Dear,
I am trying to install Flash Player ESR plugin via SCCM from Microsoft.
I tried with 2 different versions (18.0.0.241 and 18.0.0.261) but the problem still occur and I do not know what to do now.
To install I use the command : msiexec /i install_flash_player_18_plugin.msi /qn /l*v loginstall.txt
I tried to use the cleaner before installing on those devices but the error still occur.
You can find below the log i am encountering when i am trying to install.
=== Verbose logging started: 12/4/2015 13:51:56 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\Windows\system32\msiexec.exe ===
MSI (c) (2C:10) [13:51:56:053]: Resetting cached policy values
MSI (c) (2C:10) [13:51:56:053]: Machine policy value 'Debug' is 0
MSI (c) (2C:10) [13:51:56:053]: ******* RunEngine:
******* Product: install_flash_player_18_plugin.msi
******* Action:
******* CommandLine: **********
MSI (c) (2C:10) [13:51:56:053]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (2C:10) [13:51:56:053]: Grabbed execution mutex.
MSI (c) (2C:10) [13:51:56:062]: Cloaking enabled.
MSI (c) (2C:10) [13:51:56:062]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (2C:10) [13:51:56:064]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (A8:A0) [13:51:56:067]: Running installation inside multi-package transaction C:\Windows\ccmcache\dd\install_flash_player_18_plugin.msi
MSI (s) (A8:A0) [13:51:56:067]: Grabbed execution mutex.
MSI (s) (A8:84) [13:51:56:067]: Resetting cached policy values
MSI (s) (A8:84) [13:51:56:067]: Machine policy value 'Debug' is 0
MSI (s) (A8:84) [13:51:56:067]: ******* RunEngine:
******* Product: C:\Windows\ccmcache\dd\install_flash_player_18_plugin.msi
******* Action:
MSI (s) (A8:84) [13:51:56:159]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (A8:84) [13:51:56:167]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (A8:84) [13:51:56:167]: User policy value 'DisableMedia' is 0
MSI (s) (A8:84) [13:51:56:167]: Machine policy value 'AllowLockdownMedia' is 0
MSI (s) (A8:84) [13:51:56:167]: SOURCEMGMT: Media enabled only if package is safe.
MSI (s) (A8:84) [13:51:56:167]: SOURCEMGMT: Looking for sourcelist for product {8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}
MSI (s) (A8:84) [13:51:56:167]: SOURCEMGMT: Adding {8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}; to potential sourcelist list (pcode;disk;relpath).
MSI (s) (A8:84) [13:51:56:167]: SOURCEMGMT: Now checking product {8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}
MSI (s) (A8:84) [13:51:56:167]: SOURCEMGMT: Media is enabled for product.
MSI (s) (A8:84) [13:51:56:167]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
MSI (s) (A8:84) [13:51:56:167]: SOURCEMGMT: Trying source C:\Windows\ccmcache\db\.
MSI (s) (A8:84) [13:51:56:167]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI (s) (A8:84) [13:51:56:261]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (A8:84) [13:51:56:261]: Specifed source is already in a list.
MSI (s) (A8:84) [13:51:56:261]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (A8:84) [13:51:56:261]: Machine policy value 'DisableBrowse' is 0
MSI (s) (A8:84) [13:51:56:261]: Machine policy value 'AllowLockdownBrowse' is 0
MSI (s) (A8:84) [13:51:56:261]: Adding new sources is allowed.
MSI (s) (A8:84) [13:51:56:261]: Set LastUsedSource to: C:\Windows\ccmcache\db\.
MSI (s) (A8:84) [13:51:56:261]: Set LastUsedType to: n.
MSI (s) (A8:84) [13:51:56:261]: Set LastUsedIndex to: 1.
MSI (s) (A8:84) [13:51:56:261]: SOURCEMGMT: Resolved source to: 'C:\Windows\ccmcache\db\'
MSI (s) (A8:84) [13:51:56:263]: SRSetRestorePoint skipped for this transaction.
MSI (s) (A8:84) [13:51:56:264]: File will have security applied from OpCode.
MSI (s) (A8:84) [13:51:56:376]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Windows\ccmcache\dd\install_flash_player_18_plugin.msi' against software restriction policy
MSI (s) (A8:84) [13:51:56:376]: SOFTWARE RESTRICTION POLICY: C:\Windows\ccmcache\dd\install_flash_player_18_plugin.msi has a digital signature
MSI (s) (A8:84) [13:51:56:376]: SOFTWARE RESTRICTION POLICY: C:\Windows\ccmcache\dd\install_flash_player_18_plugin.msi is permitted to run because the user token authorizes execution (system or service token).
MSI (s) (A8:84) [13:51:56:376]: End dialog not enabled
MSI (s) (A8:84) [13:51:56:376]: Original package ==> C:\Windows\ccmcache\db\install_flash_player_18_plugin.msi
MSI (s) (A8:84) [13:51:56:376]: Package we're running from ==> C:\Windows\Installer\e99b980.msi
MSI (s) (A8:84) [13:51:56:377]: APPCOMPAT: looking for appcompat database entry with ProductCode '{8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}'.
MSI (s) (A8:84) [13:51:56:377]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (A8:84) [13:51:56:381]: MSCOREE not loaded loading copy from system32
MSI (s) (A8:84) [13:51:56:384]: Note: 1: 2205 2: 3: MsiFileHash
MSI (s) (A8:84) [13:51:56:384]: Machine policy value 'DisablePatch' is 0
MSI (s) (A8:84) [13:51:56:384]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (A8:84) [13:51:56:384]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (A8:84) [13:51:56:384]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (A8:84) [13:51:56:386]: APPCOMPAT: looking for appcompat database entry with ProductCode '{8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}'.
MSI (s) (A8:84) [13:51:56:386]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (A8:84) [13:51:56:386]: Transforms are not secure.
MSI (s) (A8:84) [13:51:56:386]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\Windows\ccmcache\dd\loginstall.txt'.
MSI (s) (A8:84) [13:51:56:386]: Command Line: CURRENTDIRECTORY=C:\Windows\ccmcache\dd CLIENTUILEVEL=3 CLIENTPROCESSID=9260
MSI (s) (A8:84) [13:51:56:386]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{D9D17B01-BB3B-4552-9C85-DEA3A865FDE8}'.
MSI (s) (A8:84) [13:51:56:386]: Product Code passed to Engine.Initialize: '{8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}'
MSI (s) (A8:84) [13:51:56:386]: Product Code from property table before transforms: '{8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}'
MSI (s) (A8:84) [13:51:56:386]: Product Code from property table after transforms: '{8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}'
MSI (s) (A8:84) [13:51:56:386]: Product not registered: beginning first-time install
MSI (s) (A8:84) [13:51:56:386]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI (s) (A8:84) [13:51:56:386]: Product {8656EDBE-7C0A-4945-8D49-493FDBE7B5BD} is admin assigned: LocalSystem owns the publish key.
MSI (s) (A8:84) [13:51:56:386]: Product {8656EDBE-7C0A-4945-8D49-493FDBE7B5BD} is managed.
MSI (s) (A8:84) [13:51:56:386]: MSI_LUA: Credential prompt not required, user is an admin
MSI (s) (A8:84) [13:51:56:386]: PROPERTY CHANGE: Adding ProductState property. Its value is '1'.
MSI (s) (A8:84) [13:51:56:386]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (A8:84) [13:51:56:386]: Specifed source is already in a list.
MSI (s) (A8:84) [13:51:56:386]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (A8:84) [13:51:56:386]: Adding new sources is allowed.
MSI (s) (A8:84) [13:51:56:386]: Package name retrieved from configuration data: 'install_flash_player_18_plugin.msi'
MSI (s) (A8:84) [13:51:56:387]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (A8:84) [13:51:56:387]: Machine policy value 'DisableMsi' is 1
MSI (s) (A8:84) [13:51:56:387]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (A8:84) [13:51:56:387]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (A8:84) [13:51:56:387]: Product {8656EDBE-7C0A-4945-8D49-493FDBE7B5BD} is admin assigned: LocalSystem owns the publish key.
MSI (s) (A8:84) [13:51:56:387]: Product {8656EDBE-7C0A-4945-8D49-493FDBE7B5BD} is managed.
MSI (s) (A8:84) [13:51:56:387]: Running product '{8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}' with elevated privileges: Product is assigned.
MSI (s) (A8:84) [13:51:56:387]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'C:\Windows\ccmcache\dd'.
MSI (s) (A8:84) [13:51:56:387]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '3'.
MSI (s) (A8:84) [13:51:56:387]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '9260'.
MSI (s) (A8:84) [13:51:56:387]: Machine policy value 'DisableAutomaticApplicationShutdown' is 0
MSI (s) (A8:84) [13:51:56:388]: PROPERTY CHANGE: Adding MsiRestartManagerSessionKey property. Its value is 'e1fbc51aadacd3488208b74be899ca61'.
MSI (s) (A8:84) [13:51:56:388]: RESTART MANAGER: Session opened.
MSI (s) (A8:84) [13:51:56:388]: TRANSFORMS property is now:
MSI (s) (A8:84) [13:51:56:388]: PROPERTY CHANGE: Adding PRODUCTLANGUAGE property. Its value is '1033'.
MSI (s) (A8:84) [13:51:56:388]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '110'.
MSI (s) (A8:84) [13:51:56:388]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming
MSI (s) (A8:84) [13:51:56:389]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\Favorites
MSI (s) (A8:84) [13:51:56:389]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Network Shortcuts
MSI (s) (A8:84) [13:51:56:391]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\Documents
MSI (s) (A8:84) [13:51:56:392]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
MSI (s) (A8:84) [13:51:56:392]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Recent
MSI (s) (A8:84) [13:51:56:393]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\SendTo
MSI (s) (A8:84) [13:51:56:393]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Templates
MSI (s) (A8:84) [13:51:56:393]: SHELL32::SHGetFolderPath returned: C:\ProgramData
MSI (s) (A8:84) [13:51:56:394]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Local
MSI (s) (A8:84) [13:51:56:396]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\Pictures
MSI (s) (A8:84) [13:51:56:397]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (A8:84) [13:51:56:397]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (A8:84) [13:51:56:398]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
MSI (s) (A8:84) [13:51:56:399]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (A8:84) [13:51:56:401]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
MSI (s) (A8:84) [13:51:56:401]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
MSI (s) (A8:84) [13:51:56:402]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
MSI (s) (A8:84) [13:51:56:403]: SHELL32::SHGetFolderPath returned: C:\Windows\system32\config\systemprofile\Desktop
MSI (s) (A8:84) [13:51:56:404]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Templates
MSI (s) (A8:84) [13:51:56:404]: SHELL32::SHGetFolderPath returned: C:\Windows\Fonts
MSI (s) (A8:84) [13:51:56:404]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (A8:84) [13:51:56:409]: MSI_LUA: Setting MsiRunningElevated property to 1 because the install is already running elevated.
MSI (s) (A8:84) [13:51:56:409]: PROPERTY CHANGE: Adding MsiRunningElevated property. Its value is '1'.
MSI (s) (A8:84) [13:51:56:409]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (A8:84) [13:51:56:409]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (s) (A8:84) [13:51:56:409]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'asccm'.
MSI (s) (A8:84) [13:51:56:409]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'PRODSCCM01'.
MSI (s) (A8:84) [13:51:56:409]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\Windows\Installer\e99b980.msi'.
MSI (s) (A8:84) [13:51:56:409]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Windows\ccmcache\db\install_flash_player_18_plugin.msi'.
MSI (s) (A8:84) [13:51:56:409]: Machine policy value 'MsiDisableEmbeddedUI' is 0
MSI (s) (A8:84) [13:51:56:409]: EEUI - Disabling MsiEmbeddedUI for service because it's not a quiet/basic install
MSI (s) (A8:84) [13:51:56:409]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (A8:84) [13:51:56:409]: Machine policy value 'DisableRollback' is 0
MSI (s) (A8:84) [13:51:56:409]: User policy value 'DisableRollback' is 0
MSI (s) (A8:84) [13:51:56:409]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
=== Logging started: 12/4/2015 13:51:56 ===
MSI (s) (A8:84) [13:51:56:411]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (A8:84) [13:51:56:411]: Doing action: INSTALL
Action start 13:51:56: INSTALL.
MSI (s) (A8:84) [13:51:56:411]: Running ExecuteSequence
MSI (s) (A8:84) [13:51:56:411]: Doing action: ISSetAllUsers
MSI (s) (A8:D4) [13:51:56:424]: Invoking remote custom action. DLL: C:\Windows\Installer\MSIC271.tmp, Entrypoint: SetAllUsers
MSI (s) (A8:20) [13:51:56:424]: Generating random cookie.
MSI (s) (A8:20) [13:51:56:426]: Created Custom Action Server with PID 11740 (0x2DDC).
MSI (s) (A8:7C) [13:51:56:454]: Running as a service.
MSI (s) (A8:7C) [13:51:56:456]: Hello, I'm your 32bit Elevated Non-remapped custom action server.
Action start 13:51:56: ISSetAllUsers.
InstallShield 13:51:56: Begin SetAllUsers()
InstallShield 13:51:56: Getting records from Upgrade table
InstallShield 13:51:56: UpgradeCode: {D85A1A59-DC52-4D13-9445-EF3F379D4DB5} MinVersion: 6.0.47.0 MaxVersion: 18.0.0.255 Language: Attributes: 769
InstallShield 13:51:56: Checking related product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}
MSI (s) (A8!6C) [13:51:56:462]: PROPERTY CHANGE: Adding IS_MAJOR_UPGRADE property. Its value is 'Yes'.
InstallShield 13:51:56: Adobe Flash Player 15 Plugin {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24} 1033 ***Related***
MSI (s) (A8!6C) [13:51:56:462]: PROPERTY CHANGE: Deleting ALLUSERS property. Its current value is '1'.
InstallShield 13:51:56: ALLUSERS of related product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24} is = 0
InstallShield 13:51:56: End SetAllUsers()
MSI (s) (A8:84) [13:51:56:463]: Doing action: AppSearch
Action ended 13:51:56: ISSetAllUsers. Return value 1.
Action start 13:51:56: AppSearch.
MSI (s) (A8:84) [13:51:56:464]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (A8:84) [13:51:56:464]: PROPERTY CHANGE: Modifying PREVIOUS_VERSION property. Its current value is '0'. Its new value: '18.0.0.241'.
MSI (s) (A8:84) [13:51:56:464]: Doing action: LaunchConditions
Action ended 13:51:56: AppSearch. Return value 1.
Action start 13:51:56: LaunchConditions.
MSI (s) (A8:84) [13:51:56:464]: Doing action: FindRelatedProducts
Action ended 13:51:56: LaunchConditions. Return value 1.
Action start 13:51:56: FindRelatedProducts.
MSI (s) (A8:84) [13:51:56:466]: PROPERTY CHANGE: Adding ISACTIONPROP1 property. Its value is '{F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}'.
MSI (s) (A8:84) [13:51:56:466]: PROPERTY CHANGE: Adding MIGRATE property. Its value is '{F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}'.
MSI (s) (A8:84) [13:51:56:466]: FindRelatedProducts: could not read ASSIGNMENTTYPE info for product '{A37E9FA0-00FE-479D-9F62-E6E3DBA51D29}'. Skipping...
MSI (s) (A8:84) [13:51:56:466]: FindRelatedProducts: current install is per-user. Related install for product '{DE3DB02A-3402-4CC4-AF65-B52AE8406739}' is per-machine. Skipping...
MSI (s) (A8:84) [13:51:56:466]: Skipping action: CCPSearch (condition is false)
MSI (s) (A8:84) [13:51:56:466]: Skipping action: RMCCPSearch (condition is false)
MSI (s) (A8:84) [13:51:56:466]: Doing action: ValidateProductID
Action ended 13:51:56: FindRelatedProducts. Return value 1.
Action start 13:51:56: ValidateProductID.
MSI (s) (A8:84) [13:51:56:466]: Doing action: MakePropsAvailable
Action ended 13:51:56: ValidateProductID. Return value 1.
Action start 13:51:56: MakePropsAvailable.
MSI (s) (A8:84) [13:51:56:467]: Doing action: IsIllegalUpgrade
Action ended 13:51:56: MakePropsAvailable. Return value 1.
Action start 13:51:56: IsIllegalUpgrade.
MSI (s) (A8:84) [13:51:56:497]: Doing action: CostInitialize
Action ended 13:51:56: IsIllegalUpgrade. Return value 0.
MSI (s) (A8:84) [13:51:56:497]: Machine policy value 'MaxPatchCacheSize' is 10
MSI (s) (A8:84) [13:51:56:498]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'C:\'.
MSI (s) (A8:84) [13:51:56:498]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (A8:84) [13:51:56:498]: Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (A8:84) [13:51:56:498]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (A8:84) [13:51:56:498]: Note: 1: 2205 2: 3: MsiPatchHeaders
MSI (s) (A8:84) [13:51:56:498]: Note: 1: 2205 2: 3: __MsiPatchFileList
MSI (s) (A8:84) [13:51:56:498]: Note: 1: 2228 2: 3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
Action start 13:51:56: CostInitialize.
MSI (s) (A8:84) [13:51:56:498]: Doing action: FileCost
Action ended 13:51:56: CostInitialize. Return value 1.
MSI (s) (A8:84) [13:51:56:499]: Note: 1: 2205 2: 3: MsiAssembly
MSI (s) (A8:84) [13:51:56:499]: Note: 1: 2205 2: 3: Class
MSI (s) (A8:84) [13:51:56:499]: Note: 1: 2205 2: 3: Extension
MSI (s) (A8:84) [13:51:56:499]: Note: 1: 2205 2: 3: TypeLib
Action start 13:51:56: FileCost.
MSI (s) (A8:84) [13:51:56:499]: Doing action: IsolateComponents
Action ended 13:51:56: FileCost. Return value 1.
Action start 13:51:56: IsolateComponents.
MSI (s) (A8:84) [13:51:56:499]: Doing action: CostFinalize
Action ended 13:51:56: IsolateComponents. Return value 0.
MSI (s) (A8:84) [13:51:56:499]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (A8:84) [13:51:56:499]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (A8:84) [13:51:56:499]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (A8:84) [13:51:56:499]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (A8:84) [13:51:56:499]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (A8:84) [13:51:56:499]: Note: 1: 2205 2: 3: Condition
MSI (s) (A8:84) [13:51:56:501]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'C:\'.
MSI (s) (A8:84) [13:51:56:501]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\'.
MSI (s) (A8:84) [13:51:56:501]: PROPERTY CHANGE: Adding MACROMED property. Its value is 'C:\Windows\SysWOW64\Macromed\'.
MSI (s) (A8:84) [13:51:56:501]: PROPERTY CHANGE: Adding FLASH property. Its value is 'C:\Windows\SysWOW64\Macromed\Flash\'.
MSI (s) (A8:84) [13:51:56:501]: PROPERTY CHANGE: Adding INSTALLDIR property. Its value is 'C:\Windows\SysWOW64\Macromed\Flash\'.
MSI (s) (A8:84) [13:51:56:501]: PROPERTY CHANGE: Adding ISCommonFilesFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\'.
MSI (s) (A8:84) [13:51:56:501]: PROPERTY CHANGE: Adding ISUpdateServiceFolder property. Its value is 'C:\Program Files (x86)\Common Files\InstallShield\UpdateService\'.
MSI (s) (A8:84) [13:51:56:501]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\'.
MSI (s) (A8:84) [13:51:56:501]: Target path resolution complete. Dumping Directory table...
MSI (s) (A8:84) [13:51:56:501]: Note: target paths subject to change (via custom actions or browsing)
MSI (s) (A8:84) [13:51:56:501]: Dir (target): Key: TARGETDIR , Object: C:\
MSI (s) (A8:84) [13:51:56:501]: Dir (target): Key: WindowsFolder , Object: C:\Windows\
MSI (s) (A8:84) [13:51:56:501]: Dir (target): Key: USERPROFILE , Object: C:\
MSI (s) (A8:84) [13:51:56:501]: Dir (target): Key: TempFolder , Object: C:\Windows\TEMP\
MSI (s) (A8:84) [13:51:56:501]: Dir (target): Key: SystemFolder , Object: C:\Windows\SysWOW64\
MSI (s) (A8:84) [13:51:56:501]: Dir (target): Key: MACROMED , Object: C:\Windows\SysWOW64\Macromed\
MSI (s) (A8:84) [13:51:56:501]: Dir (target): Key: FLASH , Object: C:\Windows\SysWOW64\Macromed\Flash\
MSI (s) (A8:84) [13:51:56:501]: Dir (target): Key: INSTALLDIR , Object: C:\Windows\SysWOW64\Macromed\Flash\
MSI (s) (A8:84) [13:51:56:501]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files (x86)\Common Files\
MSI (s) (A8:84) [13:51:56:501]: Dir (target): Key: ISCommonFilesFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\
MSI (s) (A8:84) [13:51:56:501]: Dir (target): Key: ISUpdateServiceFolder , Object: C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
MSI (s) (A8:84) [13:51:56:501]: Dir (target): Key: ALLUSERSPROFILE , Object: C:\
MSI (s) (A8:84) [13:51:56:501]: Note: 1: 2205 2: 3: MsiAssembly
MSI (s) (A8:84) [13:51:56:501]: Note: 1: 2228 2: 3: MsiAssembly 4: SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`, `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE `MsiAssembly`.`Component_` = `Component`.`Component` AND `MsiAssembly`.`Component_` = ?
Action start 13:51:56: CostFinalize.
MSI (s) (A8:84) [13:51:56:501]: Doing action: SetARPINSTALLLOCATION
Action ended 13:51:56: CostFinalize. Return value 1.
MSI (s) (A8:84) [13:51:56:502]: PROPERTY CHANGE: Adding ARPINSTALLLOCATION property. Its value is 'C:\Windows\SysWOW64\Macromed\Flash\'.
Action start 13:51:56: SetARPINSTALLLOCATION.
MSI (s) (A8:84) [13:51:56:502]: Doing action: SetODBCFolders
Action ended 13:51:56: SetARPINSTALLLOCATION. Return value 1.
MSI (s) (A8:84) [13:51:56:502]: Note: 1: 2205 2: 3: ODBCDriver
MSI (s) (A8:84) [13:51:56:502]: Note: 1: 2228 2: 3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
MSI (s) (A8:84) [13:51:56:502]: Note: 1: 2205 2: 3: ODBCTranslator
MSI (s) (A8:84) [13:51:56:502]: Note: 1: 2228 2: 3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
Action start 13:51:56: SetODBCFolders.
MSI (s) (A8:84) [13:51:56:502]: Doing action: MigrateFeatureStates
Action ended 13:51:56: SetODBCFolders. Return value 0.
MSI (s) (A8:84) [13:51:56:502]: Migrating feature settings from product(s) '{F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}'
MSI (s) (A8:84) [13:51:56:502]: MigrateFeatureStates: based on existing product, setting feature 'FlashPlayerAXInstaller' to 'Advertise' state.
Action start 13:51:56: MigrateFeatureStates.
MSI (s) (A8:84) [13:51:56:503]: Doing action: InstallValidate
Action ended 13:51:56: MigrateFeatureStates. Return value 1.
MSI (s) (A8:84) [13:51:56:503]: PROPERTY CHANGE: Deleting MsiRestartManagerSessionKey property. Its current value is 'e1fbc51aadacd3488208b74be899ca61'.
MSI (s) (A8:84) [13:51:56:503]: Feature: FlashPlayerAXInstaller; Installed: Advertise; Request: Advertise; Action: Advertise
MSI (s) (A8:84) [13:51:56:503]: Component: __ISRegistryComponent65; Installed: Null; Request: Null; Action: Null
MSI (s) (A8:84) [13:51:56:503]: Component: ISRegistryComponent; Installed: Absent; Request: Null; Action: Null
MSI (s) (A8:84) [13:51:56:503]: Component: InstallPlugin_18_0_0_255.exe; Installed: Absent; Request: Null; Action: Null
MSI (s) (A8:84) [13:51:56:503]: Note: 1: 2205 2: 3: BindImage
MSI (s) (A8:84) [13:51:56:503]: Note: 1: 2205 2: 3: ProgId
MSI (s) (A8:84) [13:51:56:503]: Note: 1: 2205 2: 3: PublishComponent
MSI (s) (A8:84) [13:51:56:503]: Note: 1: 2205 2: 3: SelfReg
MSI (s) (A8:84) [13:51:56:503]: Note: 1: 2205 2: 3: Extension
MSI (s) (A8:84) [13:51:56:503]: Note: 1: 2205 2: 3: Font
MSI (s) (A8:84) [13:51:56:503]: Note: 1: 2205 2: 3: Shortcut
MSI (s) (A8:84) [13:51:56:503]: Note: 1: 2205 2: 3: Class
MSI (s) (A8:84) [13:51:56:503]: Note: 1: 2205 2: 3: TypeLib
Action start 13:51:56: InstallValidate.
MSI (s) (A8:84) [13:51:56:503]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (A8:84) [13:51:56:504]: Note: 1: 2205 2: 3: BindImage
MSI (s) (A8:84) [13:51:56:504]: Note: 1: 2205 2: 3: ProgId
MSI (s) (A8:84) [13:51:56:504]: Note: 1: 2205 2: 3: PublishComponent
MSI (s) (A8:84) [13:51:56:504]: Note: 1: 2205 2: 3: SelfReg
MSI (s) (A8:84) [13:51:56:504]: Note: 1: 2205 2: 3: Extension
MSI (s) (A8:84) [13:51:56:504]: Note: 1: 2205 2: 3: Font
MSI (s) (A8:84) [13:51:56:504]: Note: 1: 2205 2: 3: Shortcut
MSI (s) (A8:84) [13:51:56:504]: Note: 1: 2205 2: 3: Class
MSI (s) (A8:84) [13:51:56:504]: Note: 1: 2205 2: 3: TypeLib
MSI (s) (A8:84) [13:51:56:504]: Note: 1: 2727 2:
MSI (s) (A8:84) [13:51:56:504]: Note: 1: 2205 2: 3: FilesInUse
MSI (s) (A8:84) [13:51:56:514]: Note: 1: 2727 2:
MSI (s) (A8:84) [13:51:56:514]: Doing action: RemoveExistingProducts
Action ended 13:51:56: InstallValidate. Return value 1.
Action start 13:51:56: RemoveExistingProducts.
MSI (s) (A8:D0) [13:51:56:516]: Resetting cached policy values
MSI (s) (A8:D0) [13:51:56:516]: Machine policy value 'Debug' is 0
MSI (s) (A8:D0) [13:51:56:516]: ******* RunEngine:
******* Product: {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}
******* Action:
MSI (s) (A8:D0) [13:51:56:516]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (A8:D0) [13:51:56:516]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (A8:D0) [13:51:56:516]: User policy value 'DisableMedia' is 0
MSI (s) (A8:D0) [13:51:56:516]: Machine policy value 'AllowLockdownMedia' is 0
MSI (s) (A8:D0) [13:51:56:516]: SOURCEMGMT: Media enabled only if package is safe.
MSI (s) (A8:D0) [13:51:56:516]: SOURCEMGMT: Looking for sourcelist for product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}
MSI (s) (A8:D0) [13:51:56:516]: SOURCEMGMT: Adding {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}; to potential sourcelist list (pcode;disk;relpath).
MSI (s) (A8:D0) [13:51:56:516]: SOURCEMGMT: Now checking product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}
MSI (s) (A8:D0) [13:51:56:516]: SOURCEMGMT: Media is enabled for product.
MSI (s) (A8:D0) [13:51:56:516]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
MSI (s) (A8:D0) [13:51:56:516]: SOURCEMGMT: Processing net source list.
MSI (s) (A8:D0) [13:51:56:517]: SOURCEMGMT: Trying source C:\Windows\ccmcache\ei\.
MSI (s) (A8:D0) [13:51:56:517]: Note: 1: 2203 2: C:\Windows\ccmcache\ei\flashplayer15_0r0_239_win.msi 3: -2147287037
MSI (s) (A8:D0) [13:51:56:517]: SOURCEMGMT: Source is invalid due to missing/inaccessible package.
MSI (s) (A8:D0) [13:51:56:517]: Note: 1: 1706 2: -2147483647 3: flashplayer15_0r0_239_win.msi
MSI (s) (A8:D0) [13:51:56:517]: SOURCEMGMT: Processing media source list.
MSI (s) (A8:D0) [13:51:56:519]: Note: 1: 2203 2: 3: -2147287037
MSI (s) (A8:D0) [13:51:56:519]: SOURCEMGMT: Source is invalid due to missing/inaccessible package.
MSI (s) (A8:D0) [13:51:56:519]: Note: 1: 1706 2: -2147483647 3: flashplayer15_0r0_239_win.msi
MSI (s) (A8:D0) [13:51:56:519]: SOURCEMGMT: Processing URL source list.
MSI (s) (A8:D0) [13:51:56:519]: Note: 1: 1402 2: UNKNOWN\URL 3: 2
MSI (s) (A8:D0) [13:51:56:519]: Note: 1: 1706 2: 3: flashplayer15_0r0_239_win.msi
MSI (s) (A8:D0) [13:51:56:521]: SOURCEMGMT: Failed to resolve source
MSI (s) (A8:84) [13:51:56:521]: Note: 1: 1714 2: Adobe Flash Player 18 NPAPI 3: 1612
CustomAction returned actual error code 1612 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (A8:84) [13:51:56:521]: Product: Adobe Flash Player 18 NPAPI -- Error 1714.The older version of Adobe Flash Player 18 NPAPI cannot be removed. Contact your technical support group. System Error 1612.
Action ended 13:51:56: RemoveExistingProducts. Return value 3.
Action ended 13:51:56: INSTALL. Return value 3.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {D85A1A59-DC52-4D13-9445-EF3F379D4DB5}
Property(S): ProductCode = {8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}
Property(S): VersionNT = 601
Property(S): TARGETDIR = C:\
Property(S): ALLUSERSPROFILE = C:\
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): OutOfDiskSpace = 0
Property(S): MACROMED = C:\Windows\SysWOW64\Macromed\
Property(S): FLASH = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): INSTALLDIR = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): CostingComplete = 1
Property(S): TempFolder = C:\Windows\TEMP\
Property(S): USERPROFILE = C:\
Property(S): ROOTDRIVE = C:\
Property(S): MIGRATE = {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}
Property(S): IS_MAJOR_UPGRADE = Yes
Property(S): ACTION = INSTALL
Property(S): UILevel = 2
Property(S): OriginalDatabase = C:\Windows\ccmcache\db\install_flash_player_18_plugin.msi
Property(S): DATABASE = C:\Windows\Installer\e99b980.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
Property(S): MsiNetAssemblySupport = 4.6.81.0
Property(S): Date = 12/4/2015
Property(S): Time = 13:51:56
Property(S): TTCSupport = 1
Property(S): PREVIOUS_VERSION = 18.0.0.241
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): RestartManagerOption = CloseRestart
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): Display_IsBitmapDlg = 1
Property(S): ProductName = Adobe Flash Player 18 NPAPI
Property(S): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
Property(S): ARPNOMODIFY = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): ARPURLINFOABOUT = http://www.adobe.com
Property(S): ColorBits = 32
Property(S): ARPURLUPDATEINFO = http://www.adobe.com/go/getflashplayer
Property(S): DWUSINTERVAL = 30
Property(S): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): TextInternalLeading = 3
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): ErrorDialog = SetupError
Property(S): INSTALLLEVEL = 100
Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine. If available, please run ISScript.msi, or contact your support personnel for further assistance.
Property(S): ISVROOT_PORT_NO = 0
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_TEXTFILECHANGS_REPLACE = Replacing %s with %s in %s...
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): InstallChoice = AR
Property(S): Manufacturer = Adobe Systems Incorporated
Property(S): MsiLogging = voicewarmupx
Property(S): NewProperty2 = 0
Property(S): NewProperty3 = 0
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductVersion = 18.0.0.255
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): RebootYesNo = Yes
Property(S): ReinstallModeText = omus
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): SecureCustomProperties = INSTALLDIR;ISACTIONPROP1;PREVIOUS_VERSION;SUPPORTDIR
Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_plugin.exe
Property(S): SETUPEXENAME = setup.exe
Property(S): ARPINSTALLLOCATION = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): AdminUser = 1
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 1033
Property(S): ISACTIONPROP1 = {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}
Property(S): ComputerName = LUMICLS093
Property(S): UserLanguageID = 1033
Property(S): UserSID = S-1-5-18
Property(S): LogonUser = SYSTEM
Property(S): MsiTrueAdminUser = 1
Property(S): VirtualMemory = 3834
Property(S): PhysicalMemory = 3978
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): COMPANYNAME = PRODSCCM01
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): USERNAME = asccm
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): MyPicturesFolder = C:\Windows\system32\config\systemprofile\Pictures\
Property(S): LocalAppDataFolder = C:\Windows\system32\config\systemprofile\AppData\Local\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): SendToFolder = C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): RecentFolder = C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): PrintHoodFolder = C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): PersonalFolder = C:\Windows\system32\config\systemprofile\Documents\
Property(S): NetHoodFolder = C:\Windows\system32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): FavoritesFolder = C:\Windows\system32\config\systemprofile\Favorites\
Property(S): AppDataFolder = C:\Windows\system32\config\systemprofile\AppData\Roaming\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): RemoteAdminTS = 1
Property(S): System64Folder = C:\Windows\system32\
Property(S): WindowsVolume = C:\
Property(S): WindowsFolder = C:\Windows\
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 1
Property(S): WindowsBuild = 7601
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): VersionDatabase = 110
Property(S): PRODUCTLANGUAGE = 1033
Property(S): CLIENTPROCESSID = 9260
Property(S): CLIENTUILEVEL = 3
Property(S): CURRENTDIRECTORY = C:\Windows\ccmcache\dd
Property(S): ProductState = 1
Property(S): PackageCode = {D9D17B01-BB3B-4552-9C85-DEA3A865FDE8}
Property(S): MsiLogFileLocation = C:\Windows\ccmcache\dd\loginstall.txt
MSI (s) (A8:84) [13:51:56:541]: Deferring clean up of packages/files, if any exist
MSI (s) (A8:84) [13:51:56:542]: MainEngineThread is returning 1603
MSI (s) (A8:A0) [13:51:56:544]: RESTART MANAGER: Session closed.
MSI (s) (A8:A0) [13:51:56:544]: No System Restore sequence number for this installation.
=== Logging stopped: 12/4/2015 13:51:56 ===
MSI (s) (A8:A0) [13:51:56:546]: User policy value 'DisableRollback' is 0
MSI (s) (A8:A0) [13:51:56:546]: Machine policy value 'DisableRollback' is 0
MSI (s) (A8:A0) [13:51:56:546]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (A8:A0) [13:51:56:546]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (A8:A0) [13:51:56:546]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\InProgress 3: 2
MSI (s) (A8:A0) [13:51:56:546]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (A8:A0) [13:51:56:546]: Restoring environment variables
MSI (s) (A8:A0) [13:51:56:547]: Destroying RemoteAPI object.
MSI (s) (A8:20) [13:51:56:547]: Custom Action Manager thread ending.
MSI (c) (2C:10) [13:51:56:547]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (2C:10) [13:51:56:548]: MainEngineThread is returning 1603
=== Verbose logging stopped: 12/4/2015 13:51:56 ===
So what I have done :
Tried to install different versions = not working
Tried to use the adobe cleaner before install = not working
I can find in the log a part saying that there is an older version already installed, but I do not know what to delete to force the installation since I runned the cleaner.
Does someone know what to do in case please ?
Regards,
Thomas.
Hi ThomasV88,
Error 1603 appears to be a generic error from Windows Installer. The actual error is in this block:
Essentially the MSI installer for 15.0.0.239 cannot be found and it is needed to uninstall 15.0.0.239 before version 18 can be installed.
You can try a few options to remedy the situation:
Maria
I tried your solution but it is still not working.
First of all, I use the MsiZap with this command : MsiZap.exe T flashplayer15_0r0_239_win.msi > logmsizap.txt
This command works on computer that are not impacted by the problem. ( I tried to install first flash 15 on test devices and then 18 and this command works)
And there is the log that I get on impacted devices.
MsiZap V 5.0
Copyright (c) Microsoft Corporation. All Rights Reserved
MsiZapInfo: Performing operations for user S-1-5-18
Searching for the product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24} cached package. . .
Searching for install property data for product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}. . .
Searching user's global config location for product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24} data. . .
Searching for product A0A0141F502854D4FBB2C9A7BCF2B442 upgrade codes in Software\Microsoft\Windows\CurrentVersion\Installer\\UpgradeCodes...
Searching for patches for product A0A0141F502854D4FBB2C9A7BCF2B442 in Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\A0A0141F502854D4FBB2C9A7BCF2B442\Patches
Searching HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\A0A0141F502854D4FBB2C9A7BCF2B442 for product data. . .
Searching HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Features\A0A0141F502854D4FBB2C9A7BCF2B442 for product feature data. . .
Searching per-machine global config location for product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24} data. . .
Searching old global config location for product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24} data. . .
Searching for product A0A0141F502854D4FBB2C9A7BCF2B442 upgrade codes in Software\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes...
Searching for patches for product A0A0141F502854D4FBB2C9A7BCF2B442 in Software\Microsoft\Windows\CurrentVersion\Installer\Products\A0A0141F502854D4FBB2C9A7BCF2B442\Patches
Searching HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Products\A0A0141F502854D4FBB2C9A7BCF2B442 for product data. . .
Searching HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Features\A0A0141F502854D4FBB2C9A7BCF2B442 for product feature data. . .
Searching per-machine location for product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24} data. . .
Searching for product A0A0141F502854D4FBB2C9A7BCF2B442 upgrade codes in Software\Classes\Installer\UpgradeCodes...
Searching for patches for product A0A0141F502854D4FBB2C9A7BCF2B442 in Software\Classes\Installer\Products\A0A0141F502854D4FBB2C9A7BCF2B442\Patches
Searching HKLM\Software\Classes\Installer\Components for published component data for the product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}. . .
Searching HKLM\Software\Classes\Installer\Assemblies for .Net assembly data for the product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}. . .
Searching HKLM\Software\Classes\Installer\Win32Assemblies for Win32 assembly data for the product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}. . .
Searching HKLM\Software\Classes\Installer\Products\A0A0141F502854D4FBB2C9A7BCF2B442 for product data. . .
Searching HKLM\Software\Classes\Installer\Features\A0A0141F502854D4FBB2C9A7BCF2B442 for product feature data. . .
Searching for product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24} in per-user managed location. . .
Searching for product A0A0141F502854D4FBB2C9A7BCF2B442 upgrade codes in Software\Microsoft\Windows\CurrentVersion\Installer\Managed\S-1-5-18\Installer\UpgradeCodes...
Searching for patches for product A0A0141F502854D4FBB2C9A7BCF2B442 in Software\Microsoft\Windows\CurrentVersion\Installer\Managed\S-1-5-18\Installer\Products\A0A0141F502854D4FBB2C9A7BCF2B442\Patches
Searching HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Managed\S-1-5-18\Installer\Products\A0A0141F502854D4FBB2C9A7BCF2B442 for product data. . .
Searching HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Managed\S-1-5-18\Installer\Features\A0A0141F502854D4FBB2C9A7BCF2B442 for product feature data. . .
Searching for shared DLL counts for components tied to the product A0A0141F502854D4FBB2C9A7BCF2B442. . .
HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Components key is not present.
Searching for product A0A0141F502854D4FBB2C9A7BCF2B442 client info data. . .
Searching for Installer files and folders associated with the product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}. . .
Searching for files and folders in the user's profile. . .
Searching for files and folders in the %WINDIR%\Installer folder
FAILED to clear all data.
After that i use the Cleaner as you said with the command : uninstall_flash_player.exe -uninstall
When I try to install flash after that the same error occur.
MSI (s) (D8:34) [13:02:22:809]: User policy value 'DisableMedia' is 1
MSI (s) (D8:34) [13:02:22:809]: SOURCEMGMT: Looking for sourcelist for product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}
MSI (s) (D8:34) [13:02:22:809]: SOURCEMGMT: Adding {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}; to potential sourcelist list (pcode;disk;relpath).
MSI (s) (D8:34) [13:02:22:810]: SOURCEMGMT: Now checking product {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}
MSI (s) (D8:34) [13:02:22:810]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
MSI (s) (D8:34) [13:02:22:810]: SOURCEMGMT: Processing net source list.
MSI (s) (D8:34) [13:02:22:810]: SOURCEMGMT: Trying source C:\Windows\ccmcache\ey\.
MSI (s) (D8:34) [13:02:22:810]: Note: 1: 2203 2: C:\Windows\ccmcache\ey\flashplayer15_0r0_239_win.msi 3: -2147287037
MSI (s) (D8:34) [13:02:22:810]: SOURCEMGMT: Source is invalid due to missing/inaccessible package.
MSI (s) (D8:34) [13:02:22:810]: Note: 1: 1706 2: -2147483647 3: flashplayer15_0r0_239_win.msi
MSI (s) (D8:34) [13:02:22:810]: SOURCEMGMT: Media Disabled for this package.
MSI (s) (D8:34) [13:02:22:810]: SOURCEMGMT: Processing URL source list.
MSI (s) (D8:34) [13:02:22:810]: Note: 1: 1402 2: UNKNOWN\URL 3: 2
MSI (s) (D8:34) [13:02:22:810]: Note: 1: 1706 2: 3: flashplayer15_0r0_239_win.msi
MSI (s) (D8:34) [13:02:22:810]: SOURCEMGMT: Failed to resolve source
MSI (s) (D8:30) [13:02:22:810]: Note: 1: 1714 2: Adobe Flash Player 18 NPAPI 3: 1612
MSI (s) (D8:30) [13:02:22:810]: Product: Adobe Flash Player 18 NPAPI -- Error 1714.The older version of Adobe Flash Player 18 NPAPI cannot be removed. Contact your technical support group. System Error 1612.
Action ended 13:02:22: RemoveExistingProducts. Return value 3.
Action ended 13:02:22: INSTALL. Return value 3.
The sources for Flash 15 and 18 are in the same folder (with the good name of course), so I do not understand why the system can't find the sources.
Regards,
Thomas
Is 15.0.0.239 still installed on the impacted system, even after running the uninstaller? Please post a screenshot (see How to post a screenshot in the forum) of the contents of the C:\Windows\System32\Macromed\Flash directory. If this is a 64-bit OS also post a screenshot of the contents of the C:\Windows\SysWOW64\Macromed\Flash directory. Please make sure the file extensions are visible before taking the screenshots. See Show or hide file name extensions - Windows Help.
Maria
Sorry I was not available before today.
Here is the screenshot as requested.
The version 15.0.0.239 seems to be uninstalled now ( the script is running every morning ) but the version 18.0.0.255 is still not working.
Here is the log :
MSI (s) (AC:88) [18:26:11:950]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (AC:88) [18:26:11:966]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (AC:88) [18:26:11:966]: User policy value 'DisableMedia' is 1
MSI (s) (AC:88) [18:26:11:966]: SOURCEMGMT: Looking for sourcelist for product {8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}
MSI (s) (AC:88) [18:26:11:966]: SOURCEMGMT: Adding {8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}; to potential sourcelist list (pcode;disk;relpath).
MSI (s) (AC:88) [18:26:11:966]: SOURCEMGMT: Now checking product {8656EDBE-7C0A-4945-8D49-493FDBE7B5BD}
MSI (s) (AC:88) [18:26:11:966]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
MSI (s) (AC:88) [18:26:11:966]: SOURCEMGMT: Trying source C:\Windows\ccmcache\vi\.
MSI (s) (AC:88) [18:26:11:966]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer 3: 2
MSI (s) (AC:88) [18:26:11:966]: Note: 1: 2203 2: C:\Windows\ccmcache\vi\install_flash_player_18_plugin.msi 3: -2147287037
MSI (s) (AC:88) [18:26:11:966]: SOURCEMGMT: Source is invalid due to missing/inaccessible package.
MSI (s) (AC:88) [18:26:11:966]: Note: 1: 1706 2: -2147483647 3: install_flash_player_18_plugin.msi
MSI (s) (AC:88) [18:26:11:966]: SOURCEMGMT: Processing net source list.
MSI (s) (AC:88) [18:26:11:966]: SOURCEMGMT: Media Disabled for this package.
MSI (s) (AC:88) [18:26:11:966]: SOURCEMGMT: Processing URL source list.
MSI (s) (AC:88) [18:26:11:966]: Note: 1: 1402 2: UNKNOWN\URL 3: 2
MSI (s) (AC:88) [18:26:11:966]: Note: 1: 1706 2: 3: install_flash_player_18_plugin.msi
MSI (s) (AC:88) [18:26:11:966]: SOURCEMGMT: Failed to resolve source
MSI (s) (AC:88) [18:26:11:966]: MainEngineThread is returning 1612
It seems that the package is not found but the msi is in the same folder as the install script.
I am currently trying with the version 18.0.0.261.
Does the behaviour only reproduce when you try to install the package via SCCM?
Are you able to install it without using SCCM?
Maria
It happens even when I try to install it manually.
Thomas.
My issue still occurs, i am still not able to deploy the new version of flash player for a large number of users.
I tried with the new cleaner coming with the version 20 of flash but nothing change.
I am currently trying with the old sources of flash 15.0.0.239 but I do not think that will change something.
Is there any other solutions?
Regards,
Thomas.
