I'm running Photoshop CC 2017.1.1 on an iMac (27-inch, Late 2013) with an NVIDIA GeForce GTX 780M 4096 MB.
A couple times recently, Photoshop won't update its window. For example, if I have an image open and press command-I, "Invert" will show up in the history palette but nothing changes in the image window. If I zoom into the image, now it's inverted. If I press command-Z, nothing changes in the image window. If I zoom in/out, it shows the change.
Restarting Photoshop seems to fix it, though one time I had to reboot.
Any suggestions?
Thanks.
There's a couple of threads here about the issue might be worth reading through to see if any of the suggestions work for you
Photoshop CC 2017: The edited image isn't updated in a window | Photoshop Family Customer Community
Have you tried updating to CC2018
Hi Maxgraphic,
Could you please try resetting the preferences of Photoshop and let us know if it helps?
To restore preferences quickly using a keyboard shortcut: Press and hold Alt+Control+Shift (Windows) or Option+Command+Shift (Mac OS) as you start Photoshop. You are prompted to delete the current settings. The new preferences files are created the next time you start Photoshop
Sahil
Sorry to take so long to respond. Resetting the settings didn't resolve it. I think at this point it's actually gotten worse, because restarting Photoshop doesn't usually fix it now.
I've also reinstalled Photoshop and updated it at least once since I first noticed this issue. The problem is it's intermittent so I occasionally think I've fixed it but it always comes back.
Certain actions DO refresh the window. For example, most tools like the brush will update the window. But selection tools (marquee, lasso) don't, and actions like Edit > Fill don't.
Any other suggestions? Would uploading a video of the behavior help?
Hi
It could be GPU related, take a look here
Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
I have "Use Graphics Processor" unchecked in Preferences > Performance.
It also just dawned on me that I'm using a new computer since I first posted this. I'm now on an iMac (Retina 5K, 27-inch, 2017) with a Radeon Pro 580 8192 MB. So I guess it's not hardware-related.
Is there a list anywhere of software that conflicts with Photoshop? At one point I thought Fantastical 2 was the culprit but then the problem returned without it. It's tough to troubleshoot such an intermittent problem.
Thanks. I am using 19.1.3.
Reading through that thread it looks like RightFont is likely the culprit. I haven't paid to upgrade to the latest version of that but I will and see if that does the trick.
Thanks again for your help.
You're welcome hope you get it sorted
