I recently brought a old version Photoshop CS6 online. When I downloaded it, the speed was 10kbps. I get a good connection network and no other usage on the same time. I tried a number of times these days and same result and there is no problems to download others. The test speed is around 50mbps. It is 1/5000th of the max. speed. It should be the server problems I guessed.
Hi FChan,
The download is dependent on the network connectivity speeds. And many a times, the Antivirus software installed on the machine might conflict with the communication with the server too. You might want to check that as well.
Please refer to the download speed vs time chart mentioned in http://forums.adobe.com/message/4451573#4451573
Alternately you can follow the steps listed at http://forums.adobe.com/thread/981369 to initiate a direct download.
It should not be the network connectivity speeds and antivirus software. I brought Lightroom 5 online as well just a week and no problem on downloading speed. It was horribly slow at 10kbps for downloading CS6.
