I'm running Windows 8.1 x64, and trying to install the latest Flash Player for Firefox. I know there's already a topic for this, but the person didn't provide any detail and I don't feel like waiting forever when it's clearly an installer issue.
I've disabled my firewalls completely to try and install this. I've tried running a clean install (uninstalled flash player completely before attempting to reinstall, big mistake), rebooting and all. And tried both the default installer and the installer provided in the "troubleshooting."
And just to be sure I was getting the correct version, I let the download page detect my system AND tried selecting it myself:
My install gets stuck at 90% with the default installer for a good 1-2 minutes:
And then fails:
And, yes, I did click "Finish" to go to the supposed "further assistance" it speaks of in the error, but it opens a browser window and tells me what I already know: that the install was unsuccessful.
Then I went through the "troubleshooting" and ended up at the download link at the bottom:
When I run it (even right-clicking and "Run as Administrator"), it goes fairly quickly, but then stops at 100% and does nothing. When I click on the installer window at this point, Windows notifies me that the program has stopped responding:
And it never will respond.
Please fix your installer.
Thanks for the detailed description and screenshots. Very helpful.
For the online installer, I'll need to get some log files from you to troubleshoot. Please review the FAQ Where do I find the Flash Player installation log on Windows? and provide all files listed (Adobe_ADM.log, Adobe_GDE.log and FlashInstall.log). If this is a 64-bit OS both FlashInstall.log files (from system32 and syswow64 directories) are required. Upload the files to cloud.acrobat.com/send using the instructions at How to share a document and post the link to the uploaded files in your reply.
For the hung offline installer, I was not able to reproduce. The log files may provide information as to why this happened.
Thank you.
Maria
The 32 bit version of the log had no recent logs since July, back when I had this trouble before and tried to use the 32 bit version instead. The 64 bit version is the one with the random letters adobe cloud had provided for its name.
Anyway, here we are.
Hello, I wanted to provide some additional information to you for troubleshooting this issue.
Guide to Manually updating Flash Player for Windows
That is a guide I wrote that could possibly assist you with issues.
Also, you might want to try the adobe uninstaller, then use the standalone to reinstall, but make sure any Firefox process and flash ones are closed via task manager. You also might want to attempt the sfc /scannow command and to run windows updates as well
Best Regards
Please be sure to mark my post here helpful or answered if I assisted you
The two FlashInstall.log files provided are identical and are from the SysWOW64 directory. There is no log file from the system32 directory. Please provide the log file from the system32 directory. I do see a conflicting process error, indicating a process needs to be terminated before installation continues. When installing, does it display a message stating some application/process needs to be terminated.
