I was working in an InDesign file yesterday, and all was well. Today, if I hit the return button, all the text below is moved into a paragraph that cannot be seen. The frame now indicates that I have text outside the size of the frame. No matter how big I make the frame, the text does not appear. Even the frames I filled in with text yesterday are doing this today. What did I do?
Try Fn+Return combination then.
Edit: also you may find interesting to read this thread.
It will help if you open up the Story Editor (Edit > Edit in Story Editor) when you have your cursor in the story. You may be able to see a "break character" or something that is keeping the text from showing.
Nope, that doesn't help. Story Editor indicates that there is an overset as soon as I hit the return, but doesn't show any special character or space. When I return to the document, the text below the return is now all below the visible area of the frame, and the frame has a big empty space.
Thanks, though. Story Editor will be helpful in other ways.
Maybe your paragraph style has an accidentally giant space-after or space-before amount? Or if you were not using styles, maybe the default amount in the Control Panel is accidentally set too great an amount?
Which Enter key do you use? Enter on a main keyboard makes new paragraph. By hitting Enter key on the numeric keypad, you create a column break. If there's just one column in a frame, your text jumps to the next threaded frame. If there isn't such, your text is overset.
I mean, use the "green" one:
That's what I would have said, if you hadn't beaten me to it, Winterm!
Ah, "Ladies first", I was taught... I'm so awfully sorry, Barb!
LOL!
OK, this is leading us closer to the solution. I am back in the office today and working on a keyboard. What you say above is exactly true. If I use the return key on the main keyboard, I have no issue. If I use the return key on the number pad, I have the issue described.
However, yesterday, I was working on my laptop which does not have a number pad. The return key on the main keyboard was acting like the return key on a number pad.
I am using Creative Cloud, and it says all apps are up-to-date.
I don't know why my laptop is giving me the keypad return, but Fn+Return solves the problem.
Hi
Story editor can (again, yes! ^^) help you out here...
Set invisible characters ON and have a look at the symbol shown in the story editor, just before the excess separator.
which one is it:
If its "normal" return, did you check premio_oscar suggestion?
Don't forget screenshots are usually very helpful... maybe you can share some
regards
check this option:
paragraph style options > keep options > start paragraph
choose "Anywhere"
It would also good to know which version are you using. Due to a bug in 2 versions in the past (CS5 several languages, CS6 Swedish) the return key was tagged to the enter key. This could be repaired simply by an update.
interesting … the more common problem is hyphenation turned off and a word is too long for the display area … thanks for that article!
