It used to work on previous iterations, but now when setting a simple horizontal navigation widget to 'stretch to browser width', it doesn't. Plus, if you attempt to pin it to the centre, it doesn't.
With a single page site, the nav widget does remain fixed to browser width [however that's pretty pointless, design-wise]. The moment you add a second page - the automatic functionality, where the widget adds subsequent page headers, causes it to fail.
It then reverts to being left aligned, and set to maximum width of your Muse doc NOT the browser width as the settings instruct.
Is this another bug? How can I fix it?
Which „100 % width issue“?
If you are talking about misplaced elements, if there is a browser wide element on top: Yes, this is fixed.
Show us an almost empty .muse with some empty pages with your menu, how you set it up and we´ll have a look at.
Best Regards,
Uwe
We will able to debug the issue if you can share muse file where you are seeing.
The latest update to Muse is ready for download. This update addresses most of the issues reported since 2017.1. Please confirm these fixes as soon as you have had a chance to test them.
There is one new feature in the latest update, and it is a feature that will help you make a smooth transition to a next update allowing you to go back and use your files in a previous version of Muse in case it becomes necessary.
Automatic creation of a backup file after you convert files to the next version:
When you open an existing Adobe Muse file using the latest version of the application, file conversion takes place. Earlier, after the file conversion, when you saved your file, you were not able to open the file in an older version of Adobe Muse.
Now, when you open and save an existing file in Adobe Muse (2018.0), you see the following warning message:
If you click OK, a backup file is saved in the same location as your original file. You can use this backup file with the older versions of Adobe Muse.
Note: The backup file is created only for those files that are converted after you open the file using the latest version of Adobe Muse.
More details provided in this doc - https://helpx.adobe.com/muse/using/whats-new.html.
Ankush
Does this update fix the 100% width issue?
