Premier Pro CS6 Question.....
Why do my photos and text disinigrate quality when imported to premier pro cs6?
I have still shots that have text and they look clean and crisp when I view them in photoshop. Why does the photo and text look so fuzzy or blurry and not crisp when I import the still files into premier pro cs6?
Is there a setting in premier that I am setting incorrectly? That is possibly blurring my photos and text? The problem appears in both my PR file and my final exported work.
Is there a way to retain the quality of the image and text that I see in my photoshop file?
Note: I am not enlarging anything after import, I am reducing though, but I would think this would only make images and text sharper????
Any help would be greatly appreciated, Im getting tired of doing all my work and delivering blurry / fuzzy / what appears to be low resolution images and text when I complete my project.
Thanks in advance for any help offered.
Use Photoshop to resize pictures before using in Premiere
Photo Scaling for Video http://forums.adobe.com/thread/450798
And, another benefit of resizing
-Too Large May = Crash http://forums.adobe.com/thread/879967
-And another crash report http://forums.adobe.com/thread/973935
Tried resizing in photoshop, still looks pretty crappy, not even close to the sharpness in original file.
I will gather the settings asked about below and send those to you for thoughts, give me a few, working on 2 computers, getting dizzy. :O)
What are the specs of the stills? What sequence settings did you use? What export settings?
Hi Jim, thanks so much again for chiming in to my questions.
Specs of Stills - Photoshop file - 677 x 1014px, 150dpi, 1.96M file size, 150dpi, this is the size of the file I originally imported and reduced to approx. 65%, the one sized properly in photoshop imported fuzzier.
Sequence Settings -
Export Settings, FLV, attached are settings.
1. EXPORT FILTER SETTINGS...
2. EXPORT FORMAT SETTINGS
3. EXPORT VIDEO SETTINGS
FINAL PROJECT IS DELIVERY OF FLV FILE TO EMBED IN INTERACTIVE FILE. Ive tried different settings for different jobs, just feel all text and photos fall apart when pulled into and exported to FLV for embedding final.
Ive done several slideshow and video's in premier pro, have so much to learn still, Im thinking I keep diving into my projects and possibly making a total mess out of my settings for the desired final destination? is this possible?
Sequence Settings - Export Settings, FLV, attached are settings.
Eeesh, no wonder it looks bad.
Is there any video involved, or just the stills?
LOL. just stills on this job. I think I just dont understand the setting thing. LOL. Ok, be easy on me, can you help me figure out what is the best to use as a standard and maybe I could stick with that for the most part????
It sounds like if I have the right settings this could actually look the way its supposed to, maybe, if Im lucky????? :O)
Stills only makes this a bit easier to fix.
Is 512 x 288 the correct dimensions you want to end up with?
I would probably be better off working in the larger format ??? since the stills are being reduced approx. 60% when imported, so if I go to larger dimension it would allow for wiggle room for pop up size when embedded, I think anyway.
I just exported this at that size b/c I wanted it smaller to see if it would sharpen any.... NOT!
Is there a standard form to refer to for settings and exports out there that make any sense for the specific job and size you are working on?
I really appreciate your time in helping on this, my coworker is not very happy with me right now. :O(
The desired end result will often determine how you do the job, especially when there's no actual video involved. So...what do you want to end up with here, and how will it be used? Be specific.
ok, I want to end up with 720 x 480.
Export will need to be FLV file which will ultimately embed into an interactive pdf file for viewing.
Any other info needed let me know. Thanks, your wonderful for offering me your time on this.
Maybe you can tell me how to know what the specifics are that you set so I could know how to do this for all future job settings and exports?
Good.
Start by resizing the images in Photoshop so that their vertical dimension matches what we'll be doing, in this case 480.
Next, create a new DV 24p sequence (Standard 48 KHz) and add the stills to that. Work as needed.
For export choose the FLV option with the Match Source Attributes (High Quality) preset.
Report back the results.
Hi Jim,
I have to break and head to dr. appt. I sure hope you will see my response when I return, thanks so much, Hope its my solution. Looks promising.
I'm here most every day.
Hi Jim, not sure my end result is any better than what I originally was doing, in spite of poor settings on my part, still falling apart.
Can I e-mail you a sample of the file embedded into a pdf file so you can see how bad image and text look?
Your thoughts would be greatly appreciated if I can send to you so you can see.
Like I said, the files are crisp as can be in photoshop, even resized to needed size for premier import.
I followed your steps from the beginning, Just still not happy at all with results.... STILL. ugggghhhhh!
Send me a link to the FLV export, without embedding into a PDF.
Hi Jim, sent the file, let me know if it made it to you via the upload link you provided.
file name is sequence1.flv
You have to send me the link you got when you uploaded.
sorry, I think this is the link you need.
url: http://depositfiles.com/files/1nve3b1r2
forum: http://depositfiles.com/files/1nve3b1r2[/URL]
Blog: http://depositfiles.com/files/1nve3b1r2
link: http://depositfiles.com/rmv/0711171774631088
Let me know if you are able to locate it, name is Sequence_01.flv
thanks, Amy
OK, something went wrong. Your export came out as 656 x 480 instead of 720 x 480. I wonder if that's a limitation of the format.
Does it need to be an FLV file?
Hi Jim,
Yes, end product needs to be FLV file, client's request to embed in pdf file.
Any idea why its exporting to 656 instead of 720 width? Would it help if I uploaded the Premier file to look at?
If its exporting in that width, my guess is that its creating in that width, which could be the "distortion / fuzzy / blurry problem, maybe the program is screwing up the images b/c its getting confused?????
Any suggestions? Let me know if you need a break from this, I know its getting late, and you have been helping me a long time, Im so thankful for your time to this issue.
Amy
So you can't embed any other type of file into a PDF?
FLV is just what the client asks for, not sure I have the liberty to change file type.
on a similar note...
If I am building a pr video project @ 1280 x 720 and creating vector graphics for it using illustrator...
should I be creating the graphics at the same res?
I'm not an Illustrator export, but I don't believe vector graphics have a fixed resolution. That's the whole point of vector graphics, they scale without degradation.
Having said that, once you add them to a sequence, they will be rasterized to that resolution.
