Flash freezes for a second or three; audio continues ok.
Happens usually a few seconds in, every 8 seconds or so for maybe 3 times and
intermittent after that (sometimes runs fine the rest of the way). Have Vista64
IE9 - Chrome and FF doesn't freeze only IE. Disabled hardware acceleration (to
software). Nvidia 440 drivers up to date. Flash up to date: Object
13.0.0.214 ActiveX control: 12.0.9.149
(shouldn't that be same as object?). Not a buffer problem as it loads up
usually at a good clip ahead of playing video. Local storage buffer set at 10MB
(tried higher and lower settings no joy). Would having 4 HD audio drivers
installed have anything to do with this problem? (noticed in device manager). Previous
versions back a few months were doing this too so decided to go on this forum. Thanks.
Hope I didn't miss anything.
The latest updated flash 14.0.0.176 for IE9 appeared to have fixed the stutter problem. I just updated and tried it - running smooth as silk. Thanks Adobe for finally fixing it.
Just thought of something else: Could the fact that I can no longer update Flash the "normal" way (using the website to tell you you need to update and you do it online). I get a Fail to register error about half way or so (or something similar) so I have to download an installer exe, uninstall Flash first with their uninstaller and then it will install fine.
OK as of today (June 27, 2014) I've had 93 views with no response. I did find a very long thread pertaining to this subject (Flash player stutters for 1 second then continues normally) so I'll tack on to end of that thread with the hopes that something can be done with this annoying stuttering. I want to post my DX Diag text but first update above: It's IE version 9. When video freezes it appears to "catch up" with audio running with no hitch (the whole thing takes a second or two and might happen a few times in a minute video - it ALWAYS happens with a second or two in the beginning though). I even reinstalled IE9 going all the way back to IE7 to make sure I got "fresh" files installed as possible - still same problem after that. With that said below is my DX Diag text. If someone (especially an Adobe person) has any suggestions of where else I can post to get someone talking to me I would appreciate it.
System Information
Time of this report: 6/27/2014, 11:01:54
Machine name: PETERDIANE-PC
Operating System: Windows Vistaâ„¢ Home Premium (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.130707-1535)
Language: English (Regional Setting: English)
System Manufacturer: HP-Pavilion
System Model: NY428AA-ABA p6110f
BIOS: BIOS Date: 04/08/09 17:02:27 Ver: 5.38
Processor: Pentium(R) Dual-Core CPU E5300 @ 2.60GHz (2 CPUs), ~2.6GHz
Memory: 6142MB RAM
Page File: 2622MB used, 9821MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
DxDiag Version: 7.00.6002.18107 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GT 440
Manufacturer: NVIDIA
Chip type: GeForce GT 440
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0DE0&SUBSYS_082810DE&REV_A1
Display Memory: 4046 MB
Dedicated Memory: 1998 MB
Shared Memory: 2047 MB
Current Mode: 1600 x 900 (32 bit) (60Hz)
Monitor: HP 2009 Series Wide LCD Monitor
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver Version: 9.18.0013.3788 (English)
DDI Version: 11
BGRA Supported: Yes
Driver Attributes: Final Retail
Driver Date/Size: 5/19/2014 19:44:03, 17480432 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71E3E-4EA0-11CF-A27D-25281CC2C435}
Vendor ID: 0x10DE
Device ID: 0x0DE0
SubSys ID: 0x082810DE
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_103C2A6F&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.7071 (English)
WHQL Logo'd: n/a
Date and Size: 12/31/1999 17:00:00, 3692632 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sound Capture Devices
Description: Microphone (HD Webcam C270)
Default Sound Capture: Yes
Default Voice Capture: Yes
Driver Name: USBAUDIO.sys
Driver Version: 6.00.6002.18887 (English)
Date and Size: 7/12/2013 02:19:21, 99200 bytes
Cap Flags: 0x0
Format Flags: 0x0
Description: DigitalIn (Realtek High Definition Audio)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x0
Format Flags: 0x0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: HP USB Multimedia Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x04F2, 0x0841
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: American Power Conversion USB UPS
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x051D, 0x0002
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2937
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 6/28/2013 19:25:32, 274944 bytes
| Driver: usbd.sys, 6/28/2013 19:25:14, 7552 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 4/10/2009 22:33:40, 22528 bytes
| Driver: kbdclass.sys, 1/20/2008 19:47:27, 42040 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 1/20/2008 19:46:59, 64000 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x0461, 0x4D0F
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 1/20/2008 19:46:59, 19968 bytes
| Driver: mouclass.sys, 1/20/2008 19:46:59, 39992 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 4/11/2009 00:15:53, 62440 bytes
| Driver: sermouse.sys, 1/20/2008 19:46:59, 26624 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 349.3 GB
Total Space: 596.5 GB
File System: NTFS
Model: WDC WD6400AAKS-65A7B2
Drive: D:
Free Space: 2.0 GB
Total Space: 14.0 GB
File System: NTFS
Drive: E:
Model: TSSTcorp CDDVDW TS-H653Z
Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6002.18005 (English), 4/10/2009 22:34:39, 79872 bytes
System Devices
Name: Intel(R) G33/G31/P35/P31 Express Chipset PCI Express Root Port - 29C1
Device ID: PCI\VEN_8086&DEV_29C1&SUBSYS_00008086&REV_02\3&11583659&0&08
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.00.6002.18005 (English), 4/11/2009 00:15:31, 178664 bytes
Name: Intel(R) G33/G31/P35/P31 Express Chipset Processor to I/O Controller - 29C0
Device ID: PCI\VEN_8086&DEV_29C0&SUBSYS_2A6F103C&REV_02\3&11583659&0&00
Driver: n/a
Name: Intel(R) ICH9 Family PCI Express Root Port 3 - 2944
Device ID: PCI\VEN_8086&DEV_2944&SUBSYS_2A6F103C&REV_02\3&11583659&0&E2
Name: Intel(R) ICH9 Family PCI Express Root Port 2 - 2942
Device ID: PCI\VEN_8086&DEV_2942&SUBSYS_2A6F103C&REV_02\3&11583659&0&E1
Name: Intel(R) ICH9 Family PCI Express Root Port 1 - 2940
Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_2A6F103C&REV_02\3&11583659&0&E0
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_2A6F103C&REV_02\3&11583659&0&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.00.6002.18005 (English), 4/10/2009 22:39:41, 948736 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_2A6F103C&REV_02\3&11583659&0&D7
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.00.6002.18465 (English), 5/5/2011 07:17:49, 49664 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.00.6002.18875 (English), 6/28/2013 19:25:21, 259584 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.00.6002.18875 (English), 6/28/2013 19:25:32, 274944 bytes
Driver: C:\Windows\system32\hccoin.dll, 6.00.6002.18465 (English), 5/5/2011 09:07:46, 10752 bytes
Driver: C:\Windows\system32\hcrstco.dll, 6.00.6002.18465 (English), 5/5/2011 09:07:46, 17920 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_2A6F103C&REV_02\3&11583659&0&EF
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2939
Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_2A6F103C&REV_02\3&11583659&0&EB
Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.00.6002.18465 (English), 5/5/2011 07:17:47, 29184 bytes
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_2A6F103C&REV_02\3&11583659&0&D1
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_2A6F103C&REV_02\3&11583659&0&D0
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_2A6F103C&REV_02\3&11583659&0&EA
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_2A6F103C&REV_02\3&11583659&0&E9
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_2A6F103C&REV_02\3&11583659&0&E8
Name: Intel(R) ICH9 Family SMBus Controller - 2930
Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_2A6F103C&REV_02\3&11583659&0&FB
Driver: n/a
Name: Intel(R) ICH9R LPC Interface Controller - 2916
Device ID: PCI\VEN_8086&DEV_2916&SUBSYS_2A6F103C&REV_02\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.00.6001.18000 (English), 1/20/2008 19:46:51, 17976 bytes
Name: Intel(R) ICH8R/ICH9R/ICH10R/DO SATA RAID Controller
Device ID: PCI\VEN_8086&DEV_2822&SUBSYS_2A6F103C&REV_02\3&11583659&0&FA
Driver: C:\Windows\system32\DRIVERS\iaStor.sys, 8.07.0000.1007 (English), 12/4/2008 05:48:52, 407064 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_2A6F103C&REV_92\3&11583659&0&F0
Name: AGERE OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_11C1&DEV_5811&SUBSYS_00000000&REV_70\4&3B75382B&0&28F0
Driver: C:\Windows\system32\DRIVERS\ohci1394.sys, 6.00.6002.18005 (English), 4/10/2009 22:39:49, 72448 bytes
Driver: C:\Windows\system32\DRIVERS\1394bus.sys, 6.00.6001.18000 (English), 1/20/2008 19:46:54, 65280 bytes
Name: LSI PCI-SV92EX Soft Modem
Device ID: PCI\VEN_11C1&DEV_0630&SUBSYS_063011C1&REV_01\4&37C315F9&0&00E1
Driver: C:\Windows\system32\DRIVERS\agrsm64.sys, 2.02.0100.0000 (English), 1/26/2010 17:52:22, 1212416 bytes
Driver: C:\Program Files\LSI SoftModem\agr64svc.exe, 1.00.0000.0010 (English), 12/3/2009 20:27:24, 28672 bytes
Driver: C:\Windows\agrsmdel.exe, 2.07.0006.0000 (English), 12/3/2009 20:28:00, 64000 bytes
Driver: C:\Windows\agrdel64.exe, 2.07.0006.0000 (English), 12/3/2009 20:27:36, 42496 bytes
Driver: C:\Program Files\LSI SoftModem\agrsmdel.ico, 5/27/2009 20:17:46, 41812 bytes
Driver: C:\Windows\system32\agrsco64.dll, 1.00.0000.0009 (English), 12/3/2009 20:28:58, 27648 bytes
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_2A6F103C&REV_02\4&5D52B92&0&00E2
Driver: n/a
Name: NVIDIA GeForce GT 440
Device ID: PCI\VEN_10DE&DEV_0DE0&SUBSYS_082810DE&REV_A1\4&13D7CD30&0&0008
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 9.18.0013.3788 (English), 5/19/2014 19:44:03, 440152 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 5/19/2014 19:44:03, 1183672 bytes
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_d36593ca\NvCplSetupEng.exe, 1.00.0001.0000 (English), 5/19/2014 19:44:03, 33528888 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 2/26/2013 01:32:08, 21898 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 5/19/2014 19:44:03, 843720 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.3788 (English), 5/19/2014 19:44:03, 224032 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 5/19/2014 19:44:03, 50585 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.3788 (English), 5/19/2014 19:44:03, 329672 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.3788 (English), 5/19/2014 19:44:03, 543520 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 5/19/2014 19:44:03, 52056 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.00.0000.0000 (English), 5/19/2014 19:44:03, 61216 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 9.18.0013.3788 (English), 5/19/2014 19:44:03, 12688328 bytes
Driver: C:\Windows\system32\nvapi64.dll, 9.18.0013.3788 (English), 5/19/2014 19:44:03, 3109248 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0013.3788 (English), 5/19/2014 19:44:03, 25256224 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.17.0013.3788 (English), 5/19/2014 19:44:03, 11644928 bytes
Driver: C:\Windows\system32\nvcuvenc.dll, 8.17.0013.3788 (English), 5/19/2014 19:44:03, 2785568 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0013.3788 (English), 5/19/2014 19:44:03, 3141976 bytes
Driver: C:\Windows\system32\nvd3dumx.dll, 9.18.0013.3788 (English), 5/19/2014 19:44:03, 17480432 bytes
Driver: C:\Windows\system32\nvinfo.pb, 5/19/2014 19:44:03, 26069 bytes
Driver: C:\Windows\system32\nvoglv64.dll, 9.18.0013.3788 (English), 5/19/2014 19:44:03, 31387936 bytes
Driver: C:\Windows\system32\nvopencl.dll, 8.17.0013.3788 (English), 5/19/2014 19:44:03, 11599072 bytes
Driver: C:\Windows\system32\nvwgf2umx.dll, 9.18.0013.3788 (English), 5/19/2014 19:44:03, 18531568 bytes
Driver: C:\Windows\SysWow64\nvapi.dll, 9.18.0013.3788 (English), 5/19/2014 19:44:03, 2730208 bytes
Driver: C:\Windows\SysWow64\nvcompiler.dll, 8.17.0013.3788 (English), 5/19/2014 19:44:03, 17561544 bytes
Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0013.3788 (English), 5/19/2014 19:44:03, 9735256 bytes
Driver: C:\Windows\SysWow64\nvcuvenc.dll, 8.17.0013.3788 (English), 5/19/2014 19:44:03, 2412376 bytes
Driver: C:\Windows\SysWow64\nvcuvid.dll, 8.17.0013.3788 (English), 5/19/2014 19:44:03, 2953672 bytes
Driver: C:\Windows\SysWow64\nvd3dum.dll, 9.18.0013.3788 (English), 5/19/2014 19:44:03, 14434704 bytes
Driver: C:\Windows\SysWow64\nvoglv32.dll, 9.18.0013.3788 (English), 5/19/2014 19:44:03, 24025376 bytes
Driver: C:\Windows\SysWow64\nvopencl.dll, 8.17.0013.3788 (English), 5/19/2014 19:44:03, 9697640 bytes
Driver: C:\Windows\SysWow64\nvwgf2um.dll, 9.18.0013.3788 (English), 5/19/2014 19:44:03, 16003912 bytes
Driver: C:\Windows\system32\nvdispco6433788.dll, 2.00.0040.0004 (English), 5/19/2014 19:44:03, 1889112 bytes
Driver: C:\Windows\system32\nvdispgenco6433788.dll, 2.00.0019.0002 (English), 5/19/2014 19:44:03, 1541576 bytes
Device ID: PCI\VEN_10DE&DEV_0BEA&SUBSYS_082810DE&REV_A1\4&13D7CD30&0&0108
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Canon G.726 DMO Decoder,0x00000000,1,1,,
MP3 Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Full Screen Renderer,0x00200000,1,0,,6.06.6002.18725
Multiple File Output,0x00200000,2,2,WMM2FILT.dll,
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,
DV Muxer,0x00400000,0,0,,6.06.6001.18000
Color Space Converter,0x00400001,1,1,,6.06.6002.18725
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,
WM ASF Reader,0x00400000,0,0,,11.00.6001.7000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6001.7000
AVI Splitter,0x00600000,1,1,,6.06.6002.18725
VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6002.18725
Microsoft MPEG-2 Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,11.00.6001.7110
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,
9x8Resize,0x00200000,1,1,WMM2FILT.dll,
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6002.18363
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,
Microsoft TV Caption Decoder,0x00200001,1,0,MSTVCapn.dll,6.00.6002.18536
MJPEG Decompressor,0x00600000,1,1,,6.06.6002.18725
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.00.6002.18242
MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6002.18725
SAMI (CC) Parser,0x00400000,1,1,,6.06.6002.18725
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6001.18000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6002.18363
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,
Microsoft MPEG-2 Video Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6002.18005
Stretch Video,0x00200000,1,1,WMM2FILT.dll,
Internal Script Command Renderer,0x00800001,1,0,,6.06.6002.18725
MPEG Audio Decoder,0x03680001,1,1,,6.06.6002.18725
DV Splitter,0x00600000,1,2,,6.06.6001.18000
Video Mixing Renderer 9,0x00200000,1,0,,6.06.6002.18725
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,11.00.6002.18005
Frame Eater,0x00200000,1,1,WMM2FILT.dll,
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,
ACM Wrapper,0x00600000,1,1,,6.06.6002.18725
Video Renderer,0x00800001,1,0,,6.06.6002.18725
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6002.18363
Capture ASF Writer,0x00200000,0,0,WMM2FILT.dll,
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,,6.06.6002.18725
Video Renderer,0x00400000,1,0,,6.06.6002.18725
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,
Proxy Sink,0x00200000,1,0,WMM2FILT.dll,
Proxy Source,0x00200000,0,1,WMM2FILT.dll,
WM ASF Writer,0x00400000,0,0,,11.00.6001.7000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6000.16386
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,
File writer,0x00200000,1,0,,6.06.6001.18000
DVD Navigator,0x00200000,0,3,,6.06.6002.18533
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6002.18005
WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6001.18000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6002.18363
Record Queue,0x00200000,1,1,WMM2FILT.dll,
DV Video Decoder,0x00800000,1,1,,6.06.6001.18000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6002.19033
Null Renderer,0x00200000,1,0,qedit.dll,6.06.6002.19033
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6002.18496
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,11.00.6002.18005
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6002.18363
Smart Tee,0x00200000,1,2,,6.06.6001.18000
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,,6.06.6002.18725
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,
NetBridge,0x00200000,2,0,netbridge.dll,6.01.6001.18000
AVI/WAV File Source,0x00400000,0,2,,6.06.6002.18725
WMT Volume,0x00200000,1,1,WMM2FILT.dll,
Wave Parser,0x00400000,1,1,,6.06.6002.18725
MIDI Parser,0x00400000,1,1,,6.06.6002.18725
Multi-file Parser,0x00400000,1,1,,6.06.6002.18725
File stream renderer,0x00400000,1,1,,6.06.6002.18725
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,
Microsoft MPEG-1/DD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,11.00.6001.7000
AVI Mux,0x00200000,1,0,,6.06.6001.18000
Line 21 Decoder 2,0x00600002,1,1,,6.06.6002.18725
File Source (Async.),0x00400000,0,1,,6.06.6002.18725
File Source (URL),0x00400000,0,1,,6.06.6002.18725
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.6002.18005
AudioRecorder WAV Dest,0x00200000,0,0,,6.00.6000.16386
AudioRecorder Wave Form,0x00200000,0,0,,6.00.6000.16386
SoundRecorder Null Renderer,0x00200000,0,0,,6.00.6000.16386
Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6001.18000
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.00.6002.18005
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6002.18496
MPEG Video Decoder,0x40000001,1,1,,6.06.6002.18725
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,6.00.6001.18000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,,6.06.6001.18000
MJPEG Compressor,0x00200000,0,0,,6.06.6002.18725
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,,6.06.6002.18725
Microsoft ADPCM,0x00200000,1,1,,6.06.6002.18725
GSM 6.10,0x00200000,1,1,,6.06.6002.18725
CCITT A-Law,0x00200000,1,1,,6.06.6002.18725
CCITT u-Law,0x00200000,1,1,,6.06.6002.18725
MPEG Layer-3,0x00200000,1,1,,6.06.6002.18725
Audio Capture Sources:
Microphone (HD Webcam C270),0x00200000,0,0,,6.06.6001.18000
DigitalIn (Realtek High Definit,0x00200000,0,0,,6.06.6001.18000
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,,6.06.6002.18725
Microsoft GS Wavetable Synth,0x00200000,1,0,,6.06.6002.18725
WDM Streaming Capture Devices:
Realtek HD Digital input,0x00200000,1,1,,6.00.6001.18000
Realtek HD Audio Line input,0x00200000,1,1,,6.00.6001.18000
Realtek HD Audio Mic input,0x00200000,1,1,,6.00.6001.18000
Realtek HD Audio Stereo input,0x00200000,1,1,,6.00.6001.18000
Logitech HD Webcam C270,0x00200000,2,2,,6.00.6001.18000
HD Webcam C270,0x00200000,1,1,,6.00.6001.18000
WDM Streaming Rendering Devices:
Realtek HD Audio rear output,0x00200000,1,1,,6.00.6001.18000
Realtek HDA SPDIF Out,0x00200000,1,1,,6.00.6001.18000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6002.18496
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6002.18005
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6002.18496
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6002.18496
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6002.18528
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6002.18528
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6002.18528
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,,6.06.6002.18725
Default DirectSound Device,0x00800000,1,0,,6.06.6002.18725
Default WaveOut Device,0x00200000,1,0,,6.06.6002.18725
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,,6.06.6002.18725
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,,6.06.6002.18725
Realtek Digital Output (Realtek,0x00200000,1,0,,6.06.6002.18725
Sorry to say but this problem is very old and adobe cannot, or will not fix it. They have even stopped responding to post about it. There were a couple of work a rounds, using Chrome, a few others depending on your system type. One was on AMD processors changing the chip to use only one core helped with the freeze a bit, but after this last release June 10, 2014 that no longer works. Looks like a software bug introduced a couple of releases back that they cannot find, or just do not know how to fix. With newer devices (mobiles, thinkpads, so on) looks like they have written off flash player for desktops, bad move from a customer service stand point.
Just so you know don't expect to many replies on this, most of us have given up on adobe finding a solution.
Thanks RG3. Not surprised. Maybe a future update might "accidentally" fix it - you never know.
