Every time I try to install it claims the link is broken, so how do you get the down load?
Hi andreas19064685,
In order to provide help as quickly as possible, please put the following information into your post:
Maria
Windows 7
Fire Fox
Connection Failed Click Re entry
Than it goes and the same thing happens over & over.
Hi andreas19064685,
Thanks for the additional information. This is the online installer and the connection error could be due to a few different issues. We'll need to obtain some log files to troubleshoot further. Please do the following to obtain the log files:
In addition to the log files, please run an internet speed test on your internet connection. There are a number of sites, such as http://www.speedtest.net/‌, http://www.speakeasy.net/speedtest/‌, that you can use to do this. Please provide either the download connection speed or the ULR to the results.
Also, when downloading the file are you saving it locally or do you select 'Run' from the download/save dialog? Do you have Virus protection and/or Firewall configured on your system? If so, which programs do you have installed?
Thank you in advance.
Maria
