Hello,
I have an membership and pay each month, no problems with the payments, however my apps are telling me that the trial has expired and i have to buy them.
but when i look at my account, its just fine and i see the apps that i have an membership.
I reinstalled the creative cloud but it didn`t worked .
Well in that case, I would advise you to Contact Customer Care as the agent will remotely connect to you machine and fix the issue for you.
tried all but nothing worked..
forgot to mention ..i have a membership for at least 2 years now..
edit:
i installed it on a other pc and there are no problems at all.
I just started having this problem too, been paying for one year all fine until the last update rolled out and I started getting all these messages that I have 6 days left in trial. At first it wouldn't even let me open any of the programs and I had to uninstall everything and reinstall but now it still tells me I have 6 days left in trial and I can't risk not being able to use illustrator. I tried all the solution I found so far (tho they seen dated from 2015 about signin out, checking you account plans, using that special adobe program to check host)
i can see the other pc in my account ..but my own pc is not on the list at all
Can you see you`re pc on you`re account ?
Did you check the host files?
Are there any Adobe entries blocked?
The host files are clean.
Can you please check if you have followed all the steps in the help document: Solutions to sign-in, activation, and connection errors with Creative Cloud and Creative Suite appli...
It seems that i can`t acces secure sites,
However i am not behind a proxy , my clock settings are good and my firewall is also good.
Ok, i contacted the Contact Customer Care and the agent indeed fixed the problem ..
Tnks for all the help !
You are welcome!
