Hey, the latest Flash installer immediately crashes with a bus error when I try to launch it. I don't know how to resolve this apart from waiting for the automatic update, and see if that fixes the issue. Does anyone have any idea how to fix this, or how to report the bug?
Thanks, I tried the suggested offline installer from your link which worked and shows up as 17.0.0.188 in system preferences.
I got the installer on this machine with 10.6, but I never downloaded this manually from Adobe. An Adobe pop-up apeared when I was using the browser to view some flash content (TV network), telling me that a new version was available. I have set up the Flash preferences to allow automatic updates, but it somehow always seems to suggest me to do it through this pop-up windo
...Copy link to clipboard
Hi 1a2b3cboo,
What is the operating system this is happening on?
If possible, please post a screenshot (see How to post a screenshot in the forum)
Thank you.
Maria
P.S. I deleted your duplicate post at Latest installer (refered to as "17au ta") crashes with a bus error.
This is happening on OS X 10.6.8. I don't think a screen shot will help because it crashes immediatelly when I double click the installer app, which results in a crash report. (snippet from crash report)
Process: | Install Adobe Flash Player [393] |
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Hi 1a2b3cboo,
Thank you for the additional information. To troubleshoot further, I'd like to get some log files from you.
Please upload all files using the instructions here How to share a document
Thank you.
Maria
Thank you. I did not find a Adobe_ADMLogs folder but the others are uploaded here: Delade filer - Acrobat.com
P.S I redacted older entries in the install log prior to this date.
The disk image is called: AdobeFlashPlayer_17au_ta_install.dmg
Mounting it and checking the info (cmd - i) on the installer itself shows a version number which is: 1.0.0.14s
BTW, I also tried a SHA 1 checksum of the diskimage which was: 1b1f54ab3c700f240c51d2ad2aeeda6b0a79d5e5
Hi 1a2b3cboo,
Please use the offline installer posted at the bottom of the Installation problems | Flash Player | Mac page in the 'Still having problems' section.
Per the folks who handle the online installer it is not compatible with OS X 10.6. The download pages performs browser/os detection to determine which installer to offer. On a 10.6 system it should have downloaded the offline installer, instead of the online installer. As such I'd like to get some more info from you on this. Did you download this file using the 10.6 machine, or some other system? Did you download it from adobe.com or some other location? What is the exact URL for the page you downloaded this installer from?
Thank you in advance.
Maria
I got the installer on this machine with 10.6, but I never downloaded this manually from Adobe. An Adobe pop-up apeared when I was using the browser to view some flash content (TV network), telling me that a new version was available. I have set up the Flash preferences to allow automatic updates, but it somehow always seems to suggest me to do it through this pop-up window instead.
I seem to remember that the automatic update is delayed a few days, so I usually go for the install button on the pop-up.
Hi 1a2b3cboo,
Thank you for the additional information. I have forwarded to the folks who handle the online installer.
Maria
I'm also having this problem (Mac OS X 10.6.8), for maybe a month I can't update Adobe Flash Player. I found this thread by searching: "install adobe flash player" "crash report"
The crash report says on top:
Process: Install Adobe Flash Player [317] Path: /Volumes/Adobe Flash Player Installer/Install Adobe Flash Player.app/Contents/MacOS/Install Adobe Flash Player Identifier: com.adobe.InstallAdobeFlashPlayer Version: 1.0.0.14s (1.0.0.14s) Code Type: X86 (Native) Parent Process: launchd [115]
Date/Time: 2015-05-20 19:23:54.287 -0400 OS Version: Mac OS X 10.6.8 (10K549) Report Version: 6
Interval Since Last Report: 369604 sec Crashes Since Last Report: 4 Per-App Crashes Since Last Report: 3
Anonymous UUID: 2A776D65-ECEA-4634-902E-534C1BB77954 Exception Type: EXC_BAD_ACCESS (SIGBUS)
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Hope I can update Flash soon... ~Ian
Hi Ian,
Based on the crash log report, this is the online installer, which isn't supported on OS X 10.6, and the download page is supposed to offer up the offline installer, not the online installer. Did you download the installer file recently, or some time ago? If it wasn't recently I'd appreciate it if you would do the following: Clear the browser cache and download the installer again from get.adobe.com/flashplayer. If the name of the file is similar to AdobeFlashPlayer_17_ta_install.dmg (it could be a variation of this, but it would start with 'AdobeFlashPlayer_17) and is less than 1MB in size, it's the online installer. If the name of the file is install_flash_player_osx.dmg and is about 15MB in size then it's the offline installer and it should install fine. Please confirm which file you're getting.
If get.adobe.com/flashplayer is still downloading the online installer for you, the offline installer is posted at the bottom of the Installation problems | Flash Player | Mac page in the 'Still having problems' section.
Thank you.
Maria
