I can't get the Creative Cloud App to install on my Mac (El Capitan). I can down load the DMG file, I click the installer and it prompts me for my administrative password, but then nothing happens.
If I checkin ~/Library/Logs/AdobeDownload/LBS.log, I see the following last few lines:
11/29/15 16:40:53:035 | [INFO] | | ACC | LBS | WorkflowManager | | | 69142 | The resolved URL for package service is https://prod-rel-ffc.oobesaas.adobe.com/adobe-ffc-external/core/v1/applications?name=CreativeCloud&n...
11/29/15 16:40:53:035 | [ERROR] | | ACC | LBS | PDM | PackageDownloadManager | | 69142 | Failed to Init PDM instance as the operation URL is empty
Any ideas?
That is your COMPUTER password asking you to verify that you have permission to make changes to the computer
Yes, I am aware of that. I entered my correct password. The application still hangs.....
Same Problem here !
i have the same issue...
First of all go to the .dmg file and try to give permissions to all the users to read and write and then try installing the file, if still you are not able to install the application try the following steps:-
1.open the ,dmg file
2.right click on intall file and select show package content>contents>MacOS>Install
after finding the install file launch TERMINAL via spotlight
3.Drag and drop the install file in terminal and press enter
your application will be installed.
Good Luck.
nope-still hangs.
