• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Fresh install of PPro CS5.5 on Mac - missing presets and AVCHD support
Community Beginner ,
Feb 26, 2012 Feb 26, 2012
Oh, this is crazy.  How on earth is this not bug-fixed?
I'm in the middle of setting up a new editing suite for my Secondary school where I am a Media Studies teacher.  I've got a handful of Macs running fresh installs which I've installed new legal, site licensed Premiere Pro CS5.5 installs on.  By default, as in many workplaces, the Macs require admin passwords for internet and install settings, which I applied.  None of the machines have had trial versions od PPro CS5.5 or previous versions of PPro.
The issues:
  1. None of the fresh installs contain the presets for  AVC-Intra, AVCHD, Digital SLR, XDCAM EX, XDCAM HD422, and XDCAM HD.  Which is kind of a disaster, as we have brand new Panasonic HDC-SD900 AVCHD cameras waiting to load up footage for editing.
  2. Further to this, none of the macs will load or recognise the AVCHD footage when I try to add it.  I get "unsupported compression type" errors.
Am I missing something basic here, or am I about to enter the "delete everything adobe, reboot, reinstall, reboot" loop from hell to try and fix an entire roomful of machines?   Is there ANY way to check if the presets are on the Macs?  Is there any way to link them back into PPro if they are?  And finally, is there any way to get CS5.5 to recognise AVCHD as a recognised format (which is why I bought the site license in the first place!  Premiere Pro is meant to have the easiest AVCHD compatibility of all the editing suites!).
Grr.  Dammit.
Ideas?
Views
18.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Mar 01, 2012 Mar 01, 2012
Okay, this turned out weird.  Fixed now, but WEIRD.  After the deafening silence on this forum, I went and did some reading on other threads and with other people having similar (but it seems not the same) issue.  It seems that there could have been three different causes: here's what I did to fix things, I'd be fascinated if anyone with closer links to Adobe comes up with the technical explanation of why this turned out the way that it did.
Possible issues:
(1) Install may need to be done as Adm
Votes
Translate
Translate
Community Expert ,
Feb 27, 2012 Feb 27, 2012
Looks like Premiere went into a kind of trial mode like in CS5.
Best is to deactivate, uninstall, run Cleaner Tool and reinstall.
http://www.adobe.com/support/contact/cscleanertool.html
Votes
Translate
Translate
Report
Report
Feb 29, 2012 Feb 29, 2012
Hi Ann - I'd *love* to take your advice, but...
(1) logged in as me, I can't deactivate.  It gives me the "you must be logged in as an admin" message.
(2) when I do log in as admin, I can't deactivate as it gives me "cannot deactivate" error, code 255:255, which the only documentation I can find says that it's an error to do with having some other CS suite trial/software installed previously: which I have not, this is a fresh install.
What's the effect if I DON'T deactivate and then uninstall?
*sigh*
AJ
Votes
Translate
Translate
Report
Report
Possible issues:
(1) Install may need to be done as Admin, rather than standard user on a Mac
(2) firewall/proxy server maybe isn't allowing some anonymous callback from premiere to adobe to register presets/codecs
(3) something else weird involving registration... some people have had issues with time zones, of all things.  see below.
What I did:
(0) Took everything off the school network and put on my home wireless network: no firewall, direct connection to internet.
(1) Tried Ann Bens's suggestion above.  Was unable to deactivate software while logged in as Admin on my mac.  Came up with error code 255:255 in the notification box, even though I never had a trial version installed on this box.  This was the same error I got at school, so I'm tentatively ruling out proxy/firewall issues.
(2) Read the forums some more.  I'm in New Zealand, it's currently daylight savings time (GMT +13) here.  In http://forums.adobe.com/message/4007876, someone in NZ had a different but similar problem with registering/deregistering Premiere Pro software during NZ daylight savings time, and found that changing to ANY other time zone fixed their issue.
(3) Thought "what the hell", changed the time zone to Samoa (couldn't bring myself to do Australia...) and rebooted as admin.
(4) Successfully deactivated software, no error messages.  Interesting.
(5) Uninstalled premiere pro.  Rebooted as admin.
(6) Ran adobe cleaner tool.  Found some scraps, killed them off.  Rebooted as admin to be on the safe side (still on Samoa time)
(7) Installed Premiere, no issues at all.  Registered, no issues at all.  All preset settings present and correct, no issues getting AVCHD files.
(8) Changed time zone to NZ day light savings time.
(9) Everything still works.
Hm.  Adobe, SOMETHING is wrong with the way your software is handling timezones and registration of codecs/software on Premiere Pro CS5.5.  Seriously, does anyone have a clue why this might be happening?
So, solved.  Shall I give myself a tick for "correct answer" and "helpful answer", given I solved my own thing with no help from tech support?
Votes
Translate
Translate
Report
Report
New Here ,
Mar 11, 2012 Mar 11, 2012
LATEST
Just installed Master Collection CS5.5 last week, but need to install a 64 bit OS to utilise premiere so tried to deactivate, no luck. Googled error #255.255, some replies were around firewall settings, so created a rule to allow anything to *.adobe.com through, but still no luck deactivating. Took my work PC home so there was no firewall in the loop, still no joy. Tried reinstalling over existing install, no good. Just came across your post regarding time zones and thought "no harm in trying it"......and it worked!!!
Thanks for the advice, must mentally put that one away for a rainy day!
Votes
Translate
Translate
Report
Report
Guest
Mar 02, 2012 Mar 02, 2012
Thank You for your clear and helpful directions...my admin password was, "blank" so when I reset it with a, "real" password...it worked. Same issues and same resolution. All codecs are available thanks to you.
Votes
Translate
Translate
Report
Report
