I found the problem was my Total Defense Internet Security Suite, (formerly Computer Associates Internet Security Suite)
After total removal of that program, Flash works fine.
If you use Internet Explorer, try
I do not use I.E. and only mentioned it so the reader would see that the
problem was the same for both I.E. and Firefox.
Never the less I tried both suggestions and neither helped.
Thanks anyway.
Pat,
I do not use I.E. and only mentioned it so the reader would see that the problem was the same for both I.E. and Firefox.
Thanks anyway.
Pat,
Thanks anyway.
Not sure what is causing this...
Can you see the Flash animation at http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html ?
If not, can you tell me what files you have in C:\Windows\system32\Macromed\Flash ?
Also, can you post the contents of file FlashInstall.log in that same folder?
Pat
No, there is no animation but Adobe says it is installed.
As stated on my original post, I have uninstalled and reinstalled more than once. Each time Adobe says I have successfully installed Flash but there is never an animation on either the Adobe site or any other site.
Sometimes when attempting to watch a YouTube Video, like the Scorpions performing Drive by the Cars (awesome acoustical version) it will not play unless I disable Flash. Then trying to play a different video it says I need flash so I re-enable flash and it doesn't work. In case you are wondering, the video that says I need flash did not work before I disabled flash and it did not work after re-enabling flash.
Before writing this reply I completely uninstalled flash following the instructions on Adobe site and then reinstalled flash and it's the same as usual. Adobe says it's installed but no animation and still have the same problems with web videos.
This all started a couple weeks ago. Before that I had not problem.
Larry
Pat
No, there is no animation.
is never an animation on either the Adobe site or anyother site.
Larry
Pat
Larry
