I am running MacOSX 10.11.6 and Premiere Pro CC 2017.1.1. v11 Tanq and Media Encoder CC 2017.1 11.1.0.170 (most recent versions)
For an advertising campaign I am running into a persistent problem with a Premiere Pro project to a MFX file with a corresponding XML document.
Because of this the broadcaster refuses to accept the file because "Duration" and "TimeOut" metadata is not showing.
I have found, read and tried these previous discussions and guidlines
Managing metadata in Premiere Pro
MXF files not showing full media duration in Premiere Pro CC, Please help!
Still no metadata
But the final result is still missing any form of metadata like "Duration" and "TimeOut" [TC_OUT]. In my search to find the solution and attempt to solve this very painful problem, I have added these metadata fields to the project metadata and have selected the corresponding schema for export but still no luck after exporting to MXF.
I also tried the same exporting the MXF file form Media Encoder and still no luck. The file plays as intended in a compatible player but no metadata is then available.
What might be the issue here?
I hope someone has the answer otherwise I will be cancelling my CC subscription.
Jonathan
Have something to add?
