cfprocparam is throwing ILLEGAL SYMBOL =;
May 14, 2015 May 14, 2015
Upgraded from CF10 to CF11 update 5 ( with hotfix hf1100-3971083.jar )
DB (DB2 v10.2)
getting an error on code that calls a stored proc.
Error Executing Database Query.
[Macromedia][DB2 JDBC Driver][DB2]ILLEGAL SYMBOL =;
The error occurred in ...: line 238
236 :  <cfstoredproc datasource="#application.dsn#" procedure="LIVE.SP" >
237 :     <cfprocparam type="In" cfsqltype="CF_SQL_BIGINT" dbvarname="STOPID" null="yes" />
238 :     <cfprocparam type="In" cfsqltype="CF_SQL_INTEGER" dbvarname="POID" null="no" value="#val( qry.id )#" />
239 :  </cfstoredproc>
The actual code looks like this - and works fine in CF10....
"qry" IS returning a value for "id"
<cfloop query="qry" >
    </cfstoredproc>
</cfloop>
This happens IF or NOT the 'debugging' is turned on (per hotfix hf1100-3971083.jar)
It seems there are others claiming cfprocparam issues - but the solutions to those issues are not fixing THIS issue.
Any Ideas?
478
Advocate ,
Have you taken a look at this thread - Stored Procedures stop working after Coldfusion 11 install (OS X 10.10.1)
As you moved from CF10 to 11u5 it might apply to you.
Looking at this post -
I tried adding the "@" (which IBM docs say IS the param symbol - IBM Knowledge Center)
    <cfprocparam type="In" cfsqltype="CF_SQL_BIGINT" dbvarname="@STOPID" null="true" >
    <cfprocparam type="In" cfsqltype="CF_SQL_INTEGER" dbvarname="@POID" value="0" null="no" >
</cfstoredproc>
NO LUCK - SAME ERROR
I also tried hard coding the value being passed - NO LUCK - SAME ERROR
Advocate ,
May 15, 2015 May 15, 2015
I assume the STOPID and POID vars are exactly correct as well? No misspelling at all?
On the DB2 server are you able to trace the request and get the full SQL that it thinks is being requested?
Documentation
