Hopefully, I am posting this in the right place.
I have a problem with a website I am developing. The menu item at the top right's hyperlinks are not working. I've checked in Muse and they are definitely there. My website is at www.film42.com.
I am using Muse CC 2017.
All menu items except "contact" are working here.
Beside this: Your page works very poor on tablts and smart phones, bevause you don't respect the defined page/breakpoint width.
On my side, all menu items seem to work. Contact opens my email window.
As this site is "under construction" I try to ignore the fact, that menus on all following pages are missing.
This might be annoying for users at the end. But this, was not not your question, I guess.
For Günter Heißenbüttel​: I thought, if layout is responsive, breakpoints don`t have to follow any rules? Maybe ksangani​ had the same thoughts?
Uwe
Thanks Gunter. No. It wasn't any of those. In any-case, I have rebuilt the menu from scratch.
Thanks Fotoroeder. I agree it needs work - especially in tablet mode. I'm on it.
Also, after I rebuilt the menu and deleted the old, a weird behaviour is now occurring with the mobile menu. It first appears after the first breakpoint (as desired) but then disappears after scrubbing through the second breakpoint. It seems to be there on the preview and in design mode. Attached is a screen recording of these modes. You can see this on the screen recording (attached).
Isolate the menu, place it into a new Muse document, upload it to Dropbox or a similar filesharing service and post the download link here. Then we can have a look without guessing and assuming.
Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
Many thanks in advance.
Kris.
Hi Gunther. Please ignore the link above. It was just the element. I have now embedded the menu element into a document. Here is the link.
I do know, why your menu (let´s call it hamburger without meat), does not appear on white. It is set to active as kind of grey but in normal state set to white. Then it is a white cat in the snow. You can touch it, changes the mouse to hand ...
Have a look at the states in the upper left corner, then you will see your menu, I hope.
Uwe
This is not the only issue! Menus within lighboxes don’t work correctly in actual Muse (You remember, Uwe? )
Of course I remember, but with the transition set to vertical or horizontal it does work, doesn`t it. His ksangani​ last issue was, that the hamburger didn´t appear. This should be solver with the states set correctly, right?
… but the "Close" button sometimes doesn’t disappear when clicked.
It is, on my side, even worse. Trying the menu twice, it doesn`t close the menu itself anymore.
So, if the composition widget does not work reliable, what do you recommend? Or, what is common sense?
Using an accordion with only one panel and put the menu in there? I heard, that chrome creates issues with accordions?
Or does this depend only, if the menu is created with several panels, function as menu buttons? Or do I mix something up?
Might sound dumb, did you clear your cache and reload?
Have no time to go in depth with this issue. I think, compositions have problems, when triggering a lightbox in context with breakpoints. I'd simply avoid lightboxes in this case and wait, what the next major update with responsive composition support will reveal …
Thanks ...
