I select text in a textbox in an open document, go to any of the value input areas on the toolbar (space after, kerning, etc.) input a value, hit tab or enter and the selected copy in the document changes to that value instead of reflecting the layout change for that value. Is this a bug or has something changed in 2017 and I'm inputting wrong?
JK
That's a now wellknown bug with the Paragraph panel.
There are some workarounds:
A. Activate the Application Frame
Window > Application Frame
( That's my recommendation. I would go for this. )
or:
B. Uncheck one or two preferences showing the OpenType Adornments with selected text:
Preferences > Advanced Type > [ ] Show Adornment on Text Selection/Text Frame for more Type controls
or maybe:
C. Use the Control panel alternatively to the Paragraph panel
But also note, that some reports came in, that also t
...Copy link to clipboard
or:
or maybe:
But also note, that some reports came in, that also the Control panel can be affected if Application Frame is not used:
Re: Can't change measurement in my toolbar! Change the text instead!
And also the Color panel could be affected ( not the Swatches panel, though 😞
Re: Bug in color dialogue box in Indesign
Regards,
Uwe
Note:
In the meanwhile there is a bug-fix for this problem.
It does not come along with an update notification from the CC Desktop app.
The fix is a separate installer you can download here from this Adobe Help page:
Troubleshoot text selection issues
And when we're at it and you are on OSX having trouble with the Hyperlinks Panel see also here:
InDesign CC 2017 crashes on macOS
Regards,
Uwe
