What have you done ADOBE!
Hours to render!
Hours to encode a simple H264 project!
Meantime, my computer is completely crippled by processing power.
FIX 2017 build now!!
Hi there Geoff,
I branched your post into a separate one to focus on your issues more closely. Sorry to hear of your lengthy encoding times. Let's take a closer look, shall we?
- Hours to encode a simple H264 project!
- Meantime, my computer is completely crippled by processing power.
First of all, we need more info on your system and media: FAQ: What information should I provide when asking a question on this forum?
After you give us a bit more info to go on, I think we can help you troubleshoot a lot more successfully. The first thing I'd make sure of is if you have GPU acceleration enabled in File > Project Settings or not. Can you check that?
Thank You,
Kevin
I have the same problem.
Your reply from Adobe sounds like it's coming from a Robot. "Let's take a closer look, shall we?"
I've never had such piss-poor performance from a software program.
BTW- If I enable GPU acceleration (as recommended by Adobe) I get horizontal glitches throughout the video.
I had huge ongoing issues with PP2016 and now PP2017 is much worse.
A simple graphic will crash my computer.
I'm using the AMD FirePro D700 6144 MB cards I have installed in my Mac Pro (Late 2013)
3 GHz 8-Core Intel Xeon E5
32 GB 1866 MHz DDR3 ECC
It's a bit extreme, but...I have high confidence in your chance for success.
Try step 4.
Hi Chris S,
I was just trying to be polite and engaging. I assure you that I am not an automaton. I am a real person, born and bred in Northern California with around 30 years of editing experience. Hope I can help.
Must be your hardware or your media as I have very few issues on both my Mac and PC here in the office. Let's try some troubleshooting to see what you've got there.
That's unusual. I would say that the GPU issue seems to be at the heart of your problem as most customers are not seeing that. Have you updated your OS recently? Did you update the OS in the middle of a project? Did you update your project filetype from one major version of the program to the next mid-project?
That's also unusual. You should not be crashing on "a simple graphic." Which format is it in? Is it in RGB format? Is it a PNG, TIFF, JPEG, PSD? What is the bit depth of these files? What is the frame size?
Do you have a media drive for your media? How is it connected? In a RAID? Is it formatted properly? Is GPU acceleration enabled in Project Settings?
We could use more details about your case in order to help.
Kevin
Chris,
One more thought: I would also have Apple (Support) test your GPUs to make sure that they are not heat damaged. The glitches you describe have been found in some machines with heat damaged GPUs.
Kevin
Hi there Geoff, Chris,
Please let us know the status of the issue.
Vidya Sagar.
