cs da de el eo es et fr he hr it ja ko ltz nl nn no pl pt pt-BR ru sv zh-CN zh-TW
ForceLanguagePriority Prefer Fallback
AddDefaultCharset UTF-8
<IfModule mod_negotiation.c>
<IfModule mod_include.c>
<Directory "error">
AllowOverride None
Options IncludesNoExec
AddOutputFilter Includes html
Order allow,deny
Allow from all
LanguagePriority en es de fr
</Directory>
</IfModule>
</IfModule>
BrowserMatch "Mozilla/2" nokeepalive
BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
BrowserMatch "RealPlayer 4\.0" force-response-1.0
BrowserMatch "Java/1\.0" force-response-1.0
BrowserMatch "JDK/1\.0" force-response-1.0
BrowserMatch "Microsoft Data Access Internet Publishing Provider" redirect-carefully
BrowserMatch "MS FrontPage" redirect-carefully
BrowserMatch "^WebDrive" redirect-carefully
BrowserMatch "^WebDAVFS/1.[0123]" redirect-carefully
BrowserMatch "^gnome-vfs/1.0" redirect-carefully
BrowserMatch "^XML Spy" redirect-carefully
BrowserMatch "^Dreamweaver-WebDAV-SCM1" redirect-carefully
#Uncomment following for enabling https based key serving
#for HLS.
#Include conf/httpd-hls-secure.conf
provide your publishing and playback URLs.
P.S. This is a public forum as opposed to Adobe support. You don’t need to paste the whole config.
Flash Encoder:
FMS URL: rtmp://fms-server-name/livepkgr
Stream: livestream?adbe-live-event=liveevent
Playback URL: http://fms-server-name/hds-live/livepkgr/_definst_/liveevent/livestream.f4m
Stream: livestream?adbe-live-event=liveevent&adbe-record-mode=record
Before you go on, clear the streams folder under livepkgr, clear .stream files under livepkgr\events\_definst_\liveevent, and reload livepkgr app in AMS admin console.
No .. the same error
i am also getting this error with Chrome, yet Firefox will play the streams/files without the error.
In both Chrome and Firefox showing same error for me ..
Anybody can please share your expert advice please ...
VOD is working without any issue:-
http://fms-server-name/vod/sample2_1000kbps.f4v
I could solve the issue ..
Please refer: http://forums.adobe.com/message/4765473
thanks all for the support
