Hi
I'm designing a website in Muse, and everything works perfectly on the desktop layout, but when I preview the Tablet layout in browser, the content is being pushed to the left I just can't figure out what is causing the problem, there is no text box or an object hidden somewhere on the far right or left.
I checked the Tablet master and everything is ok there, I have no idea how to fix this.
Hopefully, the community can help
Using the developer tool from Safari it looks like this on my side with only your master:
Although I pinned the footer element to the center and the menu to the right, on higher resolution the design looks like left aligned on iPad Pro.
Watching out the page properties I realize this:
If you change this to center it shows hopefully like this on iPad Pro:
Does this help?
Let me add, that all these beautiful scroll motion effects are unpredictable on devices with the "i" in it.
Best Regards,
Uwe
Normally in these cases, there´s something outside your canvas and your browser tries to show it.
Try: Select All and watch out, if you could detect something.
Best Regards,
Uwe
There is nothing outside the canvas of the page or of the Master
Could you provide a simple .muse with only one page? Please follow this suggestions:
Please Provide a .muse File to Help Us Fixing Your Issue!
Best Regards,
Uwe
Does this help?
Best Regards,
Uwe
Thank you for trying but, that did not help
But I think that I might have found the problem, I'm using a widget for Animated Entry from QooQee,
it's located outside the canvas, but doesn't matter if I move it onto the canvas, it will still cause the issue.
But on my side it wasn`t left aligned any more. It seems to be OK on your screenshot as well? What am I missing?
Uwe
The second screenshot shows what happens when I delete the widget that creates the entry animation, but I need this widget.
Then my last suggestion: Ask QooQee about it. If their widget causes the issue … .
But also, these scroll motion effects are really not recommended for mobile devices.
Best Regards,
uwe
Thank you for the help!
You`re welcome. If it takes too long to wait for support, let us know.
Best Regards,
Uwe
