Hi
I'm trying to write (read: copy and paste bits of code from around the web) a script that adds a section to the active page with a section marker that the user defined through a prompt. This input is then sliced to also create the section prefix.
Now I went and looked at JongWare's excellent Object Model database for the sections.add() entry, and this entry in the ExtendScript API on GitHub. But I am really confused on how to fill in the add ([reference: Page][, withProperties: Object]) to define the section as the active page with the marker and the prefix defined by the user
Any help is appreciated
This is what I have so far.
var myDoc = app.activeDocument;
var aPag = app.activeWindow.activePage.name;
var sName = prompt("Input section name","","Section name");
var sPre = sName.slice(0,2);
myDoc.sections.add( xxxxxx );
PS. This thread is closest to my question, but has not been answered and is getting quite old.
PPS. I have the latest CC version.
Just for starters. Of course you will need to make sure the page selected does not have a section applied already, etc.
try {
var aPag = app.activeWindow.activePage;
var sName = prompt ("Input section name", "", "section name");
var mySection = myDoc.sections.add(aPag, {sectionPrefix:"B", includeSectionPrefix:true,marker:sName});
} catch (e) {
$.writeln("Error "+e.message+" at line "+e.line);
try {
} catch (e) {
Yes, this works perfectly (if no section is applied yet)!
Just to understand: the add() command is filled in with
add(startPage, {sectionProperty1: value, sectionProperty2: value})
And the sectionProperties can be found here.
I'm quite now to coding so I'm still trying to understand the structure.
Thank you!
A reply, since I can't seem to edit my previous post:
I added a check to see if there is a section marker already applied:
var aPag = app.activeWindow.activePage.documentOffset;
var s = myDoc.pages.item(aPag).appliedSection;
var apSec = s.marker;
if(apSec == ""){
var sName = prompt ("Apply a new section:", "", "section name");
var mySection = myDoc.sections.add(myDoc.pages.item(aPag), {sectionPrefix:sPre, includeSectionPrefix:true,marker:sName});
} else {
alert("Section with name " + apSec + " already applied");
Perhaps this is useful for somebody else...
