Hello,
When I launch a new install of InDesign CS6, it crashes with this error detail from event viewer.:
Faulting application name: InDesign.exe, version: 8.0.0.370, time stamp: 0x4f72c3ee
Faulting module name: BIB.dll, version: 1.2.2.19553, time stamp: 0x4f3a00dc
Exception code: 0xc00000fd
Fault offset: 0x0000e508
Faulting process id: 0x1a18
Faulting application start time: 0x01cd9361dc004636
Faulting application path: C:\Program Files (x86)\Adobe\Adobe InDesign CS6\InDesign.exe
Faulting module path: C:\Program Files (x86)\Adobe\Adobe InDesign CS6\BIB.dll
Report Id: 4327293a-ff55-11e1-a5e7-7071bc1caa4c
This is on a Win7 x64 system, 6 core 3.33GHz + 24GB RAM. Other CS6 apps tested so far are working including Bridge, Premier Pro and Photoshop.
Watching the splash screen, the error comes up shortly after it says "Starting Up Service Registry."
This is installed in parallel with a previous CS3 install. InDesign CS3 is working fine.
Reading some other threads, I have tried:
1- launch using Run As Administrator option.
2- reinstall InDesign CS6
3- deleted C:\Users\<my user>\AppData\Local\Adobe\Indesign\Version 8.0 Folder
4- login as another <admin> user and try it
5- switched default printer per this: http://forums.adobe.com/thread/717953 (my default printer is in the shop, all other printers are virtual but they didn't help).
6- removed all plug-ins from InDesign\Plug-ins folder
7- tried replacing BIB.dll with that from another CS6 application
While attempting these fixes I have gotten a different error, now faulting in CoolType.dll. Per some other threads, I have deleted all non-system fonts from the fonts folder and still get an error in the same place, either referencing BIB.dll or CoolType.dll.
Below is the initial crash dump report from windows.
Thanks for any advice.
Glenn
Version=1
EventType=APPCRASH
EventTime=129922037798149895
ReportType=2
Consent=1
ReportIdentifier=ecd2715c-ff5a-11e1-a5e7-7071bc1caa4c
IntegratorReportIdentifier=ecd2715b-ff5a-11e1-a5e7-7071bc1caa4c
WOW64=1
Response.type=4
Sig[0].Name=Application Name
Sig[0].Value=InDesign.exe
Sig[1].Name=Application Version
Sig[1].Value=8.0.0.370
Sig[2].Name=Application Timestamp
Sig[2].Value=4f72c3ee
Sig[3].Name=Fault Module Name
Sig[3].Value=BIB.dll
Sig[4].Name=Fault Module Version
Sig[4].Value=1.2.2.19553
Sig[5].Name=Fault Module Timestamp
Sig[5].Value=4f3a00dc
Sig[6].Name=Exception Code
Sig[6].Value=c00000fd
Sig[7].Name=Exception Offset
Sig[7].Value=0000e430
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7601.2.1.0.256.48
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=db90
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=db907dd15c081028f80933f9c3e73bc5
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=461d
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=461db17cb723b284267116290159b876
UI[2]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\InDesign.exe
UI[3]=Adobe InDesign CS6 has stopped working
UI[4]=Windows can check online for a solution to the problem.
UI[5]=Check online for a solution and close the program
UI[6]=Check online for a solution later and close the program
UI[7]=Close the program
LoadedModule[0]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\InDesign.exe
LoadedModule[1]=C:\Windows\SysWOW64\ntdll.dll
LoadedModule[2]=C:\Windows\syswow64\kernel32.dll
LoadedModule[3]=C:\Windows\syswow64\KERNELBASE.dll
LoadedModule[4]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\ObjectModel.dll
LoadedModule[5]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\PMRuntime.dll
LoadedModule[6]=C:\Windows\syswow64\PSAPI.DLL
LoadedModule[7]=C:\Windows\system32\dbghelp.dll
LoadedModule[8]=C:\Windows\syswow64\msvcrt.dll
LoadedModule[9]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\tbb.dll
LoadedModule[10]=C:\Windows\system32\MSVCP100.dll
LoadedModule[11]=C:\Windows\system32\MSVCR100.dll
LoadedModule[12]=C:\Windows\syswow64\USER32.dll
LoadedModule[13]=C:\Windows\syswow64\GDI32.dll
LoadedModule[14]=C:\Windows\syswow64\LPK.dll
LoadedModule[15]=C:\Windows\syswow64\USP10.dll
LoadedModule[16]=C:\Windows\syswow64\ADVAPI32.dll
LoadedModule[17]=C:\Windows\SysWOW64\sechost.dll
LoadedModule[18]=C:\Windows\syswow64\RPCRT4.dll
LoadedModule[19]=C:\Windows\syswow64\SspiCli.dll
LoadedModule[20]=C:\Windows\syswow64\CRYPTBASE.dll
LoadedModule[21]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Database.dll
LoadedModule[22]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Public.dll
LoadedModule[23]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\ACE.dll
LoadedModule[24]=C:\Windows\syswow64\SHELL32.dll
LoadedModule[25]=C:\Windows\syswow64\SHLWAPI.dll
LoadedModule[26]=C:\Windows\syswow64\ole32.dll
LoadedModule[27]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\BIB.dll
LoadedModule[28]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\CoolType.dll
LoadedModule[29]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\MPS.dll
LoadedModule[30]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\AGM.dll
LoadedModule[31]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\ARE.dll
LoadedModule[32]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\BIBUtils.dll
LoadedModule[33]=C:\Windows\syswow64\WS2_32.dll
LoadedModule[34]=C:\Windows\syswow64\NSI.dll
LoadedModule[35]=C:\Windows\system32\MPR.dll
LoadedModule[36]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\AFL.dll
LoadedModule[37]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\icuuc40.dll
LoadedModule[38]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\icudt40.dll
LoadedModule[39]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\icuin40.dll
LoadedModule[40]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\amtlib.dll
LoadedModule[41]=C:\Windows\system32\WINHTTP.dll
LoadedModule[42]=C:\Windows\system32\webio.dll
LoadedModule[43]=C:\Windows\syswow64\SETUPAPI.dll
LoadedModule[44]=C:\Windows\syswow64\CFGMGR32.dll
LoadedModule[45]=C:\Windows\syswow64\OLEAUT32.dll
LoadedModule[46]=C:\Windows\syswow64\DEVOBJ.dll
LoadedModule[47]=C:\Windows\system32\IPHLPAPI.DLL
LoadedModule[48]=C:\Windows\system32\WINNSI.DLL
LoadedModule[49]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\adobe_caps.dll
LoadedModule[50]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\boost_filesystem.dll
LoadedModule[51]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\boost_system.dll
LoadedModule[52]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\boost_regex.dll
LoadedModule[53]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\icucnv40.dll
LoadedModule[54]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\ASLSupport.dll
LoadedModule[55]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\WRServices.dll
LoadedModule[56]=C:\Windows\syswow64\COMDLG32.dll
LoadedModule[57]=C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\COMCTL32.dll
LoadedModule[58]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\WidgetBin.dll
LoadedModule[59]=C:\Windows\syswow64\IMM32.dll
LoadedModule[60]=C:\Windows\syswow64\MSCTF.dll
LoadedModule[61]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\AdobeOwl.dll
LoadedModule[62]=C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.17825_none_72d273598668a06b\gdiplus.dll
LoadedModule[63]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\AdobeOwlCanvas.dll
LoadedModule[64]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\adbeape.dll
LoadedModule[65]=C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\MSVCR90.dll
LoadedModule[66]=C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\MSVCP90.dll
LoadedModule[67]=C:\Windows\system32\uxtheme.dll
LoadedModule[68]=C:\Windows\system32\profapi.dll
LoadedModule[69]=C:\Windows\syswow64\CLBCatQ.DLL
LoadedModule[70]=C:\Windows\system32\propsys.dll
LoadedModule[71]=C:\Windows\system32\ntmarta.dll
LoadedModule[72]=C:\Windows\syswow64\WLDAP32.dll
LoadedModule[73]=C:\Windows\system32\dwmapi.dll
LoadedModule[74]=C:\Windows\system32\CRYPTSP.dll
LoadedModule[75]=C:\Windows\system32\rsaenh.dll
LoadedModule[76]=C:\Windows\system32\RpcRtRemote.dll
LoadedModule[77]=C:\Windows\system32\apphelp.dll
LoadedModule[78]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\updaternotifications.dll
LoadedModule[79]=C:\Windows\system32\NETAPI32.dll
LoadedModule[80]=C:\Windows\system32\netutils.dll
LoadedModule[81]=C:\Windows\system32\srvcli.dll
LoadedModule[82]=C:\Windows\system32\wkscli.dll
LoadedModule[83]=C:\Windows\system32\ATMLIB.dll
LoadedModule[84]=C:\Windows\system32\mscms.dll
LoadedModule[85]=C:\Windows\system32\USERENV.dll
LoadedModule[86]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\ACTIONS.RPLN
LoadedModule[87]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\AXE8SharedExpat.dll
LoadedModule[88]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\APPFRAMEWORK.RPLN
LoadedModule[89]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\boost_threads.dll
LoadedModule[90]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\boost_date_time.dll
LoadedModule[91]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\APPLICATION UI.RPLN
LoadedModule[92]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\ScCore.dll
LoadedModule[93]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\LogSession.dll
LoadedModule[94]=C:\Windows\system32\VERSION.dll
LoadedModule[95]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\ExtendScript.dll
LoadedModule[96]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\ARTICLE.RPLN
LoadedModule[97]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\ASSIGNMENTS.RPLN
LoadedModule[98]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\AWS.RPLN
LoadedModule[99]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\AWSUI.RPLN
LoadedModule[100]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\BASIC TOOLS.RPLN
LoadedModule[101]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\BEHAVIOR.RPLN
LoadedModule[102]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\BNCORE.RPLN
LoadedModule[103]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\BOOK.RPLN
LoadedModule[104]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\CELLSTYLES.RPLN
LoadedModule[105]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\CJK TEXT ATTRIBUTES.RPLN
LoadedModule[106]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\CJKGRID.RPLN
LoadedModule[107]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\COLOR MANAGEMENT.RPLN
LoadedModule[108]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\COMPFONTMGR.RPLN
LoadedModule[109]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\CONDITIONALTEXT.RPLN
LoadedModule[110]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\CONTENTDROPPER.RPLN
LoadedModule[111]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\DIALOG LAYOUT.RPLN
LoadedModule[112]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\DOCUMENT ACTIONS.RPLN
LoadedModule[113]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\DOCUMENT FRAMEWORK.RPLN
LoadedModule[114]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\DOCUMENT UI.RPLN
LoadedModule[115]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\DYNAMICDOCUMENTS.RPLN
LoadedModule[116]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\ADBE_AGMFL.dll
LoadedModule[117]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\aflamingo.dll
LoadedModule[118]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\EPS PAGE ITEM.RPLN
LoadedModule[119]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\FONT MANAGER.RPLN
LoadedModule[120]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\FORMFIELD.RPLN
LoadedModule[121]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\GALLEY.RPLN
LoadedModule[122]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\GALLEYUI.RPLN
LoadedModule[123]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\GENERIC PAGE ITEM.RPLN
LoadedModule[124]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\GENERICSETTINGS.RPLN
LoadedModule[125]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\GLOBAL PREFERENCES PANEL.RPLN
LoadedModule[126]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\GRADIENT FILL.RPLN
LoadedModule[127]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\GRAPHICS.RPLN
LoadedModule[128]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\GROUP.RPLN
LoadedModule[129]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\GUIDES.RPLN
LoadedModule[130]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\HTMLPGT.RPLN
LoadedModule[131]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\HYPERLINKS.RPLN
LoadedModule[132]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\IMAGE FILTERS.RPLN
LoadedModule[133]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\IMAGE.RPLN
LoadedModule[134]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\IME.RPLN
LoadedModule[135]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\IMPORT EXPORT UI.RPLN
LoadedModule[136]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\INCOPYSHARED.RPLN
LoadedModule[137]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\INCOPYSHAREDUI.RPLN
LoadedModule[138]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\INCOPYWORKFLOW.RPLN
LoadedModule[139]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\INDEXING.RPLN
LoadedModule[140]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\INXCORE.RPLN
LoadedModule[141]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\LAYER.RPLN
LoadedModule[142]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\LAYOUT UI.RPLN
LoadedModule[143]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\LAYOUT.RPLN
LoadedModule[144]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\LINGUISTICS.RPLN
LoadedModule[145]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\LINKS.RPLN
LoadedModule[146]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\AdobeXMP.dll
LoadedModule[147]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\AdobeXMPFiles.dll
LoadedModule[148]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\MASTER PAGE.RPLN
LoadedModule[149]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\MEDIA.RPLN
LoadedModule[150]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\METADATA DATABASE FILTER.RPLN
LoadedModule[151]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\METADATA.RPLN
LoadedModule[152]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\MOVIE.RPLN
LoadedModule[153]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\OPEN PLACE.RPLN
LoadedModule[154]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\PARAGRAPH COMPOSER.RPLN
LoadedModule[155]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\PATH TYPE.RPLN
LoadedModule[156]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\PathTypeLib.dll
LoadedModule[157]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\PDF.RPLN
LoadedModule[158]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\PDFPort.dll
LoadedModule[159]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\JP2KLib.dll
LoadedModule[160]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\pdfsettings.dll
LoadedModule[161]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\PHOTOSHOP IMPORT FILTER.RPLN
LoadedModule[162]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\AdobePSL.dll
LoadedModule[163]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\tbbmalloc.dll
LoadedModule[164]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\PNG IMPORT FILTER.RPLN
LoadedModule[165]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\PRINT.RPLN
LoadedModule[166]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\RULERS.RPLN
LoadedModule[167]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\SCRIPTING.RPLN
LoadedModule[168]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\SECTIONS.RPLN
LoadedModule[169]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\SHAREDCONTENT.RPLN
LoadedModule[170]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\SOUND.RPLN
LoadedModule[171]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\SPELLING SERVICE.RPLN
LoadedModule[172]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\SPLINE UI.RPLN
LoadedModule[173]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\SPLINE.RPLN
LoadedModule[174]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\SPREAD UI.RPLN
LoadedModule[175]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\SPREAD.RPLN
LoadedModule[176]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\STROKE AND FILL.RPLN
LoadedModule[177]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\SUPPORT FOR JAVASCRIPT.RPLN
LoadedModule[178]=C:\Windows\syswow64\WININET.dll
LoadedModule[179]=C:\Windows\syswow64\urlmon.dll
LoadedModule[180]=C:\Windows\syswow64\CRYPT32.dll
LoadedModule[181]=C:\Windows\syswow64\MSASN1.dll
LoadedModule[182]=C:\Windows\syswow64\iertutil.dll
LoadedModule[183]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\TABLE MODEL.RPLN
LoadedModule[184]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\TABLESTYLES.RPLN
LoadedModule[185]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\TEXT ATTRIBUTES.RPLN
LoadedModule[186]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\TEXT EDITOR MODEL.RPLN
LoadedModule[187]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\TEXT EDITOR.RPLN
LoadedModule[188]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\TEXT WALKER.RPLN
LoadedModule[189]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\TEXT WRAP PATH.RPLN
LoadedModule[190]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\TEXT WRAP.RPLN
LoadedModule[191]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\TEXT.RPLN
LoadedModule[192]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\TOC.RPLN
LoadedModule[193]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\TRANSPARENCY.RPLN
LoadedModule[194]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\UTILITIES.RPLN
LoadedModule[195]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\WIDGETS.RPLN
LoadedModule[196]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\WORKGROUP CLIENT UI.RPLN
LoadedModule[197]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\WORKGROUP CLIENT.RPLN
LoadedModule[198]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\WORKGROUP.RPLN
LoadedModule[199]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\WORLDREADY.RPLN
LoadedModule[200]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\XML.RPLN
LoadedModule[201]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\AXEDOMCore.dll
LoadedModule[202]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Required\XMLPARSER.RPLN
LoadedModule[203]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\AXSLE.dll
LoadedModule[204]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\DATA SERVICES\DATA SERVICES UI.APLN
LoadedModule[205]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\DATA SERVICES\DATA SERVICES.APLN
LoadedModule[206]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\DATA SERVICES\TRANSFORMS\DTTRANSFORM.APLN
LoadedModule[207]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\DICTIONARIES\DICTIONARY EDITOR DIALOG.APLN
LoadedModule[208]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\TextPanelLib.dll
LoadedModule[209]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\DICTIONARIES\LILO\LILO.APLN
LoadedModule[210]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\AdobeLinguistic.dll
LoadedModule[211]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\FILTERS\EBOOKEXPORT.APLN
LoadedModule[212]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\FILTERS\MEDIA IMPORT FILTER.APLN
LoadedModule[213]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\FILTERS\PNG IMPORT FILTER UI.APLN
LoadedModule[214]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\FILTERS\SANGAM PREFERENCES UI.APLN
LoadedModule[215]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Sangam.dll
LoadedModule[216]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\FILTERS\SANGAMEXPORT.APLN
LoadedModule[217]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\FILTERS\SANGAMSERVICER-MAPPER.APLN
LoadedModule[218]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\FILTERS\SAVEBACK.APLN
LoadedModule[219]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\FILTERS\TAGGED TEXT ATTRIBUTES.APLN
LoadedModule[220]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\FILTERS\TAGGED TEXT FILTERS UI.APLN
LoadedModule[221]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\FILTERS\TAGGED TEXT FILTERS.APLN
LoadedModule[222]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\CLIPPING PATH DIALOG.APLN
LoadedModule[223]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\COLOR MANAGEMENT UI.APLN
LoadedModule[224]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\COLOR PICKER PANEL.APLN
LoadedModule[225]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\DYNAMICDOCUMENTSUI.APLN
LoadedModule[226]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\EPS UI.APLN
LoadedModule[227]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\GENERIC STYLE EDITOR.APLN
LoadedModule[228]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\GRADIENT PANEL.APLN
LoadedModule[229]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\GRAPHIC PANELS.APLN
LoadedModule[230]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\JPEG EXPORT UI.APLN
LoadedModule[231]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\JPEG EXPORT.APLN
LoadedModule[232]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\OUTPUT PREVIEW.APLN
LoadedModule[233]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\OUTPUTMISCUI.APLN
LoadedModule[234]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\PDF UI.APLN
LoadedModule[235]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\PRINTER STYLES.APLN
LoadedModule[236]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\PRINTUI.APLN
LoadedModule[237]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\PS IMPORT UI.APLN
LoadedModule[238]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\SVG EXPORT.APLN
LoadedModule[239]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\svgexport.dll
LoadedModule[240]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\SWATCH LIBRARY PANEL.APLN
LoadedModule[241]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\SWATCHES PANEL.APLN
LoadedModule[242]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\GRAPHICS\TRANSPARENCY UI.APLN
LoadedModule[243]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\INCOPYWORKFLOW\ASSIGNMENT UI.APLN
LoadedModule[244]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\INCOPYWORKFLOW\INCOPY BRIDGE UI.APLN
LoadedModule[245]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\INCOPYWORKFLOW\INCOPY BRIDGE.APLN
LoadedModule[246]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\INCOPYWORKFLOW\INCOPYEXPORT.APLN
LoadedModule[247]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\INCOPYWORKFLOW\INCOPYEXPORTUI.APLN
LoadedModule[248]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\INCOPYWORKFLOW\INCOPYIMPORT.APLN
LoadedModule[249]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\INCOPYWORKFLOW\INCOPYWORKFLOW UI.APLN
LoadedModule[250]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\INCOPYWORKFLOW\NOTE.APLN
LoadedModule[251]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\INCOPYWORKFLOW\NOTEPREF.APLN
LoadedModule[252]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\INCOPYWORKFLOW\USERNAME UI.APLN
LoadedModule[253]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\INTERACTIVE\BUTTONUI.APLN
LoadedModule[254]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\INTERACTIVE\MEDIAUI.APLN
LoadedModule[255]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\ALIGNMENT PANEL.APLN
LoadedModule[256]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\ASSET LIBRARY PANEL.APLN
LoadedModule[257]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\ASSET PUBLIBRARY.APLN
LoadedModule[258]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\BOOK PANEL.APLN
LoadedModule[259]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\BOOKMARK PANEL.APLN
LoadedModule[260]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\CONTENTDROPPER TOOL.APLN
LoadedModule[261]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\CONTROL PANEL.APLN
LoadedModule[262]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\CREATE GUIDES DIALOG.APLN
LoadedModule[263]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\EYEDROPPER TOOL.APLN
LoadedModule[264]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\HYPERLINKS PANEL.APLN
LoadedModule[265]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\INDEX PANEL.APLN
LoadedModule[266]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\unihan.dll
LoadedModule[267]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\INFO PANEL.APLN
LoadedModule[268]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\KNOWLEDGE BASE.APLN
LoadedModule[269]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\LAYERS PANEL.APLN
LoadedModule[270]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\LAYOUT ADJUSTMENT PANEL.APLN
LoadedModule[271]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\LAYOUT ADJUSTMENT.APLN
LoadedModule[272]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\LINKS UI.APLN
LoadedModule[273]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\PAGE SETUP DIALOG.APLN
LoadedModule[274]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\PAGES PANEL.APLN
LoadedModule[275]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\SECTIONS UI.APLN
LoadedModule[276]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\STEPREPEAT.APLN
LoadedModule[277]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\TEXT WRAP PANEL.APLN
LoadedModule[278]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\TOC UI DIALOG.APLN
LoadedModule[279]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\LAYOUT\TRANSFORM PANEL.APLN
LoadedModule[280]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\PAGE ITEM\IMAGE IMPORT UI.APLN
LoadedModule[281]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\PAGE ITEM\SCOTCH RULES.APLN
LoadedModule[282]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\PMPACK\BNUI.APLN
LoadedModule[283]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\PMPACK\DATAMERGE.APLN
LoadedModule[284]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\PMPACK\DATAMERGEUI.APLN
LoadedModule[285]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\PMPACK\PMWELCOMESCREEN.APLN
LoadedModule[286]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\PREPRESS\PACKAGE AND PREFLIGHT UI.APLN
LoadedModule[287]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\PREPRESS\PACKAGE AND PREFLIGHT.APLN
LoadedModule[288]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\SANDBOX\JBX.APLN
LoadedModule[289]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\SCRIPT\SCRIPT LABEL PANEL.APLN
LoadedModule[290]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\SCRIPT\SCRIPTS PANEL.APLN
LoadedModule[291]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\SCRIPT\SUPPORT FOR VISUAL BASIC.APLN
LoadedModule[292]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TABLES\TABLES UI.APLN
LoadedModule[293]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TABLES\TABLESTYLESUI.APLN
LoadedModule[294]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\CHARACTER PANEL.APLN
LoadedModule[295]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\CONDITIONALTEXT UI.APLN
LoadedModule[296]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\CREATE OUTLINES.APLN
LoadedModule[297]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\FIND AND CHANGE PANEL.APLN
LoadedModule[298]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\FIND CHANGE FORMAT PANEL.APLN
LoadedModule[299]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\FONT USAGE DIALOG.APLN
LoadedModule[300]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\GLYPHS PANEL.APLN
LoadedModule[301]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\HYPHENATION PANEL.APLN
LoadedModule[302]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\INDENTS AND TABS.APLN
LoadedModule[303]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\JUSTIFICATION PANEL.APLN
LoadedModule[304]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\KEEPS PANEL.APLN
LoadedModule[305]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\OPTICAL KERNING.APLN
LoadedModule[306]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\PARAGRAPH PANEL.APLN
LoadedModule[307]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\PARAGRAPH RULES PANEL.APLN
LoadedModule[308]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\PATH TYPE UI.APLN
LoadedModule[309]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\RUNIN STYLES PANEL.APLN
LoadedModule[310]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\SING.APLN
LoadedModule[311]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\SPANCOLUMNS PANEL.APLN
LoadedModule[312]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\SPELLING PANEL.APLN
LoadedModule[313]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\STORY PANEL.APLN
LoadedModule[314]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\STYLE PANEL.APLN
LoadedModule[315]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\TEXT COLOR PANEL.APLN
LoadedModule[316]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\TEXT FRAME OPTIONS.APLN
LoadedModule[317]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\TEXT PANEL.APLN
LoadedModule[318]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\TEXT PREFERENCES.APLN
LoadedModule[319]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\TEXT RULER.APLN
LoadedModule[320]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\TEXT\TEXT STYLE PANEL.APLN
LoadedModule[321]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\ARTICLEPANEL.APLN
LoadedModule[322]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\CSXS.APLN
LoadedModule[323]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\PlugPlug.dll
LoadedModule[324]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\GALLEY PREFERENCES.APLN
LoadedModule[325]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\GAPTOOL.APLN
LoadedModule[326]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\GENERAL PREFERENCES PANEL.APLN
LoadedModule[327]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\HELP.APLN
LoadedModule[328]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\ahclient.dll
LoadedModule[329]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\OBJECTSTYLESUI.APLN
LoadedModule[330]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\PERFORMANCE UI.APLN
LoadedModule[331]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\SHAREDCONTENTUI.APLN
LoadedModule[332]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\SHORTCUT EDITOR DIALOG.APLN
LoadedModule[333]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\TOOL BOX.APLN
LoadedModule[334]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\TOOL TIPS.APLN
LoadedModule[335]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\TRACK CHANGES PREFERENCES.APLN
LoadedModule[336]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UI\TRACK CHANGES UI.APLN
LoadedModule[337]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\UTILITY\PERFORMANCEMETRICS.APLN
LoadedModule[338]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\WORKFLOW\METADATA UI.APLN
LoadedModule[339]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\FileInfo.dll
LoadedModule[340]=C:\Windows\system32\MSIMG32.dll
LoadedModule[341]=C:\Windows\system32\WINMM.dll
LoadedModule[342]=C:\Windows\system32\OLEACC.dll
LoadedModule[343]=C:\Windows\system32\WINSPOOL.DRV
LoadedModule[344]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\WORKGROUP\WORKGROUP UI.APLN
LoadedModule[345]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\XMEDIA\SNIPPET.APLN
LoadedModule[346]=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\Plug-ins\XMEDIA\XMEDIA UI.APLN
FriendlyEventName=Stopped working
ConsentKey=APPCRASH
AppName=Adobe InDesign CS6
AppPath=C:\Program Files (x86)\Adobe\Adobe InDesign CS6\InDesign.exe
Windows crash reports are pretty much useless.
I hate to say this, but I think you should uninstall again, then run the clean tool (CS Cleaner Tool for installation problems | CCM, CS6, CS5.5, CS5, CS4, CS3) and reboot, logging in on the real Adminstrator account (you may have to enable this -- see http://www.sevenforums.com/tutorials/507-built-administrator-account-enable-disable.html) then run MSconfig (the system configuration utility) and turn off all non -essential startup programs and non-essential services, escpecially anthing to do with virus or malware scanners, third-party firewall, iTunes, browser helpers or toolbars and instant messengers, then reboot again.
If you you see a warning about running inDiagnostic mode continue. If you wind up back in the config utility, just click the cancel button. Run the installer again, then run MSconfig again and restore normal startup and reboot. See if ID works...
If all is well you can disable the Administrator account again if you like.
Hi Peter,
Thank you for the suggestion and your quick response. After a few attempts I was able to get just the essential services by only disabling non-microsoft services, and was able to get a completely error free install according to the install log. I carefully followed your instructions, but even after the final error free attempt, InDesign still crashes at the same point during launch. The current error I get is this, but it still alternates between CoolType.dll and BIB.dll, but always crashes at the point: Starting Up Service Registry.
Problem signature:
Problem Event Name: APPCRASH
Application Name: InDesign.exe
Application Version: 8.0.0.370
Application Timestamp: 4f72c3ee
Fault Module Name: CoolType.dll
Fault Module Version: 5.10.64.19354
Fault Module Timestamp: 4f207049
Exception Code: c00000fd
Exception Offset: 0004a105
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 2bbe
Additional Information 2: 2bbea8506d157ba982953ef4be6281aa
Additional Information 3: 43e0
Additional Information 4: 43e0dc7cbbc9459b4f72850a498b83f3
I'm sorry to hear that.
I'm not sure what BIB does, but CoolType is part of the font rendering engine, I believe. Do you have a font manager installed? Any other third-party plugins? Any fonts from free font sites?
It was painful but good to finally get a clean install of all the other programs. It was really just acrobat that failed previously, but some others had warnings.
I do not have any font manager installed, and no third party plug-ins. As for fonts....
I had a rather large set of fonts previously installed, 1500ish. I can't specifically think of any from free sites but there may be a couple.
Since this started, I have attempted to remove all fonts that windows will let me delete, assuming those are the required system fonts. I've also added the adobe recommended fonts back in, thinking they may help.
This may be interesting or a red herring:
I found this in my registry - in the fonts list. [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts]
"Generic (TrueType)"="C:\\Program Files (x86)\\Common Files\\Adobe\\SING\\AssocCache\\Generic.otf"
It does not appear in my Fonts folder and I have renamed the SING folder so I tried removing this key and reinstalling the font from the file. I get an error from windows stating its not a valid font.
I am able to open and view all the other fonts in the fonts folder, for what that's worth.
Glenn
I think it's a red herring, but my entry is just a little different from yours in the path statement: C:\Program Files (x86)\Common Files\Adobe\SING\Mark II\Generic.otf
And I don't have any other good ideas at the moment...
Is your generic.otf a valid font file? Can you double click it and see the font?
No.
I guess it is a red herring. I'm stuck too. I'll try Adobe support tomorrow afternoon.
I really appreciate your time over this weekend. Thank you.
If you get it solved, please let us know what the problem turns out to be. I have a feeling there are others in the same circumstance.
Will Do.
SOLVED FOR ME! Hopefully this will work for you...
ERROR:
InDesign hangs on "Starting Up Service Registry..." followed by a Windows Error Box saying that "Adobe InDesign CS6 has stopped working."
WORKING SOLUTION:
I've been having the same InDesign crash on startup all day and after trying and failing at just about every suggested fix I was able to find a solution. Essentially, this all boiled down to a corrupted font that I had installed on my system (Win X64). I went into my font manager and disabled all the fonts that I had installed, which left only the system fonts, ran InDesign and it started up perfectly. This makes sense since InDesign is so dependent on font files for it to run properly. You'd figure Adobe would at least update the app to include some kind of diagnostic to detect something like this, but I'm just happy it's fixed.
If you are running a font manager, just uninstall/deactivate any manually installed fonts. If it works for you then you can start turning on font sets to isolate the corrupted font from there.
A FEW OF MY PREVIOUSLY FAILED SOLUTIONS FOR REFERENCE:
PS. Adobe's knowledge seems to be highly deficient in this issue and after spending over 2 hours on a live chat and messing up my system with new Win7 user accounts and software uninstall/installs I came to this solution independent of them. They will most likely send you on a wild goose chase if your problem is similar to this. I recommend trying the forum-posted solutions first.
Thank you both for your replies. This was a painful issue to resolve. I worked with Adobe support over three different calls. I received different advice at each call but the successful process in the end was to completly uninstall and further delete all traces of adobe software and reinstalling again. I had CS3 installed and was told that it is incompatible with Windows 7 (though its been running on my desktop and laptop without trouble for years.)
So what I did was to first uninstall pretty much everything starting with Adobe in my Uninstall Programs control panel.
Then, per adobe support, I proceded to delete files/keys from these locations manually. Not all of them existed. I also included Program Files (x86) where any Program Files paths are listed. (Note: AdobeCreativeSuiteCleanerTool does NOT remove all traces of files and keys!)
C:\Program Files\Adobe*
C:\Program Files\Common Files\Adobe*
C:\Program Files\Common Files\Macrovision Shared\FlexNet*
C:\Program Data\Adobe*
C:\Program Data\FlexNet*
C:\Users\All Users\Adobe*
HKEY_LOCAL_MACHINE\Software\Adobe*
HKEY_CURRENT_USER\Software\Adobe*
HKEY_LOCAL_MACHINE\SOFTWARE\Macrovision\FLEXnet Publisher*
I rebooted and installed again and it worked.
During this process I discovered what I believe may have been the actual cause. Under one of the above paths was another InDesign\Fonts folder loaded with fonts. Sorry, I do not recall which as I have since had a hard disc failure and had to really start over. I thought I had done a search of fonts but apparently had not done such a good job. I recall now having trouble getting my fonts (installed in windows/fonts) to appear in InDesign CS3 and the workaround was to place a copy in this folder. I the end, I believe I had a copy of a corrupted font in that folder.
My recommendation to anyone else struggling with this problem is to (1) remove all fonts from the windows/fonts folder and (2) to check the above paths for any fonts you may have added and remove them, and (3) check the above paths for any remaining fonts and verify they are not corrupt by opening them to preview. Remove anything corrupt. If all else fails, (4) follow uninstall procedure described above.
CS3 runs just fine on Windows 7. If you need it, though, you'll want to uninstall everything again and reinstall in chronological order.
