Hi, first of all, sorry for any misspelling, I'm Argentinian . I'm writing here because I've tried a LOT of ways and solutions to install Flash Player for IE, here some facts:
I mostly use Google Chrome, that has the FP already installed, but i have a problem with the ActiveX control, I can install Flash player 11 for windows but Not ActiveX... i read that that's a tool for IE, so i thought i wouldn't be needing it, but when i tried to execute a program (Game Ranger) it said that i needed ActiveX control and that i didn't have it in my computer.. So i started to check for solutions, etc etc. and finally give it up because i just couldn't do it, but well now I started again because I want to know if it's something important to have..
The problem when installing is this: It starts to download Flash Player.. then install it and when it's in 51% it stops and a message appears saying: registry error. this is what happens when I try to install ActiveX, not Flash Player itself because as I said earlier I can install it...
All I want to know is if there's some way to allow Flash Player installation to change registry values.. because i think that's the main problem.. i think. Thank you for reading.
Edit: Forgot to tell information about my system.
OS: Windows 7 32-bits
FINALLY FOUND THE SOLUTION!!
This is where I found it > http://forums.adobe.com/message/4086663#4086663
Finally, after 6 months I have installed ActiveX, thanks to that person that fixed it
Anyways, I'm grateful with you guys, I was impressed by the speed that you answered my question, thank you very much.
Windows
32 bit Flash Player for ActiveX (Internet Explorer)
Physically disconnect from the Internet and run the downloaded installer
Thanks for the help, I dont have too much time now so I'll try that in a few hours, then I will tell you what happened
To Pat: Thank you!! That's what I wanted to know, that i could not find in any place...
When I finish doing what Carl suggested i will also post that information.
Thanks a lot
If Carl's steps don't clear this up, you might want to give this FAQ a try in case we're dealing with a registry permission conflict:
Tried it. Same error, which is the last one in this page: http://kb2.adobe.com/es/cps/191/tn_19166.html#main_CommonErrors
As Pat said, here's the list all files there are in C:\Windows\system32\Macromed\Flash (after following Carl's instructions)
Flash32_11_2_202_228.ocx
FlashInstall.log
FlashPlayerUpdateService.exe
FlashUtil32_11_2_202_228_ActiveX.dll
FlashUtil32_11_2_202_228_ActiveX.exe
And here are the contents in the FlashInstall.log
=O====== M/11.1.102.62 2012-04-10+00-36-47.662 ========
0000 00000010 "C:\Users\User\Downloads\install_flash_player_ax_32bit (2).exe"
0001
0002
0003 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash11f.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11f_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil11f_ActiveX.dll
0008 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0009
0010 00000018
0011
=X====== M/11.1.102.62 2012-04-10+00-36-59.750 ========
=O====== M/11.1.102.62 2012-04-10+00-37-02.198 ========
0001
0002
0004
0009
0010
0011 00000018
0012
=X====== M/11.1.102.62 2012-04-10+00-37-07.486 ========
=O====== M/11.0.1.152 2012-04-10+00-37-09.663 ========
0000 00000010 "C:\Users\User\Downloads\InstallFlashPlayer[11.0.1.152].exe"
0001
0002
0003
0004
0005 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0006
0007
0008
0009
0010
0011
0012
0013
0014 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32.dll
0015 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11c_Plugin.exe
0016 00000017 C:\Windows\system32\Macromed\Flash
0017 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0018
=X====== M/11.0.1.152 2012-04-10+00-37-16.433 ========
=O====== M/11.1.102.62 2012-04-10+00-37-20.222 ========
0000 00000010 "C:\Users\User\Downloads\uninstall_flash_player_32bit (2).exe" -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
=X====== M/11.1.102.62 2012-04-10+00-37-23.884 ========
=O====== M/11.1.102.62 2012-04-10+00-37-24.761 ========
0001
0002
0003
0004
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash11f.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil11f_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil11f_ActiveX.dll
0010 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0011
0012 00000018
0013
=X====== M/11.1.102.62 2012-04-10+00-37-30.354 ========
=O====== M/11.1.102.62 2012-04-10+00-45-07.183 ========
0001
0002
0004
0009
0010
0011 00000018
0012
=X====== M/11.1.102.62 2012-04-10+00-45-13.035 ========
=O====== M/11.0.1.152 2012-04-10+00-45-15.075 ========
0001
0002
0003
0004
0006
0007
0008
0009
0010
0011
0012
0013
0018
=X====== M/11.0.1.152 2012-04-10+00-45-19.263 ========
=O====== M/11.2.202.228 2012-04-10+00-59-30.619 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/11.2.202.228 2012-04-10+00-59-30.937 ========
=O====== M/11.2.202.228 2012-04-10+00-59-19.313 ========
0000 00000010 "C:\Users\User\AppData\Local\Temp\install_flash_player_ax_32bit.exe" -iv 8 -install -au 0
0001
0002
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_228.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.dll
0009
0010 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0011
0012
0013
0014 00000018
0015
=X====== M/11.2.202.228 2012-04-10+00-59-31.574 ========
=O====== M/11.0.1.152 2012-04-10+01-04-33.190 ========
0000 00000010 "C:\Windows\System32\Macromed\Flash\FlashUtil11c_Plugin.exe"
=X====== M/11.0.1.152 2012-04-10+01-04-36.613 ========
=O====== M/11.2.202.228 2012-04-10+01-15-19.500 ========
=X====== M/11.2.202.228 2012-04-10+01-15-19.651 ========
=O====== M/11.2.202.228 2012-04-10+01-15-20.228 ========
=X====== M/11.2.202.228 2012-04-10+01-15-20.322 ========
=O====== M/11.2.202.228 2012-04-10+01-15-10.656 ========
0001
0002
0004
0009
0010
0011 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0012
0013
0014
0015
0016 00000018
0017
=X====== M/11.2.202.228 2012-04-10+01-15-20.875 ========
=O====== M/11.2.202.228 2012-04-12+00-14-07.450 ========
0000 00000010 "C:\Users\User\Downloads\uninstall_flash_player_32bit (4).exe" -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
0032
0033
=X====== M/11.2.202.228 2012-04-12+00-14-13.543 ========
=O====== M/11.2.202.228 2012-04-12+00-20-50.182 ========
0000 00000010 "C:\Users\User\Downloads\install_flash_player_ax_32bit (1).exe"
0001
0002
0003
0004
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_2_202_228.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.dll
0012
0013
0014
0015 00000018
0016
=X====== M/11.2.202.228 2012-04-12+00-21-31.245 ========
Chris: Thank you too. I will give that a try right now.
Some clarification: ActiveX is part of Internet Explorer, you cannot "install" it.
Flash Player is installed either
If you still have problems after following Carl's instructions above, please
Interesting, the script in the FAQ should have taken care of that for you too. Did you have to specifically add your username as a user with full access to the folder? Do you believe that the msi was key in your installation?
If you have a few minutes, I'd like to see what your permissions are so I can try and resolve this for other users. I've got a script in the following post that outputs the user permissions for these folders and files. You'd just need to run it once and send me the log.
I believe that what fixed the problem was the .MSI file, because I then realized that i didn't change any permission (but i thought i did).
So, what i think was more important is the installation via the .msi
I'll run that program and then send the log to your e-mail. Thanks!
Edit: Sorry! I forgot to say that i tried your solution Chris, but it didn't work either
Again thanks for you help
