So far no luck getting Premiere CC 2014 or 2015 to recognize my CUDA GPUs that were working before Win 10 install (was running Win 7). However got CUDA to work on the original 2014 release on Win 10, but of course my current save files wont work with that version and the FCP XML export isn't a great option right now. Anyone with similar issues? Also noticed that Adobe might have dropped support for the Tesla C2075 and Quadro 600 for 2015 release?
Current Setup:
Model: HP Z420 Workstation
Baseboard ID: 1589
BIOS version: 3.50 (Current Setting Group: Premiere Pro CC)
Processor: Intel(R) Xeon(R) CPU E5-2687W @ 3.10GHz
Enabled Processor Count: 16
Total Memory: 32 GB
Local Storage: 18.66 TB (14 drives)
Graphics Card & Driver 1: Tesla C2075 -- 353.62
Graphics Card & Driver 2: Quadro 600 -- 353.62
Slots in use:
SLOT 2 (PCI Express Gen 3): Quadro 600
SLOT 5 (PCI Express Gen 3): Tesla C2075
Operating System: Windows 10 (64-bit)
Current Culture: en-US
Moving to Premiere Pro‌
Also just confirmed that Mercury Playback works on Premiere Pro CS6 with Win 10, just an issue with CC 2014.2 and 2015
Does anyone know if it works on Premiere Pro CC 2013?
I also have this problem with the GeForce GTX675M (driver v353.62).
It worked fine before the Windows 10 upgrade, now I cannot enable mercury.
Although it seems to be working in Media Encoder.
That is the notice that I get stating "This project was last used with mercury playback engine GPU acceleration, which is not available on this system. mercury playback engine software only will be used. This happens after updating to windows 10
This morning I had a similar issue, but was able to solve. (May be too late for you, but in case it isn't).
Back story:
I originally created a project in premiere, and even exported when I thought I was finished. I was able to use OpenGL. That night, my windows 10 updated. Next day when I opened the same project it I got the error you mentioned: "This project was last used with mercury playback engine GPU acceleration, which is not available on this system. mercury playback engine software only will be used".
Solution:
I ran GPUsniffer.exe located in "C:\Program Files\Adobe\Adobe Premiere Pro CC 2015". After that, I opened that same project and no longer had the error and was able to use the OpenGL renderer.
All I had to do was run the sniffer. Maybe this will help someone...
My modest setup (for reference):
i5 6400, 8gb RAM, Intle HD Graphics 530 (awating nVidia 750 ti)
Confirmed!
Thankyou arielreyes001
I closed Premiere Pro, then ran GPUsniffer.exe in the C:\Program Files\Adobe\Adobe Premiere Pro CC 2015 folder which simply opened a little window with nothing inside for a minute or so, then closed.
I then ran PPro CC and the mercury playback using cuda was now available.
I don't know where you got that info but it is good info! Thanks.
CUDA Mercury Playback Engine no longer working on Premiere CC 2014 or 2015 w/ Windows 10‌
Thanks much. This worked (at least so far) for Premiere CC 2015 and AE CC 2015.
HP Z640
Intel Xeon CPU E5-2620 v3 @ 2.40 GHz
48GM RAM
64-bit OS Windows 7
Tried Technical Support. No real answer as of yet:
Fitz: Faulting application name: Adobe Premiere Pro.exe, version: 9.0.1.36, time stamp: 0x55acd8dd Faulting module name: nvoglv64.DLL, version: 9.18.13.4762, time stamp: 0x55b03182 Exception code: 0xc0000005
Fitz: The program Adobe Premiere Pro.exe version 8.0.0.169 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Fitz: Faulting application name: SpeedGrade.exe, version: 9.0.1.0, time stamp: 0x55ab0242 Faulting module name: nvopencl.dll, version: 8.17.13.5362, time stamp: 0x55b03336 Exception code: 0xc0000005
Fitz: those are the only three that pertain to anything adobe
Anamika: nvoglv64.DLL-->this is related to your graphics card drivers
Anamika: nvopencl.dll->this is also related to your graphics card
Anamika: please uninstall and re-install graphics card drivers
Anamika: if still happens
Anamika: contact nvidia to get it sorted
Fitz: I've reinstalled a few times since those errors yesterday, but Premiere CC 2014.2 and 2015 are still having issues not seeing the cards, CS6 and CC 2014.0 are working and using the mercury playback
Fitz: Has adobe dropped the support for Tesla C2075 and Quadro 600 for 2015 release?
Anamika: https://helpx.adobe.com/premiere-pro/system-requirements.html
Anamika: check here
Fitz: They aren't listed for 2015, but nothing was noted that if the cards wouldn't work anymore or would have limited use.
Anamika: if not listed
Anamika: then it means not supported
Fitz: But for CC 2014 they are listed still, however it isn't running with the current setup on Windows 10.
Anamika: then downgrade the driver version and check with 2014
Fitz: Just wondering if anyone has had this issue yet or anyone at Adobe has taken note of this problem. I did the downgrade to the original before Win 10 and it still didn't work for the 2014.2 version.
Anamika: nope not till now
Fitz: Ok
Fitz: Just to make note again, CS6 and the original CC 2014 of Premiere work with my current setup, its just the newest version of CC 2014.2 and 2015 that are having issues. I also have rendering out issues that have artifacts in the video that are also seen in the playback on CC 2014.2 and 2015. Don't know if there is a way to show this to you for documentation.
Sean Fitzgerald: Since I can't send you anything higher than 10MB
Anamika: try changing the sequence settings
The sequence settings are the same through out the all versions of premiere, so it has to be a fault with the driver combo with Win 10 and the newer versions of Premiere (also 2015 version of SpeedGrade is crashing on startup just like when they released the 2nd version a few years back). Still odd that on Win 7 w/ CC 2014.2 worked, but now its still only CS6 and CC 2014.0 that are seeing the CUDA cards on Win 10.
Same here. Quadro 5000 + Tesla C2075 and Windows 10. Mercury Playback Grayed Out.
I believe it's GPUSniffer that is causing the fault, being that it can't supposedly initialize the graphics cards.
C:\Program Files\Adobe\Adobe Premiere Pro CC 2015>gpusniffer
Caught structured exception!Full test failed, trying no OpenCL
--- OpenGL Info ---
Vendor: NVIDIA Corporation
Renderer: Quadro 5000/PCIe/SSE2
OpenGL Version: 2.1.2 NVIDIA 353.62 10.18.13.5362
GLSL Version: 1.20 NVIDIA via Cg compiler
Monitors: 2
Monitor 0 properties -
Size: (0, 0, 2560, 1440)
Max texture size: 16384
Supports non-power of two: 1
Shaders 444: 1
Shaders 422: 1
Shaders 420: 1
Monitor 1 properties -
Size: (2560, 0, 2560, 1440)
Shaders 444: 1
Shaders 422: 1
Shaders 420: 1
--- GPU Computation Info ---
OpenCL test failed
Found 2 devices supporting GPU computation.
CUDA Device 0 -
Vendor: NVIDIA
Capability: 2
Driver: 7.5
Total Video Memory: 5375MB
* Not chosen because of initialization failure.
CUDA Device 1 -
Vendor: NVIDIA
Capability: 2
Driver: 7.5
Total Video Memory: 2240MB
Hi Patrics,
Have you tried the below 353.62 drivers for both the cards for Windows 10 machine supporting DirectX 12?
For Quadro: NVIDIA DRIVERS Quadro Desktop/Quadro Notebook Driver Release Windows 10 R352 WHQL
For Tesla: NVIDIA DRIVERS Tesla Driver for Windows WHQL
//Vinay
Try to install SR1 for Windows 10. This solved my playback issues.
I was hoping the SR1 would help, but still having the same issues.
I just installed Premiere CC 2015.0.1 on Windows 10 and it is recognizing the CUDA Mercury Playback no problem. I am also using 353.62. It actually runs better than it does on my 8.1 system. (I have a swappable c: drive to test new stuff like this.)
If you're comfortable trying a reinstall on your Windows 10 graphic drivers, here are some instructions I posted this on another site:
You can turn off driver only updates in Control Panel>System>Advanced system settings>Hardware Tab> Device installation Settings, then select "No, let me choose..." and select "Never install..." and leave the box at the bottom checked.
Then go to Nvidia or AMD, or whomever makes your card, and get the current drivers. However If you have a built in graphics card, or don't know where to get your drivers, I'd ignore the above advice. A clean install may help your system recognize the card for CUDA.
BTW, this only affects hardware drivers, not security and other updates (which is probably a good thing for video editors and musicians.)
Did a hard reinstall on most of my drivers a day ago and no luck with 2015 CC seeing the Tesla C2075 and Quadro 600. Don't know about 2013, but it seems like anything older than and including CC 2014.0 works perfectly fine with my current setup listed above, just the new versions of Premiere are still having issues with mercury playback and rendering out anything that would look like normal footage no matter what the sequence settings.
Think I have the same issue - rendering and playback are 7x (seven times) faster without cuda acceleration (GTX 980Ti graphic card)
Why Mercury Playback Engine Software is faster than CUDA ACCELERATION?
Last night Microsoft released a third service release. Not that it helped solve any issues
I have been looking at my graphic card usage in the Sysinternal Process Explorer. I have a Lenovo Z510 with builtin Intel HD4600 and GeForce GT740M, running Windows 10 and Geforce 355.60 (currently latest drivers) and running PPro 9.0.1 and Speedgrade 9.0.1.
I start both programs with right-click and select the Nvidia card for acceleration.
In my project I used a few level-corrections, some primary-correction and added a LUT in "creative".
When I play back in Premiere, the playback stutters. GPU dedicated memory is about 220MB and GPU Usage around 1.3%
Now, when I playback in in Speedgrade, the playback is slow, but I see all the frames. But now GPU dedicated memory is about 450MB and GPU Usage around 4.2%
I checked if Mercury CUDA playback is selected in Premiere for my project, and it is. So to me it looks like Premiere doesn't, or hardly uses CUDA playback, which causes the stuttering playback of graded clips. If I disable the Lumetri effect on a clip, it plays back fine. If I leave Lumetri on, but disable all the subsections, the playback keeps stuttering. Pretty odd stuff
I just built a new system. Here are my specs:
I7 5820k (OC to 4.2)
Asus X99 Extreme 4
16gb DDR4 Ram
Geforce 980
2 WD 650 Black Drive (Raid 0) (Project Files)
2 WD 2 TB Drive
1 External 1TB ESATA (Video Previews)
I'm having trouble with 4K playback with GH4 files and Phantom 3 Pro 4K with Premiere Pro CC 2015. I can playback at mostly full resolution and sometime it will start to drop frames with Mercury Playback installed. DJI Phantom 3 Pro 4K files drops frames at full, 1/2 res, and 1/4 resolution around 5 seconds into the clip, it drops frames. Any settings I can change? I'm running Premiere CC 2015.
I installed the CUDA 7.5 dev. kit. And updated to GPU-z 0.8.5. CUDA is now enabled. I deleted all preview files and started fresh. Same thing. Software playback plays GH4 & DJI Phantom 3 files fine, no dropped frames. When I enable mercury playback engine, it stutters and drops frames. Any help with this?
I'm having this issue as well. It started with the recent updated to Adobe CC 2017. It worked fine with Adobe CC 2016. My graphics drivers are the current and latest drivers. I get the error whenever I start After Effects. I can click OK, and go to settings and re-enable it, and everything is fine until I restart the app again.
I'm still running Windows 7 and I have two NVIDIA cards on my system.
Check nVidia control panel under workstation section. Select Manage GPU Utilization, the option to use for Graphics and compute needs may have gotten switched off. (turned it back on, problem went away) If your nVidia control panel does not have this option then your card is likely not capable of CUDA processing in Premiere
