Hi there!
Not actually the world’s end, but still somewhat annoying:
[Win 10 64 Pro]
After launching Acrobat Pro DC (19.008.20081) in the morning, the first thing I always have to do is to maximize its window. And I have to repeat that every morning—that maximize status won’t stick.
What to do about this?
Hi Klаus,
As per the issue description mentioned above, acrobat's window doesn't stay maximized, is that correct?
Could you try resetting preferences for Acrobat using the steps given in this link: How to reset Acrobat Preference settings to default. reboot the machine after resetting preferences and try again.
If that doesn't work, try checking the box next to "restore last view settings when reopening documents" under edit > preferences > documents,click OK relaunch Acrobat and check.
Does this h
...Copy link to clipboard
Hi Klаus,
Does this happen only with Acrobat? Have you tried replicating the behavior with other applications?
Let us know if you need any help.
Shivam
Thank you, Shivam!
The »resetting step« alone did not solve the problem, I’ll try the »restore last view settings« proposal tomorrow.
Yep, now it stays maximized! Thanks again!
