This has happened on the last two versions of the Flash Player I have attempted to install. I download the installer, run it and it does it's thing downloading the player and when it gets to the portion of the process that updates the registry with information about the ActiveX components, it stops. I've looked at the support forums, and everyone says that the underlying issue is that I do not have privileges. Well....I do. I am the only user on this laptop and I have set things so I am the administrator. So, the installer is not working for me and if it's not working for me, then I would like to know what entries I need to make in the registry using regedit. I'm installing the current version of Flash Player, which is 17.0.0.134, I'm running Windows 7, SP1. I've got IE 11, version 11.0.9600.16428.
This could be due to to a permissions issue in the registry, preventing the components from registering. Please see How do I fix Windows permission problems with Flash Player?.
Maria
Maria,
Thank you for your help.
I did as was outlined, and I still got the same result....the installer failed to register. Do you have any other suggestions?
Tom
Please provide the FlashInstall.log file located at C:\Windows\System32\Macromed\Flash using the instructions here How to share a document. If this is a 64-bit OS, also provide the FlashInstall.log file located at C:\Windows\SysWOW64\Macromed\Flash.
Maria
Maria,
Thanks again for your help.
Listed below is the contents of the log file.
=O====== M/11.9.900.152 2013-11-20+19-35-38.321 ========
0000
0001 00000010 "C:\Users\Tom Mulligan\AppData\Local\Adobe\AIH.92d7e6711e66578cb7f39ea16ed1b732cc944485\install_flash_player_ax.exe" -install -iv 8 -au 1
0002
0003
0004
0005 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_9_900_152.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.dll
0010 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0011 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0012 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0013 00000012
=X====== M/11.9.900.152 2013-11-20+19-35-43.726 ========
=O====== M/11.9.900.152 2013-11-26+19-21-31.953 ========
0000 00000010 "C:\Users\Tom Mulligan\AppData\Local\Adobe\AIH.86bc93124a78335ff261208f5f5e71fb68434a89\install_flash_player_ax.exe" -install -iv 8 -au 1
0001
=X====== M/11.9.900.152 2013-11-26+19-21-33.775 ========
=O====== M/11.9.900.152 2013-11-26+19-22-45.662 ========
0001 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_9_900_152.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_152_ActiveX.dll
0005 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0006 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0007
0008
0009 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0010
0011 00000012
=X====== M/11.9.900.152 2013-11-26+19-22-53.598 ========
=O====== M/11.9.900.152 2013-11-27+18-50-47.137 ========
0000 00000010 "C:\Users\Tom Mulligan\AppData\Local\Adobe\AIH.7468e0291dd2cd95d8afdc9111012dd88bbbcf56\install_flash_player_ax.exe" -install -iv 8 -au 1
0001
=X====== M/11.9.900.152 2013-11-27+18-50-48.788 ========
=O====== M/11.9.900.152 2013-11-27+18-54-33.756 ========
0007
0008
0010
0011 00000012
=X====== M/11.9.900.152 2013-11-27+18-54-39.653 ========
=O====== M/11.9.900.170 2013-12-17+00-01-05.915 ========
0002
0003 00000018
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_9_900_170.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_170_ActiveX.dll
0008 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0009 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0010
0011
0013
0014 00000012
=X====== M/11.9.900.170 2013-12-17+00-01-15.164 ========
=O====== M/12.0.0.38 2014-02-01+00-32-09.942 ========
0000 00000010 "C:\Users\Tom Mulligan\AppData\Local\Adobe\AIH.093012ecfdb7d3cb471b376f1dee9d606fd480b1\install_flash_player_ax.exe" -install -iv 8 -au 1
0001
0002 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0003
0004 00000018
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash32_12_0_0_38.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_38_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_38_ActiveX.dll
0009 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0010 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0011
0012
0013 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0014
0015 00000012
=X====== M/12.0.0.38 2014-02-01+00-32-16.897 ========
=O====== M/12.0.0.38 2014-02-02+00-41-51.702 ========
0001
0002
=X====== M/12.0.0.38 2014-02-02+00-41-54.047 ========
=O====== M/12.0.0.38 2014-02-02+00-42-17.111 ========
0001
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash32_12_0_0_38.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_38_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_38_ActiveX.dll
0006 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0007 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0008
0009
0010 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0011
0012 00000012
=X====== M/12.0.0.38 2014-02-02+00-42-23.446 ========
=O====== M/11.7.700.269 2014-03-04+03-00-21.407 ========
0000 00000010 "C:\Users\Tom Mulligan\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\YFW5HZW5\flashplayer_11_7_ax_debug.exe"
0001
=X====== M/11.7.700.269 2014-03-04+03-00-47.117 ========
=O====== M/12.0.0.70 2014-03-04+03-02-21.793 ========
0000 00000010 "C:\Users\Tom Mulligan\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\WN423FNL\flashplayer_12_ax_debug.exe"
0001
0002
0003 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0004
0005 00000018
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash32_12_0_0_70.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_70_ActiveX.dll
0012
0013
0014
=X====== M/12.0.0.70 2014-03-04+03-02-51.625 ========
=O====== M/12.0.0.77 2014-03-28+21-54-31.600 ========
0000 00000010 "C:\Users\Tom Mulligan\AppData\Local\Adobe\AIH.093012ecfdb7d3cb471b376f1dee9d606fd480b1\install_flash_player_ax.exe" -install -iv 8 -au 0
0002
0003 00000018
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash32_12_0_0_77.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_12_0_0_77_ActiveX.dll
0010
0011
0013 00000012
=X====== M/12.0.0.77 2014-03-28+21-54-40.537 ========
2014-7-25+22-7-11.23 [error] 1226 1062
=O====== M/14.0.0.145 2014-07-25+22-06-39.152 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 9
0001
0003 00000013
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_14_0_0_145_ActiveX.dll
0008
0009
0011
0012
0013
0014 00000012
=X====== M/14.0.0.145 2014-07-25+22-06-29.559 ========
2014-10-22+2-6-36.297 [error] 1226 1062
=O====== M/15.0.0.167 2014-10-22+02-06-17.452 ========
0001
0003 00000013
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_167_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_167_ActiveX.dll
0008
0009
0011
0012
0013
0014 00000012
=X====== M/15.0.0.167 2014-10-22+02-06-38.184 ========
2014-11-20+1-6-30.826 [error] 1226 1062
=O====== M/15.0.0.223 2014-11-20+01-06-21.139 ========
0002 00000013
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_223_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_223_ActiveX.dll
0007
0008
0010
0011
0012
0013 00000012
=X====== M/15.0.0.223 2014-11-20+01-06-32.948 ========
2014-12-4+0-6-32.331 [error] 1226 1062
=O====== M/15.0.0.239 2014-12-04+00-06-11.228 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 11
0002
0003 00000018
0004
0005 00000013
0006 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_239_ActiveX.exe
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_239_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_239_ActiveX.dll
0011
0012
0014
0015
0016
0017 00000012
=X====== M/15.0.0.239 2014-12-04+00-06-36.840 ========
2014-12-11+2-6-13.143 [error] 1226 1062
=O====== M/15.0.0.246 2014-12-11+02-06-05.578 ========
0002
0003 00000018
0004
0005 00000013
0006 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_246_ActiveX.exe
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_246_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_15_0_0_246_ActiveX.dll
0011
0012
0014
0015
0016
0017 00000012
=X====== M/15.0.0.246 2014-12-11+02-06-15.875 ========
=O====== M/16.0.0.235 2014-12-20+05-24-48.739 ========
0000 00000010 "C:\Users\Tom Mulligan\AppData\Local\Adobe\AIH.66e1f1ec00e9a0050928523c06fb6bf1a1216dae\install_flash_player_ax.exe" -install -iv 8
0001
0003
0004 00000018
0005
0006 00000013
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_235_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_235_ActiveX.dll
0011
0012
0013
0014 00000018
0015
=X====== M/16.0.0.235 2014-12-20+05-24-55.894 ========
=O====== M/16.0.0.235 2014-12-25+23-47-55.009 ========
0000 00000010 "C:\Users\Tom Mulligan\AppData\Local\Adobe\AIH.f6103d1c7c46b7e4fc9fd1847562faf9dd99e8f3\install_flash_player_ax.exe" -install -iv 8
0002
0003
0004 00000018
0005
0006
0007 00000013
0008
=X====== M/16.0.0.235 2014-12-25+23-47-58.554 ========
=O====== M/16.0.0.235 2014-12-25+23-54-16.754 ========
0002
0003
0004 00000018
0005
0006 00000013
0007
=X====== M/16.0.0.235 2014-12-25+23-54-20.122 ========
=O====== M/16.0.0.235 2014-12-26+00-03-58.753 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-01.277 ========
=O====== M/16.0.0.235 2014-12-26+00-04-08.903 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-11.391 ========
=O====== M/16.0.0.235 2014-12-26+00-04-12.939 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-15.431 ========
=O====== M/16.0.0.235 2014-12-26+00-04-16.744 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-19.311 ========
=O====== M/16.0.0.235 2014-12-26+00-04-20.566 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-23.068 ========
=O====== M/16.0.0.235 2014-12-26+00-04-24.204 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-26.721 ========
=O====== M/16.0.0.235 2014-12-26+00-04-27.664 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-30.204 ========
=O====== M/16.0.0.235 2014-12-26+00-04-31.240 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-33.779 ========
=O====== M/16.0.0.235 2014-12-26+00-04-34.651 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-37.136 ========
=O====== M/16.0.0.235 2014-12-26+00-04-37.952 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-40.489 ========
=O====== M/16.0.0.235 2014-12-26+00-04-41.261 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-43.755 ========
=O====== M/16.0.0.235 2014-12-26+00-04-46.593 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-49.087 ========
=O====== M/16.0.0.235 2014-12-26+00-04-49.850 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-52.346 ========
=O====== M/16.0.0.235 2014-12-26+00-04-53.085 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-55.572 ========
=O====== M/16.0.0.235 2014-12-26+00-04-56.363 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-04-58.850 ========
=O====== M/16.0.0.235 2014-12-26+00-04-59.843 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-02.364 ========
=O====== M/16.0.0.235 2014-12-26+00-05-03.205 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-05.748 ========
=O====== M/16.0.0.235 2014-12-26+00-05-06.876 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-09.363 ========
=O====== M/16.0.0.235 2014-12-26+00-05-10.226 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-12.792 ========
=O====== M/16.0.0.235 2014-12-26+00-05-13.742 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-16.230 ========
=O====== M/16.0.0.235 2014-12-26+00-05-17.484 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-20.004 ========
=O====== M/16.0.0.235 2014-12-26+00-05-20.928 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-23.424 ========
=O====== M/16.0.0.235 2014-12-26+00-05-25.579 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-28.155 ========
=O====== M/16.0.0.235 2014-12-26+00-05-28.948 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-31.431 ========
=O====== M/16.0.0.235 2014-12-26+00-05-32.179 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-34.674 ========
=O====== M/16.0.0.235 2014-12-26+00-05-35.488 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-38.027 ========
=O====== M/16.0.0.235 2014-12-26+00-05-38.633 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-41.160 ========
=O====== M/16.0.0.235 2014-12-26+00-05-41.877 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-44.417 ========
=O====== M/16.0.0.235 2014-12-26+00-05-44.970 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-47.459 ========
=O====== M/16.0.0.235 2014-12-26+00-05-48.186 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-50.731 ========
=O====== M/16.0.0.235 2014-12-26+00-05-51.340 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-05-53.830 ========
=O====== M/16.0.0.235 2014-12-26+00-05-59.464 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-02.003 ========
=O====== M/16.0.0.235 2014-12-26+00-06-02.537 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-05.030 ========
=O====== M/16.0.0.235 2014-12-26+00-06-05.695 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-08.247 ========
=O====== M/16.0.0.235 2014-12-26+00-06-08.844 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-11.396 ========
=O====== M/16.0.0.235 2014-12-26+00-06-11.963 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-14.519 ========
=O====== M/16.0.0.235 2014-12-26+00-06-15.085 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-17.627 ========
=O====== M/16.0.0.235 2014-12-26+00-06-18.197 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-20.683 ========
=O====== M/16.0.0.235 2014-12-26+00-06-21.415 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-23.907 ========
=O====== M/16.0.0.235 2014-12-26+00-06-24.485 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-26.973 ========
=O====== M/16.0.0.235 2014-12-26+00-06-27.454 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-29.939 ========
=O====== M/16.0.0.235 2014-12-26+00-06-30.633 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-33.118 ========
=O====== M/16.0.0.235 2014-12-26+00-06-33.706 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-36.189 ========
=O====== M/16.0.0.235 2014-12-26+00-06-37.003 ========
0001
=X====== M/16.0.0.235 2014-12-26+00-06-39.516 ========
=O====== M/16.0.0.235 2014-12-26+00-08-01.073 ========
0002
0003 00000013
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_235_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_235_ActiveX.dll
0008
0009
0010
0011 00000018
0012
=X====== M/16.0.0.235 2014-12-26+00-08-08.536 ========
=O====== M/16.0.0.235 2014-12-26+00-08-57.129 ========
0002
0003
0004 00000018
0005
0006
0007 00000013
0008
=X====== M/16.0.0.235 2014-12-26+00-09-00.531 ========
=O====== M/16.0.0.235 2014-12-26+00-13-16.031 ========
0000 00000010 "C:\Users\Tom Mulligan\AppData\Local\Adobe\AIH.01b49c5f7d0268bb37db9a1a650b8ec4cf96e517\install_flash_player_ax.exe" -install -iv 8
0002
0003
0004 00000018
0005
0006 00000013
0007
=X====== M/16.0.0.235 2014-12-26+00-13-19.563 ========
=O====== M/16.0.0.235 2014-12-26+01-11-08.308 ========
0000 00000010 "C:\Users\TOMMUL~1\AppData\Local\Temp\{D3E75D26-7E8B-41D5-BA3B-66066686D6FA}\InstallFlashPlayer.exe" -iv 6
0002
0003 00000013
0008
0009
0010
0011 00000018
0012
0014
0015
0016
0017 00000012
=X====== M/16.0.0.235 2014-12-26+01-11-34.858 ========
=O====== M/16.0.0.235 2014-12-26+01-09-27.540 ========
0000 00000010 C:\Users\TOMMUL~1\AppData\Local\Temp\IDC2.tmp\FP_AX_CAB_INSTALLER64.exe
0001 00000011 1
=X====== M/16.0.0.235 2014-12-26+01-11-35.058 ========
2015-1-15+0-6-51.73 [error] 1226 1062
=O====== M/16.0.0.257 2015-01-15+00-06-30.448 ========
0002
0003
0004 00000018
0005
0006
0007 00000013
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_257_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_257_ActiveX.dll
0012
0013
0014 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0015
0016
0017
0018 00000012
=X====== M/16.0.0.257 2015-01-15+00-06-53.584 ========
2015-1-23+3-6-19.612 [error] 1226 1062
=O====== M/16.0.0.287 2015-01-23+03-06-11.053 ========
0002
0003 00000018
0004
0005 00000013
0006 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_287_ActiveX.exe
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_287_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_287_ActiveX.dll
0011
0012
0014
0015
0016
0017 00000012
=X====== M/16.0.0.287 2015-01-23+03-06-22.506 ========
2015-1-26+0-6-20.567 [error] 1226 1062
=O====== M/16.0.0.296 2015-01-26+00-06-10.957 ========
0002
0003 00000018
0004
0005 00000013
0006 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_296_ActiveX.exe
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_296_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_296_ActiveX.dll
0011
0012
0014
0015
0016
0017 00000012
=X====== M/16.0.0.296 2015-01-26+00-06-22.891 ========
2015-2-7+21-6-28.180 [error] 1226 1062
=O====== M/16.0.0.305 2015-02-07+21-06-08.087 ========
0002 00000013
0003 00000025 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.dll
0008
0009
0011
0012
0013
0014 00000012
=X====== M/16.0.0.305 2015-02-07+21-06-30.146 ========
=O====== M/17.0.0.134 2015-03-18+15-11-30.524 ========
0000 00000010 "C:\Users\Tom Mulligan\AppData\Local\Adobe\AIH.8d9917e2a9c8a3a0e530782ffb0049e4e5ae43f4\install_flash_player_ax.exe" -install -iv 8
0001
0003
0004 00000018
0005
0006 00000013
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_17_0_0_134_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_17_0_0_134_ActiveX.dll
0011
0012
0013
0014 00000018
0015
=X====== M/17.0.0.134 2015-03-18+15-11-38.296 ========
=O====== M/17.0.0.134 2015-03-18+15-26-24.919 ========
0000 00000010 "C:\Users\Tom Mulligan\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\V1GOKULM\install_flash_player_ax.exe"
0002
0003
0004 00000018
0005
0006
0007 00000013
0008
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_17_0_0_134_ActiveX.exe
0010 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_17_0_0_134_ActiveX.dll
0011 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0012 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0013
0014
0015
0016 00000018
0017
0018 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0019
0020
0021
0022
=X====== M/17.0.0.134 2015-03-18+15-28-00.936 ========
=O====== M/17.0.0.134 2015-03-18+15-47-24.904 ========
0000 00000010 "C:\Users\Tom Mulligan\AppData\Local\Adobe\AIH.e95b939e083c24c49f027bfc531f66254f276aea\install_flash_player_ax.exe" -install -iv 8
0002
0003
0004 00000018
0005
0006
0007 00000013
0008
=X====== M/17.0.0.134 2015-03-18+15-47-28.366 ========
=O====== M/17.0.0.134 2015-03-18+15-52-49.009 ========
0002
0003 00000013
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_17_0_0_134_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_17_0_0_134_ActiveX.dll
0008
0009
0010
0011 00000018
0012
=X====== M/17.0.0.134 2015-03-18+15-52-56.175 ========
=O====== M/17.0.0.134 2015-03-19+14-48-45.899 ========
0000 00000010 "C:\Users\Tom Mulligan\Downloads\AdobeFlashPlayer\install_flash_player_ax.exe"
0002
0003
0004 00000018
0005
0006
0007 00000013
0008
0013
0014
0015
0016 00000018
0017
0019
0020
0021
=X====== M/17.0.0.134 2015-03-19+14-49-30.921 ========
=O====== M/17.0.0.134 2015-03-19+17-50-36.734 ========
0002
0003
0004 00000018
0005
0006
0007 00000013
0008
=X====== M/17.0.0.134 2015-03-19+17-50-41.070 ========
=O====== M/17.0.0.134 2015-03-19+17-56-09.520 ========
0002
0003 00000013
0008
0009
0010
0011 00000018
0012
=X====== M/17.0.0.134 2015-03-19+17-56-17.032 ========
=O====== M/17.0.0.134 2015-03-19+18-35-36.052 ========
0002
0003
0004 00000013
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_17_0_0_134_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_17_0_0_134_ActiveX.dll
0007 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0008 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0009
0010
0011
0012 00000018
0013
=X====== M/17.0.0.134 2015-03-19+18-35-43.056 ========
Hi Thomas,
The exact error is 8002801C,which is a registry permissions issue (Error Code 8002801c- DllRegisterServer in COM failed with regsvr32) and it appears to be on some other registry entry that is not included in our reset file. This forum thread, Could not register Active X Control, has information on running Process Monitor to identify the exact registry entries causing the problem (if you'd like to go that route), however it also links to a Microsoft KB article, https://support.microsoft.com/en-us/kb/968003, that resets all registry entries. You may just want to go this route and reset everything.
You may want to scan your system for malware after fixing it. MalwareBytes is quite popular.
Maria
