Hyperlinks (Adobe Presenter 7.0.6)
Jul 2, 2012 2:33 AM
I have two hyperlinks in PPT. One points to a word doc and other to a ppt or pptx.
While the doc link works as expected the other hyperlink doesnt even show hand symbol.
Please let me know if this can be resolved
  • Jorma Jennings
    Jul 5, 2007
    Jul 2, 2012 9:30 AM   in reply to graphias
    Hyperlinks in Presenter will not work if they are not pointed to an http:// call or another slide in the document. Not sure why you are seeing the call to the doc working. Presenter is intended to be a server based tool, so local file paths are not allowed.
  • Jorma Jennings
    Jul 5, 2007
    Jul 3, 2012 9:00 AM   in reply to graphias
    Well, I will assume you are refering to this presentation and it's section on attaching documents through the attachments feature. Is that correct? In that case, the document is actually bundled with the presentation and the download feature will allow users to pull down the attached files from the presentation through the paperclip button on the right of the play bar. Is the issue with that feature, as opposed to the hyperlink functionality?
    If that is the functionality you are using, you may want to make sure that it is not a pop-up blocker that is stopping  your users from downloading the files, as the download link opens in a new window.
  • Jorma Jennings
    Jul 5, 2007
    Jul 5, 2012 2:03 PM   in reply to graphias
    The issue I run into is with certain clip art images, the conversion to flash goes badly. This results in the hyper link only working if you carefully mouse over the edge of the image. Text hyperlinks work fine. If you convert images to jpeg and then insert them and add a hyper link it should work. Here is a sample, using the hyperlinking technique shown above, that gives access to a ppt and pptx file, but the center and right clip art image only link on the edge of them.
    http://realeyesconnect.adobeconnect.com/p5fpf1qvfwc/
