Hello,
I am a new contractor in a large organization and I am going to be sharing an RH8 license with another user who has already been using the license and working with another team of people. I'm concerned before I download it that I need to consider the preferences or decisions the other user made when installing. For example, did the person install the server with it? does it matter if it's RH for Word or RH HTML? Any warnings on this?
Not exactly sure what you mean by sharing the license - RH is installed on a machine with a license. If you have a user profile on that machine and the original installer installed RH to be accessible by all users of the machine, then you would see the shortcut(s) on your desktop. Only one of you would be using the software at one time, since only one of you could be logged in. The projects that you work on would be located in a place common to both of you (if you wanted to share the projects), otherwise, you would keep your projects in your own profile.
To avoid any misunderstanding, that common place must be the same hard disk, not a network location.
Hi there
From what I'm seeing, it would seem that you are expecting to download the software to your own PC and "share" the license that way.
You can get away with that to an extent, but you would be violating your agreement with Adobe. They intend for each license installed to be used by the same person. That license allows for installing and activating on two different machines. But the intent is to have one install at the workplace. Then another on either a laptop used by the same individual when traveling, or on their home PC so they might take work home.
Either way, the settings selected during one install won't have anything to do with the settings during the second.
Cheers... Rick
thank you, Rick. You read my mind. I don't intend to do this then. Thanks
for clarifying.
Gloria Ryan
Hi Gloria,
There is a way that you can even share the license and do not violate any agreement but this is only possible when both of you do not require to use RoboHelp simultaneously (Only one of you uses RoboHelp at a time), Adobe allows deactivating of a license on one machine and using the same license on another machine so one of you intends who wants to use the license can ask the other guy to deactivate it on his/her machine and activate using the same key and return the key when required vice-versa
But never try using this simultaneously or you will voilate the user agreement!
Hope this Helps
Ashish
Hi all
RobooAsh, as I understand it, this will only work a certain number of times before things stop cold and force the user to contact Adobe before allowing further activations.
Cheers... Rick
Can someone explain what the intent is to have 2 users on a license if the users can't use RH simultaneously?
Also, is the serial number separate from the RH8 disk? I recall at my last project that we had to search all over for documentation that included the serial number because it couldn't be found with the packaging. This was at a huge company where the purchasing department did the purchase and held the documentation with the serial number on it. It took a few weeks to locate and we were lucky we found the right person!!
Like many pieces of software it is there to allow the same person to have it on typically a desktop and a laptop so that the same person can work at home of offsite.
HI Luviola
Did you read the thread? I ask because I made an attempt at explaining just that.
My apologies, as I must have not been clear in what I wrote.
Cheers... Rick
yes, Rick, you are right. You did explain it well. I guess I just needed to
clarify it. We've decided to deactivate the first user and assign the
license to me; there won't be any back and forth.
I guess I was looking for other suggestions for using the second rights to
the license other than for just the one person, but perhaps everyone figures
it out for themselves for their own situations.
Gloria Ryan
