Have loaded Adobe Flash Player several times, still won't load. Says successfully installed.
can you provide the operating system and browser that you're trying on?
I am using Windows 7 and Internet Explorer
Thank you!
Hi calicographics,
Did you try following the instructions here? Try steps 1-9 and see if that helps.
How do I find the ActiveXfiltering? Up to that part it matches.
What exactly means "won't load"? See also
Please use the flash player uninstaller utility and remove any instances of flash player.
http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
Then restart your system and then try to install adobe flash player again using site http://www.adobe.com
Hi did try this more than one time. It says installed correctly but it
will not play a video
Please visit the below link and confirm the flash player version installed on your system.
http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
Also, In order to install adobe flash player you must be system administrator.
Hey calicographics,
I was able to reproduce and fix the issue you're having. Hopefully it's the same thing.
Try this:
1. Start by uninstalling flash.
2. Download the .zip of the latest version here and extract the zip. (contains 11.7.700.202)
3. Navigate into the folder "11_7_r700_202". (NOT the debug folder)
4. Run flashplayer11_7r700_202_win (Windows Installer Package) and make sure that it successfully installs.
5. Next, run flashplayer11_7r700_202_winax (Windows Installer Package) and make sure that it successfully installs.
6. Verify that it's working in the browser.
I received an error when installing the winax package
Please follow the instructions given in the below knowledge base article
http://forums.adobe.com/thread/928315
Thank you.
