Hi all,
I have a few users here that are all having the same issue with Acrobat. When they go to open a PDF with multiple pages that would be around 6MB in size, Acrobat becomes non responsive when attempting to save the file to the local device or to a network drive. It also freezes when scrolling through the documents pages.
I have tried the updates, repairing, removing the security features, uninstalling and reinstalling it and still the same results.
Can anyone advise if they found another way to resolve this issue.
Hi Conorf,
As per the issue description mentioned above, Adobe Pro not responding when opening a PDF with multiple pages, is that correct?
Could you let us know dot version of Acrobat and the operating system installed on the machine? You may refer to the steps given in this link on how to check the version in Acrobat: Identify the product and its version for Acrobat and Reader DC
Does this happen with specific pdf file or with all the files?
Also, would it be possible to share the pdf file you are working with to replicate the issue at our end? To share the file here in the forums, refer to the steps given in this link: How to share a file using Adobe Document Cloud
You may also share the link for the pdf via private message - How Do I Send Private Message
Let us know if you need any help.
Shivam
Hi Shivam,
We are using Adobe Acrobat Pro 2017 on Windows 10 Pro.
The issue with Acrobat Pro not responding happens with everything i.e. when opening a large, multi page PDF, when saving any PDF when renaming the PDF while saving as. Unfortunately I am unable to share the PDF with you as it is highly confidential but the fact is, this is happening to all PDF documents.
Have you come across this issue before?
Kind regards,
Conor.
Hi Conor,
You may try disabling protected view and enhanced security using Edit menu > Preferences > Security (Enhanced), relaunch Acrobat and check if that helps.
Note: disabling protected view is for troubleshooting purpose only, and not recommended. Turn the feature back on after troubleshooting is complete.
-Shivam
Hi Shivan,
I have disabled the protective view, done the repair, and updated the software and still the same issue is occurring. I have uninstalled the software and reinstalled it and done the same process again but still the issue occurs.
Kind regards,
Conor.
Hi Conor,
Try disabling show online storage option under Edit > Preferences > General > show online storage when opening/saving files , relaunch Acrobat and check.
-Shivam
I am having very similar problems. For me, having one .pdf open is not a problem but as soon as I open another file the software freezes up.
Hi Danb,
Also, try replicating the issue in Adobe Reader: Adobe Acrobat Reader DC Install for all versions and see if it depicts the same behavior as Acrobat.
Shivam
