Hello. Lightroom CC hangs all the time. And i don't think that its because of PC. I noted that it works faster when i makes smaller window of lightroom.
Info about this PC:
Lightroom version: CC 2015.9
Operating system: Windows 10
Version: 10.0
Application architecture: x64
System architecture: x64
Logical processor count: 6
Processor speed: 3.5 GHz
Built-in memory: 16383.1 MB
Real memory available to Lightroom: 16383.1 MB
Real memory used by Lightroom: 787.1 MB (4.8%)
Virtual memory used by Lightroom: 866.4 MB
GDI objects count: 805
USER objects count: 2716
Process handles count: 1569
Memory cache size: 0.0MB / 3839.7MB (0.0%)
Maximum thread count used by Camera Raw: 6
Camera Raw SIMD optimization: SSE2,AVX
Camera Raw virtual memory: 247MB / 8191MB (3%)
System DPI setting: 144 DPI (high DPI mode)
Desktop composition enabled: Yes
Displays: 1) 3840x2160
Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
Graphics Processor Info:
GeForce GTX 1060 6GB/PCIe/SSE2
Check OpenGL support: Passed
Vendor: NVIDIA Corporation
Version: 3.3.0 NVIDIA 378.78
Renderer: GeForce GTX 1060 6GB/PCIe/SSE2
LanguageVersion: 3.30 NVIDIA via Cg compiler
Does anybody has the same problem? Thank you!
Try to deactivate the GPU and see if this helps:
Adobe Lightroom GPU Troubleshooting and FAQ
Can you be a bit more specific about 'hangs'. Locks up, slows down or ... and when you do what exactly in which module of LR?
Please also post the exact type of your CPU.
i did deactivate the GPU but it didnt help( all movements in lightroom looks like slideshow. very difficult work with brush and graduated filter becouse of that. i have
amd fx(tm)-6300 six-core processor 3.5 ghz
LR does not play well with more than 4 cores.
Read here: Terrible performance in LR - Fantastic in PP. What gives?!
i turned off cores but it didn't help.
I think resetting the preferences does not help., but since it cures all sorts of strange effects in LR I'd try: Resetting Preferences in Lightroom CC/6
Otherwise, I'm out of ideas except for a reinstall of LR: Download Photoshop Lightroom
Basic 6.0 first, test and then upgrade to 6.9.
Me too. Lightroom just hung three times doing simple work. Happen twice when I change from develop to library and once when i changed from smugmug to Library. Very frustrating.
This brushing and spot healing are known problem in Lightroom, especially with your large 4K monitor. There are several things you can try to speed things up:
