I have some security camera footage I need to analyze for a client. It's a 704x480 AVI using an IMM4 codec. It plays in WMP on several computers, however PPro does not like this codec. IMM4 VCM is new to me, but after reading up on it, it appears to show up in several security DVR products.
I'd like to get Adobe PPro happy with this format so I can load the files. I want to tile them up and scrub through hours of footage. Also, it is imperative that I maintain the quality of the picture (well....it's a poor quality image...typical surv cam footage....but I cannot afford to alter the image any further) and if I cannot get PPro hip to this format natively, I'll have to figure out a way to convert it, and in order to preserve the picture, that will probably mean uncompressed AVI, which, given the amount of footage, will really suck.
Any help you can give would be appreciated.
Thanks.
Buck Wyckoff
Buckward Digital
Check with the security company to see if they have a codec which you may download and install for PPro editing
ADDED
It says VLC will convert a different problem codec in reply #6 http://forums.adobe.com/thread/1172956 so give that a try
Thanks.
I know it is Mpeg4 because the device lit says so. So #6 in that thread sounds like it may work.
One thing: What is Vlc?
Turns out VLC does not like IMM4 either. Oh well.
Using Google, I found https://forum.videolan.org/viewtopic.php?f=7&t=41968&start=0 which says Lorex has a codec
YMMV and all the usual disclaimers (ie-try the Lorex link at your own risk !!!)
PS - Lorex is a good company, I own one of their security DVR systems
My warning was because I have never tried to extract/edit anything from the DVR, so I have NO personal knowledge about their codec
Usually the driver comes with that if you do a backup from your DVR to a CD or USB. It will have a player, video, info, setup.exe. If you run the setup.exe, you should be able to play in anyplayer. I am trying to upload the setup file and having a hard time. Will update to this thread once I have the link from a fileshare site.
