• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
FAQ: The File Cannot Be Opened Because of a Header Error
Adobe Employee ,
Mar 10, 2023 Mar 10, 2023
Unable to import your image(s) to Premiere Pro? Does “The File Cannot Be Opened Because of a Header Error” pop up? Adobe Expert, Jens Trimmer, created an article and video containing fixes for the issue. Check these out.
Here's Jens' updated troubleshooting guide if you run into the error:
https://videowithjens.com/premiere-pro-the-file-cannot-be-opened-because-of-a-header-error/
Jens also made a video about it:
https://www.youtube.com/watch?v=JtpyTbWZWJ8
TOPICS
FAQ
Views
32.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
replies 159 Replies 159
New Here ,
Jul 22, 2021 Jul 22, 2021
I had the same problem on my mac, and for me it helped to click in Textedit on format, convert to plain text. Then it saves the text as a .txt instead of a .rtf, and if you change the extention from .txt to .srt and PremierePro will understand it now.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Dec 13, 2016 Dec 13, 2016
I edited a short film in Premiere.  In order to make a DCP I exported the picture as a jpeg sequence.  I wanted to put it back into Premiere so I could watch it and make sure there are no problems, but when I try to import it I get the following error message:  The file cannot be opened because of a header error.
Elsewhere I have seen the advice to import the jpegs into photoshop and re export them, but I have over 12000 of them, so this isnt a great solution.
Anyone know what is going on?
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 23, 2021 Apr 23, 2021
I'm trying to import an MP4 into Premiere Pro & have never seen this error before - The File cannot be opened because of a header Error
Screenshot attached. I've tried converting the file in Handbrake to see if I can then import that version, same error. I've seen a lot of suggested fixes for photos importing into PP, but this is a video (MP4)
Is there a fix for this? It's a simple interview clip downloaded from web, something I've done 1000x not sure how to fix?
Votes
Translate
Translate
Report
Report
Community Expert ,
If Handbrake does not fix it I don't know what will.
Votes
Translate
Translate
Report
Report
Contributor ,
Jul 20, 2019 Jul 20, 2019
HI All,
I am getting an error while trying to import a .wmv file.
The message says: The file cannot be opened because of a header error
Does anyone know exactly what this means and a possible solution?
Thanks in advance!
Votes
Translate
Translate
Report
Report
Community Expert ,
File is corrupted
See if https://handbrake.fr/ open source transcoder/converter will read the file, and output a new file
Votes
Translate
Translate
Report
Report
Contributor ,
John,
Handbrake option worked! Thank you for suggesting that. I really appreciate it!
Votes
Translate
Translate
Report
Report
Community Expert ,
Jul 21, 2019 Jul 21, 2019
Glad it worked... file corruption issues can be hard to fix
Votes
Translate
Translate
Report
Report
Guest
Dec 19, 2020 Dec 19, 2020
Same here. But if I click and drag the file in to the project panel, the sound is cut out?
Votes
Translate
Translate
Report
Report
New Here ,
Feb 27, 2020 Feb 27, 2020
I was having the same issue, changed file type to AVI from WMV and it worked perfectly.  Just the same as some who had issues with jpegs changed to bmp's
Votes
Translate
Translate
Report
Report
New Here ,
Feb 08, 2013 Feb 08, 2013
When I imported .avi video file into Premiere Pro CS6, only the audio played. I used VLC to convert the .avi file to .mp4 through a batch file. Now when I try to open the .mp4 file into Premiere Pro CS6, I receive an error "File cannot be opened because of a header error".
I've tried converting the .avi file to .mov and .wav but they receive the same header error.
I've also tried opening in Audition and resaving it as .wav pc but it still won't import to Premiere.
Votes
Translate
Translate
Report
Report
Community Expert ,
First, depending on what is inside the AVI file, it should/might be "naturally" supported by Premiere
Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
What is a CODEC... a Primer http://forums.adobe.com/thread/546811
What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
http://forums.adobe.com/thread/592070?tstart=30
For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
For Mac http://mediainspector.massanti.com/
Also, for the future when you post...
More information needed for someone to help... please click these links and provide the requested information
-Information FAQ http://forums.adobe.com/message/4200840
-Effective questions http://forums.adobe.com/thread/416679
-How to get help quickly http://forums.adobe.com/thread/419406
Votes
Translate
Translate
Report
Report
Guest
Aug 02, 2013 Aug 02, 2013
Do you use the correct setting to convert videos to mp4?Sometimes, I get the idea, that I use the wrong settings made the video stop, and start to buffer again. I hope you guys understand what I mean...
Votes
Translate
Translate
Report
Report
Community Expert ,
Post 3 shows you how to convert with the vlc player.
http://forums.adobe.com/thread/1149978?tstart=0
Votes
Translate
Translate
Report
Report
Guest
Aug 13, 2013 Aug 13, 2013
AVI is not a good editable format for Adobe Premiere Pro CS6, if you wanna a smooth editing, you can encode the avi files first. As far as I know, MPEG is good format for Adobe with relatively small video size. There's a relevant threat talks about the AVI to Premiere Pro CS5/CS6 issue and offers the final solution.
Votes
Translate
Translate
Report
Report
Community Expert ,
MPEG is compressed and is not as good to edit as AVI - Why not edit mpeg http://tangentsoft.net/video/mpeg/edit.html
The OP (Original Poster) still has not come back with information about what is inside the problem AVI files... so we need to wait for more information
Votes
Translate
Translate
Report
Report
Guest
Apr 18, 2016 Apr 18, 2016
I think Premiere Pro CS6 is compatible with AVI. Maybe the issue is caused by the video codec of AVI file.
If you want to convert AVI to Premiere supported MP4 format, you may prefer to give this step by step tutorial a try.
It will tell you how to convert AVI to MP4, MOV, FLV, SWF, etc. Very userful.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 05, 2017 Oct 05, 2017
When attempting to import an SRT file, I get the error: “This file cannot be opened because of a header error”
Anyone know a fix for this? Thanks
Votes
Translate
Translate
Report
Report
Oct 06, 2017 Oct 06, 2017
Hi BuiltThisCityProductions,
I am sorry that you are not able to import SRT files into Premiere Pro.
Kulpreet Singh
Votes
Translate
Translate
Report
Report
Jan 23, 2018 Jan 23, 2018
I had the same error message when importing an .srt file that I had made by hand.
The error message has nothing to do with the header of the file or the format of the .srt.
When only a single subtitle has a duration of 00:00:00,000 Premiere Pro fails to import it.
The solution is to edit the file in a text editor and inspect it whether any of the lines have a duration that looks inconsistent. (overlapping or very short length do not matter). Then correct the file an save it with UTF-8 encoding.
Votes
Translate
Translate
Report
Report
New Here ,
Sep 07, 2018 Sep 07, 2018
Hi
I had the same issue and the YouTube trick is too much complicated.
The main reason why Premiere does not import the SRT file is that it recognises only text files saved with Windows and not with macOS's TextEdit. The latter encodes slightly differently the line breaks.
Here's the method that works all the time: just open the SRT file in BBEDIT (the app is free forever despite the message proposing you to pay to unlock advanced features but you don't need them) and Save As... and be sure to use the following options.
And if the last subtitle does not appear, just add an extra one with dummy content.
Votes
Translate
Translate
Report
Report
New Here ,
Dec 31, 2020 Dec 31, 2020
That was the solution for me, thank you! I wonder why Apple / Adobe don't address it.
Votes
Translate
Translate
Report
Report
Jan 08, 2023 Jan 08, 2023
Tried this but BBEDIT wont open the SRT file. It's greyed out
Votes
Translate
Translate
Report
Report
New Here ,
Jan 30, 2018 Jan 30, 2018
Hi all,
I have just moved over from Mac back to PC and traded in iMovie and Final Cut for the Adobe software and am going through the most immense growing pains.
I am trying to import 4 JPG files into Adobe to no avail - It comes up with an Import Failure Header Error . I have tried re-saving them as a jpg from photo editing software as recommended by other forums and this has not work. Any suggestions?
Thanks.
Votes
Translate
Translate
Report
Report
LEGEND ,
Make sure the pics are saved using RGB and not CMYK color
Jeff
Votes
Translate
Translate
Report
Report
