Can I make a drop down paypal button in Muse? I want list Photography packages amounts by using a drop down menu.
Thank you for your help
Debbie Shotwell
For this approach there´s no widget, I guess.
The "Password" widgets I know, do not even claim for themselves to be save – code-experienced people (known as coders ) could easily detect the password from the source code.
Depending on the amount of people Karen wants/needs to shoot throughout the years, I would recommend a valid shop system like for example in Germany there´s one called "www.fotograf.de".
It provides generated codes for each person you photograph, and later you pass this code togeth
...Copy link to clipboard
What exactly do you want? Do you have an example?
You could start with a composition, you could also try the accordion (maybe the easiest way).
It depends on, where on the page you want to have this PayPal button.
To clear it up, like this the PayPal button is just a graphical button, with a drop down menu/list/paypal inside.
In this dropdown you will have to place the "real" paypal.
Does this help?
Best Regards,
Uwe
I want to create a dropdown menu of different sized photo packages with a
Add to Cart button. I don't see a paypal option in Muse is there one?
On Sun, Oct 15, 2017 at 5:13 AM, fotoroeder <forums_noreply@adobe.com>
In the widget panel – social (or social media) – …
Try it with a composition or an accordion.
This lets you have individual sizes for your button. With accordions the buttons and the dropdown are the same width.
Best Regards,
Uwe
Can you explain how I would integrate the accordion and paypal buttons to
work together?
On Mon, Oct 16, 2017 at 2:24 AM, fotoroeder <forums_noreply@adobe.com>
work together?
Same as with the composition. Drag elements to the desired place in the accordion – one for the trigger and how much you like for the target. Show us an example of your picture what you want to sell and how this should look like.
Best Regards,
Uwe
When I try to paste it from paypal it pastes outside of the accordion, I
can't edit the spacing between each element, technically I wouldn't need
the accordion if I could edit spacing. If I try to use the paypal widget
there is no option to use a drop down for more than one price. I would need
to use a button for every price. If there is another way to use it please
explain how to me.
On Mon, Oct 16, 2017 at 8:56 AM, fotoroeder <forums_noreply@adobe.com>
No understanding on my side. Please provide a .muse, following these rules:
Please Provide a .muse File to Help Us Fixing Your Issue!
Uwe
This is a link to the folder in dropbox.
https://www.dropbox.com/s/nnxoqptna8e7wfp/Karen_Photography.muse?dl=0
I put a couple notes on the page. The accordion is there because Adobe told
me I could use it to make the drop down work, but I haven't figured out how.
Thank you for your help.
Debbie Shotwell
On Mon, Oct 16, 2017 at 2:17 PM, fotoroeder <forums_noreply@adobe.com>
Master: Don`t use system fonts, it behaves like an image and not like text.
Watch my suggestion: Dropbox - Karen_Photography_Accordion.muse​
I think, there´s a lot to think as the future customer to make this work altogehther.
Best Regards,
Uwe
No, it doesn't look professional at all. Maybe I need to use a different software.
Thank you for your help!
It is not only a software task.
It is more, what you, or even better, the user wants to achieve.
Watching your site I as a user see at least two different people. I may see myself and somebody else?
I can buy someone else images?
Maybe you would need a code for each person to look at only the ones related to each person?
On the other hand, if this page is meant to be only information about prices, then you wouldn´t need a PayPal, right?
So yes, finally, maybe you better look for a stable shop system, where most features are already integrated.
Best Regards,
Uwe
This is just an example page, so it's not set up correctly yet. One of my
questions preciously was how to set it so that my customer would need a
code to view their pictures. Can you tell me how I would do that or what
widget I need for that?
On Tue, Oct 17, 2017 at 4:11 AM, fotoroeder <forums_noreply@adobe.com>
It provides generated codes for each person you photograph, and later you pass this code together with the pictures inside an album, so that only people, who know the code, can watch and purchase these images.
For Karen the "workaround" could only be to create subpages like "karen-photography.com/clientwithsomeaddtionals1".
These should be uploaded to subfolders, named: clientwithsomeaddtionals1 on her FTP. I don`t know how experienced Karen is, as I said, depends on the amount of people.
I don`t recommend this really – the other solution comes around with some money to be paid . If she earns money, well then go for it.
From this forum I know Günter Heißenbüttel​ who works with shop system(s). Maybe he has a different/additional opinion to this?
Best Regards,
Uwe
Also, do you know if there is a midget or way to hide a page so that a
customer would use a unique code to view its content? An example would be
to see there pictures from a photo shoot.
Thank you so much for your help.
Debbie Shotwell
On Sun, Oct 15, 2017 at 10:53 PM, Debbie Shotwell <dmshotwell@gmail.com>
No, this is not possible for Muse out of the box.
You need a stable CMS for that with shop system and so on. You may use some automatic generated code, this needs a proper shop system. Best to use a shop system which already has these features – code and so on.
I am not sure if the shop systems from musewidgets.com provide something like this.
Best Regards,
Uwe
