when i try to save my pdf file after adding some highlights or pop ups it seems i cant save the file after clicking the save icon.
An error "The document could not be saved. There was a problem reading this document(110)." keeps coming up . Why is that??
Hello Zombi,
Sorry for the delayed response and inconvenience caused. AS per the description above, you are getting an error message while saving a PDF file using Adobe Reader, Is that correct?
Is it happening with all the PDF files or is it specific to one PDF? Try saving the PDF as 'File>Save As' and see if this brings any difference.
Try saving the file with a different file name and check. You may also refer to the following Adobe discussion and try the suggestions marked as 'helpful' and 'corr
...Copy link to clipboard
Hello Zombi,
Try saving the file with a different file name and check. You may also refer to the following Adobe discussion and try the suggestions marked as 'helpful' and 'correct' there was an error processing a page. there was a problem reading this document (110)?
https://acrobatusers.com/forum/general-acrobat-topics/can-not-save-downloaded-pdf-document/
https://acrobatusers.com/forum/security/acrobat-doc-could-not-be-saved-issue-error-43/
Check for any pending updates of Adobe Reader from help>check for updates, reboot the machine after updating Adobe Reader and check.
What is the dot version of Adobe Reader installed? To identify refer to Identify the product and its version for Acrobat and Reader DC
Is it a Mac or Windows machine and what is the version of OS installed?
If the issue is specific to one PDF file, Is it possible to share the PDF file with us? To share the file, please use Adobe Send feature, upload the file, share the link to files via private message only, How Do I Send Private Message
Let us know how it goes and share your observation.
Anand Sri.
